Technical 307 with 400 crank
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Oct 18, 2021.
  1. anyone build one?
    wondering why ?
    How might it run?
    Well There’s one sitting here now.
    I’ll probably open it up later this week to see what they did.
    Speed Gems and Deuces like this.
  2. Roothawg
    Roothawg
    It’s basically a 283 bore with a 3-3/4” stroke. Small bore long stroke. More of a cl*** engine for racing where a cubic inch requirement governs the total CID. What you have there is a 350. Long way around to get there.
    Deuces and Truckdoctor Andy like this.
  3. I read in an old "Hot Rod", about one of these being built. Maybe late '50's early '60's. .060 over 283 with a 3.75 stroke. 364 cubes. Was in a dragster, don't know what it ran, just remember thinking it was really fast. Of course, it did have a blower on it. Gene.
    jimmy six, Speed Gems, Deuces and 2 others like this.
  4. MeanGene427
    MeanGene427
    from Napa
    Sounds like something for a Street Stock type roundy-rounder cl*** requiring stock valve sizes, iron heads n intake etc. Folks would spend a lot blowing abrasives through heads n manifolds, and that long stroke would let it pull on the little carb a long time. Used to be fun to watch the Chebbelles and Torinos banging fenders, running on narrow recapped "cl***" tires on white spoke wheels
  5. oldiron 440
    oldiron 440
    Longer stroke would have more torque for getting off the corners, this from a drag racer but the bore makes power?
    Deuces likes this.
  6. Budget36
    Budget36
    Someone posted that article here a while back. Wild stuff from back in the day.
    jimmy six, alphabet soup and Deuces like this.
  7. Where did the 3.75" crank come from, I wonder?
    Deuces likes this.
  8. Budget36
    Budget36
    If old, weld journals and or offset grind.
  9. Roothawg
    Roothawg
    I was just basing off the fact that he said it was a 400 crank. If so, those are externally balanced.
    jimmy six and Deuces like this.
  10. Budget36
    Budget36
    Ya, I was thinking he was basing the question on before the 400 cranks were available.
    Anyways, be neat to see what’s inside the topic engine.
    Deuces likes this.
  11. Mr48chev
    400 aka 383 Chevy crank in a big journal small block isn't an issue you just have to follow standard procedure.
    The big issue might be pistons. Those might get expensive in comparison to what we know as standard stroke your 350 with a 400 crank pistons.
    Still to go to that added expense and work a guy would have to have a specific reason to do it. Fits a certain ***ociation's cl*** or possibly a low speed torque motor for offroad or other purposes.
    Deuces likes this.
  12. Deuces
    Deuces
    Regardless... I wanna see pictures....:);)
    Speed Gems and Budget36 like this.
  13. Speed Gems
    Speed Gems
    Me too! I did a search for 364 inch Chevy and didn't find anything.:(
  14. Roothawg
    Roothawg
    With a std bore it works out to 353.
  15. blue 49
    blue 49
    from Iowa
    I remember that someone made a 400 crank stroker kit for the 305 block. Supposed to have nearly as much torque as a 350 with not much more gas as a 305.
    Gary
    Deuces likes this.
  16. belair
    belair
    There was a thread some time ago about overbored 283 and custom made cranks back in the late 50's, early 60's. I think they made 352 cubic inches.
    Deuces likes this.
  17. 364.8393 @ .060 over in a 283. I really don't remember if the article was about the engine or the dragster. It was quite some time ago that I read it. It was in a group of old magazines I got from my uncle. Gene.
    Deuces, Speed Gems and belair like this.
  18. Speed Gems
    Speed Gems
    Deuces and belair like this.
  19. Last edited: Oct 18, 2021
    Deuces and Speed Gems like this.
  20. That combination also could have been inspired by a desire to use up a stack of random parts sitting in a garage floor.
    2Blue2, joel and Deuces like this.
  21. I’ve seen that happen but it takes custom pistons- pretty sure anyway
    Deuces likes this.
  22. MeanGene427
    MeanGene427
    from Napa
    Bigger bore lets you run bigger valves- but if your cl*** requires stock valve sizes, long stroke will let you pull on them longer- just a different way to get the charge
    Elcohaulic and Deuces like this.
  23. X-cpe
    X-cpe
    There has to be something else at play, other than stroke length. At any given RPM a stroke is going to take a set linear time to be completed. The longer the stroke, the faster the piston has to move to complete it. Does this create a stronger vacuum? Does the longer stroke allow a later closing of the intake valve or an earlier opening?
  24. jimmy six
    jimmy six
    A 283 with 4” bore and 3-1/2” crank was a 352”. GM made the 3.48 crank. A crank builder would never do it. Howard Johanson was building 352’s as soon as he could along with his aluminum heads in 1957. It was considered a “big” Chevrolet then.
    Tickety Boo and Deuces like this.
    I use these variable stroke rods.
    Makes a huge difference
  26. Deuces
    Deuces
    Too funny!....:D
    427 sleeper and anthony myrick like this.
  27. Deuces
    Deuces
    More dwell at TDC creates the torque....
  28. buick bill
    buick bill
    from yreka;ca
    i really need a set of those rods . anyone making them for a 235 ? but seriously. gota be easier to go to the casino or buy lottery tickets . return is more likely ?
    Deuces likes this.
  29. Roothawg
    Roothawg
    No offense intended Jimmy, but a 283 bore with a 3.50” stroke is 330 cid.
    Speed Gems likes this.
  30. 57 Fargo
    57 Fargo
    Can you elaborate on this?
    Longer stroke is what produces more torque, it’s a longer lever. Now more cylinder pressure will certainly do that as well. Is that the thought behind the longer tdc dwell? More time to build pressure?
    Deuces likes this.
