Technical Open BANJO BRACING Q.
Discussion in 'Traditional Hot Rods' started by hardtimesainit, Oct 12, 2021.
  1. hardtimesainit
    hardtimesainit
    Can anyone point out drawing of how an open banjo rear should be safely braced ?
    Im going to use an auto trans, with open drive shaft… model A.
    I haven't a clue, so any help will be appreciated.
    For use with a 4 banger.
  2. 1946caddy
    1946caddy
    from washington
    Her's one example from the HAMB I think. There are lots of different ways .
  3. sdroadster
    sdroadster
    You didn't mention what year rear end you are planning to use. I am pretty sure open drive kits only fit V8 rear ends 35-48.
  4. 1946caddy
    1946caddy
    from washington
  5. hardtimesainit
    hardtimesainit
    Thanks, very nice !
    Rick
    lothiandon1940 likes this.
  6. hardtimesainit
    hardtimesainit
    Dont know what details are most needed ?
    My next question , a**** many….what HP/abuse will the stock model A rear(that is in excellent condition) handle ?
    I insert this question here, as I know old timers who race stock A 3rd members. Some say they have never broken one ?
    The V8 style , ‘35 to ‘48, with the pinion brace, would seem to be a better choice, eh ?
    ARE THEY ALL SAME WIDTH ?
    Where is the ‘open’ seal/u-joint available ??
  7. Budget36
    Budget36
    For the cost of the kits to go open drive, you might want be on the look out for a ‘42-7 Ford PU rearend. They are parallel leaf, but since you’ll be doing a modified setup, shouldn’t cause a problem.
  8. Koz
    Koz
    In my opinion, Model A rears are useful only behind mild A/B block motors. a hot banger will cream one easily. Try to find a post '37 rear as the guts are better. The 1940 style works best under a model A, the only difference up to '48 (other than spring hangers and radius rod style is the '46 to '48 flavor is about 2" wider and contrary to common belief, is not horrible under an A. Just don't run reversed wheels. Lately the later rears seem to be more common.
    I love banjos and there is a lot you can do to make them durable. Remember they ran them in most rails up into the early sixties behind everything including Hemis'. A simple rider bolt does wonders for keeping them in one piece. You didn't mention what you were putting up front but nothing looks better under an A than a nice banjo with the stubs sticking out.
    lothiandon1940, neilswheels and Tman like this.
  9. hardtimesainit
    hardtimesainit
    Hey Koz,
    Well, Ive got this almost ready to dyno ….four banger… it’s a D for Donovan. Hope to have couple hundred HP. So, your input about a post ‘37 is most interesting to me. Pic if comes thru…
    Explain: Rider Bolt ?
    G_Don and Haven Hills Auto Club like this.
  10. PotvinV8
    PotvinV8
  11. studebakerjoe
    studebakerjoe
    @hardtimesainit I'm pretty sure by rider bolt he means having a bolt that goes into the rear against the ring gear opposite the pinion to counteract deflection. Often referred to as a load bolt.
  12. neilswheels
    neilswheels
    from England
    here's a few of mine on my 40, rear bones split. Theres a load of pics on here iof different setuos.
    lothiandon1940 and '28phonebooth like this.
  13. neilswheels
    neilswheels
    from England
    A bunch of others from here that I saved for reference
  14. rusty rocket
    rusty rocket
    I did this on my single seater. Its the front portion of the radius rod I heated and bent. keeps the rear end from rotating and adds to the look of an early sprint car.(edit) forgot to say that I cut the cast part off the front of the wishbone where the two bones meet the torque tube and welded it to the rear where it bolts to the top flange bolt F985FF8C-5B9E-424C-8EAC-A2D5C6FBA616.jpeg 6650459C-79F7-4E61-B447-F0F7E12F0C5E.jpeg
  15. Koz
    Koz
    Studebakerjoe is absolutely correct. The sidebolt, usually br***, helps keep the pinion from running up over the ring gear. This is an old dirt track trick that is also commonly found on over the road big trucks as well.
    The Donovan is insane! I'd love to hear that one wound tight.
  16. hardtimesainit
    hardtimesainit
    Hey Joe,
    Thanks! I kinda get the picture from your words. Im sure it’s not easy, but I can see where … not allowing the ring gear to ‘move’ outward, would be a simple ‘trick’ worth the effort !
