Projects Belly Tank Build UK
Discussion in 'Traditional Hot Rods' started by JamieUC, Jan 3, 2021.
  1. flathead 37
    flathead 37
    Awesome work! Keep it up!
    loudbang and JamieUC like this.
  2. 26 T Ford RPU
    26 T Ford RPU
    Shifter and dash are very nice. You may need to sleeve some of those bores.
    The big push is on. :cool: JW
  3. JamieUC
    JamieUC
    from Swansea UK
    Yep might have to wear my Kevlar trousers:):D
    loudbang, 26 T Ford RPU and Tman like this.
  4. 282doorUK
    282doorUK
    Got the email too, was hoping to book my Chevy racer in, but after a reality check there are just too many things conspiring against me being able to get it onto the beach this time.
    But I've no doubt you'll git er done in good time, so keep us posted and good luck..
    JamieUC, loudbang and 26 T Ford RPU like this.
  5. saltflats
    saltflats
    from Missouri
    My rear engine dragster had a net like a window net above my legs to keep them contained.
  6. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    What size overbore did you decide on? I would say you could go at least 1/8" oversize (3 mm).
    JamieUC and loudbang like this.
  7. JamieUC
    JamieUC
    from Swansea UK
    Yes I'm thinking just over 1/8, Ross do a piston for 3.342 bore and if I've got my maths right, taking into accout .010" wear already in the cylinders, that should give me a minimum wall thickness of about .100".
    The thinest areas are all at the base of the cylinders so I think the engine will be fairly robust with this size bore...hopefully:)
  8. Yes, SCTA requires some form of retention for arms and legs
  9. Marty Strode
    Marty Strode
    Ross did some 3.342 pistons for a couple of flatheads for us. 3-5/16 + .030.
    JamieUC, Jeff34 and 26 T Ford RPU like this.
  10. Absolutely awesome build.
    JamieUC likes this.
  11. JamieUC
    JamieUC
    from Swansea UK
    knocked up a couple of pedals, gas and clutch, out of some 3mm aluminium and quite a few rivets.
    All mounted and ready for some likage back to the engine bay.
  12. 26 T Ford RPU
    26 T Ford RPU
    They look the cats meow!! :cool::cool: JW
  13. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Do you set those rivets by hand or use a press?
    nice
  14. JamieUC
    JamieUC
    from Swansea UK
    With an air rivet gun and a block of steel for a buck, its a bit hard work on the arms but does the job.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thank you. That is a very novel way to create a "non-skid" surface.
    Is a non-skid surface mandatory in pedals (like it is in some sanctioning racing organizations)?
    I have created a mandatory non-skid surface by spacing little weld nuggets over the pedal and sanding the tops on a belt sander, but your solution is definitely cl***ier.
  16. JamieUC
    JamieUC
    from Swansea UK
    Non skid is not a requirement but, don't want a foot slipping when I'm on the go pedal:D
  17. Little Terry
    Little Terry
    [emoji1362][emoji1362][emoji1362]
    JamieUC likes this.
  18. JamieUC
    JamieUC
    from Swansea UK
    Started work on the fuel tank this weekend, got my son to calculate the area and it should be between 3 1/2 to 4 gallon, hopefully that will be big enough. Tank103.jpg
    Still got to fit a filler, breather and fuel line fittings, and finish the welding.
    There will be a water tank in front of this, similar design but bigger that will feed a heat exchanger, for engine cooling, its all gonna be some what of a squeeze!
    Bandit Billy, das858, 35cab and 9 others like this.
  19. 26 T Ford RPU
    26 T Ford RPU
    Very nice tank in a tank.:cool: JW
  20. JamieUC
    JamieUC
    from Swansea UK
    Bit more progress on the tanks in a tank:rolleyes: rear one if fuel and the front is a water tank for engine cooling.
    I should have taken a couple of pictures of the top skins being welded on as there was quite a combination or ratchet straps and clamps involved to get the curves to sit right.
    The filler cap is from an aircraft surplus place in the States, got another one to go in the water/ice tank.
    Tank104.jpg Turning up some coolant pipe, cutting barb ends on 1 5/8" pipe, this will supply cold water to the heat exchanger.
  21. 26 T Ford RPU
    26 T Ford RPU
    You continually impress me with what you make on this.:cool::cool: JW
    loudbang, JamieUC and The 39 guy like this.
  22. JamieUC
    JamieUC
    from Swansea UK
    Thanks JW and like wise I'm enjoying and being inspired by your build thread.:cool:
    Would be great to meet at Bonniville one day when both our tanks are finished. Would be a bit of a dream for me to get myself and tank to the States but as you say "Dreams dont come true unless you dream them"
  23. 26 T Ford RPU
    26 T Ford RPU
    That would be a blast!:cool::cool::):)JW
  24. das858
    das858
    Those tanks are a work of art ! This is one of the best belly tanks ever .
  25. JamieUC
    JamieUC
    from Swansea UK
    Not posted for a couple of weeks but have been busy on the tank, beeen working on the heat exchanger, basically a radiator in a water box.
    Radiator was an ebay puchase but UK made, had to weld on some longer hose conections, gave it a quick pressure test and then welded up the box around it.
    Still got to finish welding then give it all a pressure test.
    Also welded in some **** protection :eek:, 3mm steel plate, and some seatbelt anchor point for the harness.
    And finally a rear crossmember for the gearbox, a job I've been avoiding as it took a bit of head scratching.
    So I've still got a few little jobs to do on the ch***is but about ready to strip it down, finish all the welding and get some paint on it. I've had permission from the good lady wife to sneek off the the workshop for a couple of days during the Christmas break and get the ch***is is the spray booth.
    badshifter, brEad, 40two and 12 others like this.
  26. j hansen
    j hansen
    Nice job!
  27. 26 T Ford RPU
    26 T Ford RPU
    All looking good, Jamie.:cool::cool: JW
  28. saltflats
    saltflats
    from Missouri
    Interesting idea with the radiator/coolant tank.
  29. brady1929
    brady1929
    Wow, amazing work.
    JamieUC likes this.
  30. JamieUC
    JamieUC
    from Swansea UK
    Its a common idea in land speed racing but not something I've done before, and to be honest there's quite a bit of guess work in this cooling system, definitely a case of set it up see how it performs and make changes if necessary.
    The 39 guy and 26 T Ford RPU like this.
