Technical Suggestions for replacing cheesy Recliner Handle on Glide seat?
Discussion in 'Traditional Hot Rods' started by Detonator, Oct 17, 2021.
  1. Detonator
    Detonator
    from santa cruz
    I'm putting a Glide Engineering seat in my '35 Ford coupe. I needed a seat that would fold forward for rear access -- and the recliner feature sounded kinda comfy, too. I have a Bengles in my '29 and am very happy with it -- but Bengles had gone dark for awhile and I had to move on.
    The recliner handle on the side of the Glide is black plastic. It's really cheesy. The handle is splined and is held in place by a simple screw that's tapped into the splined post. Size-wise, it looks a LOT like the splines on 50's - 60's era window crank handles.
    Has anyone found a subs***ute for these plastic handles? Something chrome? Metal? And stylish? Thanks
    A Boner likes this.
  2. stanlow69
    stanlow69
    I have a customers 40 Ford Coupe in the shop now. I`ll see what I can dig up. I have a couple hundred handles in my stash.
    Tman likes this.
  3. Kiwi 4d
    Kiwi 4d
    Agreed @Detonator the glide release handle looks like it belongs on a Honda. We took ours off and put a pull release under the front edge of the seat .then made a new cover to hide the hinge mechanism , covered that in old leather . Deception complete. We cant recline ours in the 3W but i presume it still does recline.
    A Boner likes this.
  4. Many wagons of the 50's-70's have a splined chrome handle on the inside of the tailgate, most held in by a central screw, which look neat. Also, seat adjusters on 40's GM cars had a similar set-up.
  5. indyjps
    indyjps
    Can you measure shaft diameter and spline, comparison can be made to other things. The one on the seat might just be off a honda o_O
  6. Good idea Denny ;) you could grind the splined shaft square, and use a stock inside door handle couldn't ya? o_O
  7. For starters, you need to count the splines and measure the tooth diameter and minor diameter at the base of the teeth. I have one of those cheap, digital calipers and I find it handy to measure something with it just about every week. I saw sellers on the net and they mention size and tooth count, etc.
    I doubt the splined shaft is a one of a kind. There's bound to be a crossover from something. Besides car window and interior handles, a lot of vintage bathroom faucet handles were splined. Might be worth a try.
    Atwater Mike likes this.
  8. stanlow69
    stanlow69
    I bought about 100 matching used interior handles that are all the same style. Used. The splines fit. The interior door handle would work but is a bit big. The wing window crank is the right size wise but the knob would need to be trimmed down. The handles would need a hole drilled for the mounting screw.
  9. Detonator
    Detonator
    from santa cruz
    The diameter of the shaft is .453, there are 15 splines inside the handle itself.
  10. Detonator
    Detonator
    from santa cruz
    LOL. Great stash! Keep me posted (see diameter and splines above). Thanks!
  11. A Boner
    A Boner
    A rusty piece of bar stock would look better than what comes on a “Glide” seat!
    -Brent- and Tman like this.
  12. Atwater Mike
    Atwater Mike
    ...But it would have to be 'broached'! :D
  13. stanlow69
    stanlow69
    Read post 10.
  14. 40Standard
    40Standard
    from Indy
    still better than a wise guy seat
  15. stanlow69
    stanlow69
    Detonator likes this.
  16. Gotcha
  17. Kiwi 4d
    Kiwi 4d
    12E3BAA2-F32E-46D7-94DD-9A93512E8063.jpeg 66D57002-89BA-43BE-BB10-39EDEA42F485.jpeg 72584878-C148-4FAA-8C35-C08DC124CF2F.jpeg A glide seat, with the honda handle gone.
    Jrs50 and Jim Bouchard like this.
  18. A Boner
    A Boner
    Just weld on with arc welder!