  17. lothiandon1940 likes this.
  18. hardtimesainit
    hardtimesainit
    Hey Koz,
    Haven’t got it to run yet, but the engine guy used to build and race his own creations. What a creative old dude( well Im older than dirt…he's younger than dirt !).
    He builds everything from bits/pieces of metal ! His stuff even looks good… ha !
    The D is set to be dyno… Oct/Nov this year. This thing will make heart thump. Ever hear of a four banger with FOUR BOLT MAINS ?
    Yeah that and much more !!
    I got injured back, and he took over. This man is engine builder. Took me TWO years to even get in the door. Once he saw the engineering in this small space….he actually got interested … said ‘ this thing built like a brick outhouse !!
    Anyway, I’m not good with skills, but have already bench raced it 1/4 mi…. woke up with smile and sweat same time !! Just need a good LIGHT ride for it.
    Lucky me, just located a 904 and kit for behind a banger. If I had skills of some here, Id be dangerous, eh !
    Thanks to youse guys for any/all help !!
    Im trying to locate a ‘27 roadster for it. Might get lucky, eh !
    If all goes well, I’ll share dyno stats with you. My lopsided avatar shows a little of the builders’ skills. He built the Holly 4brl intake, exhaust… heck… even the custom oilpump set up( from 59 AB) !!
    lothiandon1940 and Koz like this.
  19. hardtimesainit
    hardtimesainit
    Mr rocket,
    What a great simple idea for bracing AND repurposing a rear radius rod !! Thanks!!
  20. Koz
    Koz
    Can't wait! The wildest creative engine I've seen to date is this guy who brings a '27 Dodge ratty 4 dr. to Fall Wildwood. It has two Mazda ****els back to back with a 650 Holley and an MSD ignition outboard on some homemade drive system. Ugly as hell but the sound is insane out on the road. Way to weird for me. The Donavan is right up there with an Offy for cool as far as I'm concerned and I can't wait to see what you stuff it in.
  21. hardtimesainit
    hardtimesainit
    Hey Joe,
    Would you happen to have a ‘tech’ article on HOW TO …. for detailed instruction for installing rider bolt in banjo rear end ?
    NOTE: Many years ago JUST PLAIN BILL (Rest in peace) who was a valued contributor on the Model A forum, instructed on same subject, I think. Cant find Bills’ work, but sounds like Same trick/improvement. Would be nice to compare tech…now and then !!
  22. hardtimesainit
    hardtimesainit
    Hey Koz….because you enjoy cool, here’s Banger **** for your enjoyment ! Notice the rare two piece pan (RUTHERFORD) on floor …right
    ottoman, lothiandon1940 and Tman like this.
  23. Koz
    Koz
    That is insane! I love it. As close as I've gotten to a hot banger is an early '60's Chevy Iron Duke with a hot cam and a ,030 bore with two 94's on a homemade intake. Actually ran nicely in the bucket. Yours is some real banger ****. I'm watching this one.
  24. RJD
    RJD
    I'd also be interested to see more on this?
  25. FYI, if you search the term "torque arm" you will find more detailed info since that is the actual name for the brace
  26. hardtimesainit
    hardtimesainit
    Hey Tman,
    Thanks!
    Every bit of info/guidance helps !
    I will ‘search’ term torque arm as you suggest !
    More time to use in research now, as Doc says DO NOT go to RPM Nationals tomorrow. Too early …can reinjure back operation of last week !!
    Like the song says…..’maybe next year’ !!
    Tman likes this.
  27. Another way to search. Go to Google, type torque arm/hamb and it will pulll up threads.
    You can also use the plus sign here in searches. torque+arm
  28. studebakerjoe
    studebakerjoe
    @hardtimesainit I may have a tech article somewhere but cant recall where. I took these pics today at work thinking they might help. Both sides of a load bolt on a quickchange bell. 20211018_141332.jpg 20211018_141310.jpg
  29. hardtimesainit
    hardtimesainit
    Hey Joe,
    Yeah, those pics are helpful ! I suppose that same info for use with iron stock rear ?
    If you locate that article, would be great !! Someone mentioned bronze bolt use. Guess that helps with wear, eh ? What a great idea overall, to strengthen Banjo. Any other great tips to strengthen rear ?
