Technical Which current production rams horn manifolds fit tightest?
Discussion in 'The Hokey Ass Message Board' started by SDS, Oct 19, 2021.
  1. SDS
    SDS
    Got a set of ram horn exhaust manifolds from Summit Racing - they are super nice for the $, but do not at all hug the block - the collector basically hangs down vertically from the head versus angled inward along the side of the block. This puts the exhaust pipe in the same place that my steering sfat/s will be.
    I'm looking for an alternative (no "tru-ram" types!) to these in a stock appearing 'Corvette" style manifold - does anyone know of any currently available re-pop manifolds that hug the block tight/er?
    Thanks
    Deuces likes this.
  2. MMM1693
    MMM1693
    I believe all ram horns stock or repops in corvette style dump straight down
    Max Gearhead and Deuces like this.
  3. 31Apickup
    31Apickup
    They all go straight down. The other option is to run block hugger headers. I was going to run rams horn, had the same issue you have plus the set I have are the smaller outlet ones. I had a set of block hugger headers I originally bought for an OT project which I sold a while back, they clear great. Not as vintage looking but I’m going to run full hood. 1CFA3D2E-84D4-4222-BC30-25269E7F691B.jpeg
    Deuces likes this.
  4. 31Apickup
    31Apickup
    I need to take a photo with the steering box in place
  5. SDS
    SDS
    I've definitely seen some originals that hug the block quite tightly (compared to these). I had a set of cast iron re-pops that I bought from a vendor at the long beach swap meet back in 2002 ($245) and they were super nice - they fit much tighter than the summit ones, but I don't have a clue who made them.
  6. 34Phil
    34Phil
    Have you considered angle mill and spot face the bolt holes?
  7. That was mentioned in his other thread also
  8. KevKo
    KevKo
    from Motown
    Some Chevy Ram Horns dump on a rearward angle. And Williams makes a set of nice looking rear dump cast iron manifolds.
    jimmy six likes this.
  9. I would either pic the rams horns I liked OR do Fentons (much cooler IMHO) and as mentioned build the steering around them.
  10. OR 55 Chevy manifolds
  11. X-cpe
    X-cpe
    Angle milling the heads might also buy you a fraction.
  12. Taboo56Chevy
    Taboo56Chevy
    Chevy pickups had a ram horn the angled rearward, but not in towards the block
  13. SDS
    SDS
    I have considered this too...the bolt holes are pretty tight, would have to bore those out at the corresponding angle as well. Will post photos of the ones I had on it 18 years ago.
  14. oldsman41
    oldsman41
    When I get into headers in a car that I know will have steering interference I just build my own,way cheaper in the long run IMO
    RMR&C and Tman like this.
  15. blue 49
    blue 49
    from Iowa
    I run one like the lower one on my '36 Ford pickup. They do offset inward just enough for my steering shaft, but not all builds are the same.
    Gary
  16. A guy can also offset the engine slightly to the p***enger side to gain clearance
    gimpyshotrods, ottoman and X-cpe like this.
  17. tim troutman
    tim troutman
    Sanderson cast iron headers fit tight but may not be the look you are after. bought a car that had block huggers on it . the steering was at to much angle for the ujoints and they were rusted out . wanted to put ram horns on but they would not fit . the sandersons were the solution to make it all work for me.
  18. pprather
    pprather
  19. Bob Lowry
    Bob Lowry
    Yet, another offering..Williams Manifolds....
  20. 1985 Chevy C-10, 350 engine, exhaust manifold, would this work? E78B8D00-BAB4-49E0-88FD-233A8FC7B5E8.png
  21. SDS
    SDS
    Thanks for all of the great input, guys. I didn't really want to use tru-rams, but they may be the only option.
    Steering column should be here any day, I'm going to mock-up the column, drop, shaft and u-joints (being conscious of exhaust clearance) - then decide if I have to use different manifolds.
  22. figure8
    figure8
    I'm using some I bought from Speedway. Hug the block like a block hugger header. But I think the are tru-ram. I would use them again.
    SDS likes this.
  23. carpok
    carpok
    from Indy
    These do tilt into the pan some there 2.5”bought on the online site.
  24. SDS
    SDS
    That looks pretty tight - 2 questions:
    1) what's the gap between the back side of the collector and the block
    2) where'd you get them, Speedway? Cost?
  25. carpok
    carpok
    from Indy
    The three bolt flange is around 1/2” from the block right at where the head sits on the block.
    eBay
  26. Joe Blow
    Joe Blow
    I posted this the other day on this thread and deleted it, when I reread your initial post...."no tru-ram types". Since you might be rethinking these I'll re-post for your consideration.
    3wLarry's (RIP) old 32 Coupe.
    -Brent- and Budget36 like this.
  27. SDS
    SDS
    Thanks...lots of ram's horns on eBay...Have a link to that vendor or eBay page?
  28. alchemy
    alchemy
    I bought a vintage pair of Chevy rams horns last weekend for $10 at a swap meet. Just in case I ever decide to (heaven forbid) build a car with a small block. They had straight and angled in the pile, and I picked the pair with the least warts. The left one swings rearward and slightly inward. They probably aren’t pre-1965, but they are traditional.
    Bob Lowry likes this.
  29. carpok
    carpok
    from Indy
