Hot Rods Yes it’s still Possible.
Discussion in 'The Hokey Ass Message Board' started by Mitchell Rish, Dec 5, 2020.
  1. Mitchell Rish
    Mitchell Rish
    from Houston MS
    What is the little short grey cap? Vent? I am going to try and put it half above and half below (flange the opening and flanges are already on the cell - mount that to the frame. ) . Will approach the filler neck exactly as you did.
    What sender unit did you use ? Did it work with stock fuel gauge?
  2. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Got up this morning early. Cooler. Lots. This is at my house not at the River so this shop isn’t air conditioned. Lol
    Cut out the spare tire sump. Always hated the way they look anyways. Cleaned out and found some metal termites. And treated them with mechanics lindane ( ospho). Tends to kill and neutralize metal termites for ever. This is what I have in mind as far as the fuel cell. It has 2 plus inches of mounting bracket. And they can come off. Might put a inch or two below the floor and use a bolt in ring to locate and seal.
    enloe, 1Nimrod, chryslerfan55 and 4 others like this.
  3. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Got trunk and spare tire sump removed and panels welded in. No pics. Still waiting on my window felt so I can put in my new windows.
  4. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Frame base for fuel cell mounting. I’ll decide wether I’ll weld or bolt it in. It’s amazing to me how much weight /m*** the factory believed a stock floor board /trunk pan could support. Most hanging from below. Wow.
    enloe, 1Nimrod, chryslerfan55 and 3 others like this.
  5. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Straightened the fin trim on p***enger side. Before and after not perfect but acceptable considering the over all approach I want for it.
  6. catdad49
    catdad49
    Mitchell, love this project seeing as how I grew up with a ‘57. Dad bought a BelAir Sport Coupe (white over black) and kept it until 64. Almost got it back, sad story. Is that coral under that white?! I think Uncle Marion would love this project, Carp.
    1Nimrod, Thor1 and loudbang like this.
  7. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Check his page here on hamb. News posted. No it’s not good.
    1Nimrod and loudbang like this.
  8. manyolcars
    manyolcars
    whose page?
    chryslerfan55, loudbang and Blue One like this.
  9. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Sorry. The late Marion Fairchild. Mrs Joyce p***ed earlier this week.
    1Nimrod, chryslerfan55 and loudbang like this.
  10. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Catdad49. It was coral at one time. Here is tonight’s work. Managed to get both Trim sets on the fins pretty much straightened out. The gas door had to be removed to be straightened. They are not perfect but they will work and man have you priced them lately. 94E529A9-E80A-4F32-9D66-1080AB163401.jpeg 33EB471A-5C92-4803-A265-441F3BAA4743.jpeg
  11. catdad49
    catdad49
    Coming along nicely, the car looks really solid.
  12. Mitchell Rish
    Mitchell Rish
    from Houston MS
    In the morning light.
    enloe, 1Nimrod, chryslerfan55 and 6 others like this.
  13. wheeldog57
    wheeldog57
    Nice work, it is difficult to not overwork that trim
    enloe, 1Nimrod and loudbang like this.
  14. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I used an old upholstery hammer that I glued a bit of leather to. Use a wooded block as an anvil. Mulberry / Bodock to be exact. Grind/ file to shape and go very slowly. Machine key stock with a filed radius is almost a perfect match for the center ridge. I spent all total probobly 10 hours and the fuel door was the worst of it. Sweat and blood are cheap. lol
    Also getting the fin/trim on and off with out messing them up isn't nearly as simple as you think. Gently by 1/2.
  15. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Got door gaps cleaned up a little. Also got the seam sealed above the quarter window.
    enloe, 1Nimrod, chryslerfan55 and 7 others like this.
  16. GlassThamesDoug
    GlassThamesDoug
    57 Looking good Mitch.
  17. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Ordered headliner and windlace yesterday. When I got a hold of the 654 interior code man what a shock. What I have been calling ok’d faded black is actually old fade charcoal. Had a Off white headliner and a taop wind lace. Some hade the dash insert painted other didn’t. It actually doesn’t look bad a all. Probobly try to copy as much as will clean up the rest will be as I can match. Don’t want it to nice. I am not using factory seats so we will see.my cash is total charcoal no insert. The out side was coral with a white top. Weird.
    Anyone use the series 90 buckets that speedway /jegs/summit is selling. If there is anything to them at all that’s hard to beat. Won’t have a back seat so no worries.
    enloe, 1Nimrod, tomkelly88 and 4 others like this.
