Technical Metal in oil pan
Discussion in 'The Hokey Ass Message Board' started by johnfin, Oct 9, 2021.
  1. johnfin
    johnfin
    from Florida
    I found a few slivers of steel in the oil strainer. They are magnetic. Should i pull all bearing caps? Maybe the bearing backing or journals are hosed.
  2. 427 sleeper
    427 sleeper
    Or the cam is going flat. Pull the caps just to be sure.
    warhorseracing likes this.
  3. warhorseracing
    warhorseracing
    from cameron wv
    Could be the cam going or a lifter. Timing chain or gears. Hard to tell without even knowing what engine it is to properly diagnose.
    427 sleeper likes this.
  4. rusty valley
    rusty valley
    slivers are steel being peeled off something. cast iron would be tiny chips
    Elcohaulic, VANDENPLAS and Deuces like this.
  5. drtrcrV-8
    drtrcrV-8
    Hard to diagnose without at least a brand & year/size to start from, ya think??
  6. CyaNide
    CyaNide
    from Texas
    You should already know the answer to your question.
    CN
    Deuces and ProtoTypeDesignFlauz like this.
  7. johnfin
    johnfin
    from Florida
    Its a 60's chevy 350. I am going to look at the cam and timing chain like you guys mentioned.
    Deuces likes this.
  8. oldsman41
    oldsman41
    350s didn’t eat cams so I would guess you might have a crank bearing ready to go. Take it apart you might have caught it in time before you spun one. Hey let us know what you find
    Deuces and ffr1222k like this.
  9. NoelC
    NoelC
    Because you mentioned 350 Gm, didn't mention knock, loss of power, check the thrust washer at the bottom of the distributor. You might discover it bumping up and wearing out the rotor as it wears away so pulling the cap and lifting the shaft up and down might show excess movement indicating wear.
    Just a guess from past experience.
    alanp561 and Deuces like this.
  10. Deuces
    Deuces
    Ouch!....:(
    lothiandon1940 likes this.
  11. chevy57dude
    chevy57dude
    Hate to say that may be a spun rod bearing.
    Deuces and lothiandon1940 like this.
  12. johnfin
    johnfin
    from Florida
    When you say spun bearings I guess you mean the backing plate when into the crank because the bearings itself is non ferrous like aluminum and copper. My slivers are hard steel.
    427 sleeper and chevy57dude like this.
  13. Deuces
    Deuces
    Doh!....:confused:
    chevy57dude likes this.
  14. chevy57dude
    chevy57dude
    Take a look at #6 rod, with the cap removed. You can see the two bearing halves have stacked up and taken a ride ' round the journal. This left shavings in the pan like you showed.
    alanp561 likes this.
  15. Deuces
    Deuces
    Oh ****!....:(
  16. oldsman41
    oldsman41
    Chevy 57 that’s a great picture, should be in auto shop 101
    klleetrucking, Deuces and chevy57dude like this.
  17. ottoman
    ottoman
    from Wisconsin
    If your bearing is in that shape you wont be asking about some small metal shavings in the pan... but about the loud knocking noise in your motor
    Deuces, chevy57dude and NoelC like this.
  18. johnfin
    johnfin
    from Florida
    my shavings are like the end of tooth picks, about 3/16 long
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    Wrist pin retaining clips ? Internal oil pump gears ?
  20. 427 sleeper
    427 sleeper
    Is the engine down on power and starting to run like ****? Has it ever been apart? Might be time for an exploratory surgery.
    Deuces, chevy57dude and SS327 like this.
  21. Deuces
    Deuces
    Maybe even the timing chain setup.....:confused:
