Customs From Clown Car to 1927 T Touring Custom Rod
Discussion in 'The Hokey Ass Message Board' started by VOODOO ROD & CUSTOM, Oct 3, 2021.
  1. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Chuck Vranas Voo Doo Doll.jpg Clown Car 2.jpg 1927 T Body former Shriners Clown Car 1.jpg 1927 T Body former Shriners Clown Car 2 .jpg 1927 T Body former Shriners Clown Car 3 .jpg 1927 T Body former Shriners Clown Car 4 .jpg 1927 T Body former Shriners Clown Car 5 .jpg 1927 T Body former Shriners Clown Car 6 .jpg 1927 T Body former Shriners Clown Car 7 .jpg View attachment 5188899 View attachment 5188900 View attachment 5188901 View attachment 5188902 View attachment 5188903 View attachment 5188904 View attachment 5188905 View attachment 5188906 View attachment 5188907 View attachment 5188908 View attachment 5188909 View attachment 5188910 View attachment 5188911 View attachment 5188912 View attachment 5188899 View attachment 5188900 View attachment 5188907 View attachment 5188908 View attachment 5188909 View attachment 5188910 View attachment 5188911 View attachment 5188912 Ever since Kim Vranas' 1927 T Touring (VOO DOLL) came out; I have been on the hunt for a 1927 T Touring body. Well, today was the day that I finally found one.
    It is a former Shriner's Clown Car that was in excellent condition and eventhough it was altered to make the Clown Car, the body is in very good shape with only the Back Panel needing to be replaced due to a modification that was made.
    I am including images of a substantially similar Clown Car that was for sale on the HAMB some time age. I bought the body only, since the original Model T engine and transmission were already spoken for. I will have to take some photos of the ch***is that this body came off of. It was a wheel standing Clown car of unknown origin.
    My plans, to take cues from Kim Vranas' T Touring build and make this a real Cool
    Custom Hot Rod. It is looking like a hand built ch***is is going to be the way to go utilizing 2 x 4 box tubing with custom sewpt front rails grafted in at the cowl area.
    From the Cowl rearward, I will follow the contour of the body with the 2 x 4 and hopefully be successful at doing a 1932 style reveal in the side of the frame rail. The second possibility is utilizing '32 Rails and custom fabbing the rest. It will be highboy with a Model A front Crossmember and still not certain on the Rear Crossmember and axle/suspension.
    SBF for power -or- anything else Ford that comes along that will give the build a cool factor. Not sure on the Transmission yet. 35 - 36 Wheels with a cool rubber rake are my first choice.
    Everything else is up in the air for now. Still in the planning stages right now.
    Stay Tuned.
    VooDoo Rod & Custom View attachment 5188899 View attachment 5188899 View attachment 5188900 View attachment 5188901 View attachment 5188902 View attachment 5188903 View attachment 5188904 View attachment 5188905 View attachment 5188906 View attachment 5188907 View attachment 5188908 .
    (Quite a coincidence that the car that I like is called the VOO DOO DOLL !!)
    VooDoo Rod and Custom.
  2. Max Gearhead
    Max Gearhead
    from Wisconsin
  3. Rehpotsirhcj
    Rehpotsirhcj
    Too many clowns out there messing up perfectly good hot rods. :)
    Looking forward to your build!
    Stogy and loudbang like this.
  4. A car after my own heart , great start to a build !!! 20210518_205651.jpg
  5. Rickybop
    Rickybop
    Awesome. :D
  6. eaglebeak
    eaglebeak
  7. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Picked her up last night.
    Here are some Pix of the ch***is that it came off of.
    The entire ch***is and driveline were already sold.
    I had no interest in any of that stuff so there are Two of us that are happy.
    VR&C.
  8. rusty valley
    rusty valley
    I would have liked to play with the clown car for a while !
  9. You sure about that?
  10. rusty valley
    rusty valley
    Reason is, its the only way I will ever do a wheel stand in a car
  11. Model-T-clown-car-12.jpg Brings back great memories of povertyflats (Paul), good times.
    Paul B, chryslerfan55, Cooon and 9 others like this.
  12. rod1
    rod1
    And Pie!
    chryslerfan55, Stogy and loudbang like this.
  13. rusty rocket
    rusty rocket
    I actually think clown cars are kool. Shriners do so much for sick kids. If A clown car helps them raise money then that’s two thumbs up from me.
  14. Fortunateson
    Fortunateson
    I hope you decide not to use a Deuce grille shell. Though a very handsome thing it's been done forever on A's and the A grille is cool in its own right!
  15. rusty rocket
    rusty rocket
    I’m with you on the 32 shell but I think a T should run a T shell. I have a 26 T modified with a T shell and am working on a 26 roadster that will also run a T shell.