  18. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Ok I am not posting pics but I will tell you that the p***enger side cable of the wipers forms a figure 8. It is not like the driver side that runs parallel. Pulled heater ducts to clean out and reinstall. Heater motor actually runs as did the wiper motor. Kinda impressed. Probobly put a heater core in now/or at least have this one checked.
    1Nimrod, Squablow, Thor1 and 2 others like this.
  19. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Cleaned up /and pressure tested the core. Coat of paint re***emble and reinstall.
    enloe, 1Nimrod, chryslerfan55 and 8 others like this.
  20. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Major score. A friend of mine that has a 57 gave me a bel air bumper/back up light delet plates/and a champ 500 steering wheel. The driver side front corner is better than mine and between the two I can make a decent bumper and not look new or bad. I also got the brackets. All of them including the one that bolt to the bottom of the front fenders. Got some bumper guards as well. They along with the back set could be fixed and plated. They will be available soon cheap. Real cheap I am not a fan of them. None of the rubber snubbers will be used either. I like the delete plates front and rear.
    Was a good day. A thanks to Stevie
  21. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Making up a rust removing paste and see what it will do. Can’t hurt.
  22. Mitchell Rish
    Mitchell Rish
    from Houston MS
    The driver side front bumper section. Not bad for aluminum dust /acetic acid /salt and flower. Old fashion small wool buffing pad and a very old craftsman drill. Then some old fashion turtle wax chrome polish got all the rust spots gone. Scratches cleaned up but they are still there. And that’s OK. It will do nicely. Now got to make the rest Match
    1Nimrod, AHotRod, catdad49 and 7 others like this.
  23. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Vent window regulator had to be retoothed so to speak. Took a chisel and a file and straightened them out. Back together and some grease and we are in business. Windows /vent window felt /channel are in and functional. Now p***enger side
    enloe, 1Nimrod, catdad49 and 5 others like this.
  24. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Window channels/setting windows /felt etc.
    Actually finished everything up on both sides after we got glide builds set up for the race cars. Came back and finished. Will post tomorrow.
    enloe, 1Nimrod, kidcampbell71 and 3 others like this.
  25. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Makes the car look totally different. I went with the clear /not tinted because the rest is original and will stay that way. I do have a quarter window with a small crack but only one side. It will be left alone for now. Have the felt and track stuff would be nice to find a used quarter but will see.
    For those that think your upholstery guy/girl is ripping you don’t get on it. If you do it yourself and do it right you will learn just like with metal fab if you rush it you will screw it up. A good rule of thumb. Take materials double it and add 15 to 20 percent. Unless you are dealing with a situation that requires a stupid tax. I’ll explain that at a later time.
    Remember this car will not be restored. It is not a rat rod. It will be a flash of my memory from high school with a little more engine / disc brakes. A time that as I thought I was on the outside looking in at times it’s was still some of the best of times. And I have the friend ships memories /and wrecks to prove it. Gotta love it
  26. Squablow
    Squablow
    Both of my rear quarter windows are cracked and also have some delamination bubbles in them but the windows are so cool I couldn't bear to replace them. Your new gl*** looks good. All those felt sweeps and channels are a real bear, especially since the new ones don't come with the factory clips installed (at least the ones I got didn't, just generic sticks I had to bend up myself) so it can be a ***** to get them in there snug. But it's a must-have thing, nothing ruins gl*** like ****py window channels with all of the felt torn out.
    1Nimrod, chryslerfan55, brEad and 3 others like this.
  27. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I used repops out of AR. They had all the factory clips etc. Still a lot of work
    1Nimrod, loudbang and Thor1 like this.
  28. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Picked this up today.friend had it sitting on a shelf. He’s Not going to use and I figure will need a refresh. 750 dbl pumper. Used them on just about everything. Even a 292 six and it liked it. Should do well on the 57.
  29. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Pulling out /dis***embling /re***embling of gauge cluster. Will also let me clean up the dash /paint as needed. This is a clean a fix what needs but don’t go over board deal. And I’d really like to have a discussion with the engineer that put the two long studs in the bottom of the cluster.
    Pulled and test fitted the steering wheel/ they said I’d have to to get the cluster out any way. Luck has it that the turn signal ***embly appears to be perfect. Gonna touch up the top of the dash. The rest will be left alone.
    enloe, 1Nimrod, WC145 and 6 others like this.
  30. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Headliner and wind lace came in. Looks weird until you look up interior code 654 for a 57 210 sedan. Doesn’t look bad once it’s all together close enough to compare and contrast.
    Dash cluster cleaned /speedometer lubed /painted and even took an orange paint marker to all the needles. Will touch up dash and column and re***emble.
    enloe, 1Nimrod, catdad49 and 8 others like this.