  16. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    I have the original T shell and Lower Shell apron as well as the original Hood.
    Started stripping off the Yellow paint last night. The original Black paint is still underneath the Yellow and still sticking like crazy. The Yellow came off very easily.
    Moving Forward already.
    VR&C.
  17. alchemy
    alchemy
    Unless you can find a cherry original rear panel, you should probably just patch the one you have. The repros I've seen don't fit worth a dang and have a poor curve to them.
  18. rusty rocket
    rusty rocket
    Or he can cut it in half like this! Hahaha! ADC32D82-0606-4C47-9075-EC30EA81A4A8.jpeg
  19. Fortunateson
    Fortunateson
    Ooooops! I typed "A" when I meant "T". A T on a T and an A on an A. Just because that beautiful Deuce grille shell has been overdone as a transplant...
    Stogy, El Mirage Garage and loudbang like this.
  20. rusty rocket
    rusty rocket
    You got that right! I do like 30-31’s with a deuce shell but that’s about it.
  21. RICH B
    RICH B
    Old neighbor maintained a T parade car for some civic group. When I got a little older; I noticed it didn't have a T rear end; next time he was working on it, I stopped by and visited; turns out he put a B engine, trans, and an A rear in it. He said he changed it out as he was tired of training new guys to work the T's three pedals all the time.
  22. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
  23. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    DAMN double images !
    I'll have to clean up this thread when I have more time.
    VR&C.
  24. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Starting in on the body work. There isn't very much. This body is real clean. Most of the grinded off areas are holes that I will be filling.
    The area between the Frt and Rr Doors on both sides will be cut out and patch panels welded in. LT Side Body Roughout 1.jpg LT Side Body Roughout 1.jpg LT Side Body Roughout 2 .jpg LT Side Body Roughout 3 .jpg RT Side Body Roughout 1.jpg RT Side Body Roughout 2.jpg RT Side Body Roughout 3.jpg
  25. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    The Two arched areas on each Rear Door is where the builder burned the Hell out of the Door Skin(s) with his trusty Arch Welder ! when he welded the Rear Fenders to the Doors.
    Stogy, loudbang and AndersF like this.
  26. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Spent the day stripping the body and roughing in the little sheet metal replacement that is needed.
    This body is in very good overall condition. 20220122_195112.jpg A Little rot in L Rr Quarter .jpg A Little rot in R Rr Quarter .jpg Body Stripped 1.jpg Body Stripped 2.jpg Body Stripped 3 .jpg Body Stripped 4.jpg Body Stripped 5 jpg.jpg Body Stripped 6,jpg.jpg Cutting out rot in R Rr Quarter 2.jpg Cutting out rot in R Rr Quarter.jpg Rot cut out of L Rr Quarter.jpg Rot cut out of R Rr Quarter.jpg Sheetmetal replacement between Doors 1.jpg Sheetmetal replacement between Doors 2 .jpg Sheetmetal replacement between Doors 3  .jpg Sheetmetal replacement between Doors 4  .jpg
  27. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Spent another Snowy Syracuse day taking care of the RT. & LT. Quarter Panel Supports. Orignially, this area was actually just the point where the Quarter Panel and Dogleg panels overlapped. I decided to cut all rot out and replace the area with a formed piece of 18 gauge steel as seen in the pix. I will then fabricate a one piece panel to fill in the area and weld all seams together. I had the welder set a little cold and once I turned up the heat, the welds laid down much better. Hoping to have the body wrapped up and in Epoxy primer in the next couple of weeks.
    VR&C. Right Rear Quarter Panel Support  2 .jpg Right Rear Quarter Panel Support  tacked in  .jpg Right Rear Quarter Panel Support  welded .jpg Right Rear Quarter Panel Support .jpg Right Rear Quarter Panel Support Outer at the subrail .jpg Right Rear Quarter Panel Support Outer at the subrail 2 .jpg Right Rear Quarter Panel Support Outer at the subrail 3  .jpg Right Rear Quarter Panel Support Outer at the subrail 4   .jpg Left Rear Quarter Panel Support .jpg
  28. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Metal Prepping. The sheetmetal on this body is real clean. The dull grey areas are Evercoat Metal 2 Metal filler. The rest is original Henry steel. This steel is completely different that the steel of the last 50 years. Metal Prep 1.jpg Metal Prep 2 .jpg Metal Prep 3.jpg Metal Prep 4.jpg
  29. pprather
    pprather
    Nice progress!
    Hamtown Al, loudbang and Stogy like this.
  30. Rusty J
    Rusty J
    I'm interested in knowing how the steel is different from newer steel - I've got a 27 touring waiting it's turn and will be going down this road too.
    Stogy, Hamtown Al and loudbang like this.
