Hot Rods Higher frontend stance
Discussion in 'The Hokey Ass Message Board' started by Doug Sonnenberg, Oct 19, 2021.
  1. Doug Sonnenberg
    Doug Sonnenberg
    Ok has anyone ever installed a block between the leaf spring and the crossmember to get a higher front stance? Pics? 20211019_173752.jpg
    Stogy likes this.
  2. Pete Eastwood
    Pete Eastwood
    from california
    Or you could use a stock eye spring .
    If you want to go higher use a stock ( non drop ) axle .
  3. squirrel
    ...instead of finding a stock axle? (not dropped)
    Hnstray and Stogy like this.
  4. Stogy
    Stogy
    They do make those in varied thicknesses and I've thought about it as my spring is very close to the frame without a notch and an un-dropped axle...Your situation is different and a couple of our veteran Hotrod membership have chimed in with very helpful details about you situation...
    Hnstray and Doug Sonnenberg like this.
  5. Doug Sonnenberg
    Doug Sonnenberg
    Your suggesting another leaf spring where the eye is in a different/stock location?
    Stogy likes this.
  6. adam401
    adam401
    My car currently has a block between the spring and rear crossmember. It has a hole to accept the locating pin on the spring and also a locating pin to center it in the crossmember. Its fine.
    Edit: I would say however if I were in the mockup stage of a build that wouldn't be my go to solution. I did mine after the car was togther, the suspension had settled a little more than I anticipated and i didnt like how it looked. When I put a different rear in this winter I will locate the spring perches where the spacer block will no longer be needed.
    Stogy likes this.
  7. If the picture you posted is yours you have a reversed eye spring which is 1” lower and a dropped axle which is 2” or so lower than stock. Go back to stock style stuff and you will raise it 3”? Not what you asked but same result?
    Doug Sonnenberg and Stogy like this.
  8. Doug Sonnenberg
    Doug Sonnenberg
    Did it make a big difference in handling? Im only thinking of maybe an 1" block, or maybe putting an extra leaf in. I mounted my crossmember lower between the frame rails so that gave me a cpl extra inches in height
    Stogy likes this.
  9. Pete Eastwood
    Pete Eastwood
    from california
    Yes , a stock Ford spring has the eye rolled the other way .
    The photo is not a Ford spring , but it shows what I'm saying .
  10. Doug Sonnenberg
    Doug Sonnenberg
    Right on. Ill just head to my spring shop and get them to make one up for me.
    Stogy likes this.
  11. Stogy
    Stogy
    You have no weight to see ride height but if what you see now is where you want it adding a spring with an original eye and perhaps a spacer might achieve your preferred ride height...it's truly a juggling act...a frame notch is another option...and of course the other details mentioned...
    I have seen Builders clamp down and load the suspension to ride height based on experience to verify it meets the correct desired height and look..
    Ch***is setup another walk in the shoes of those that possess the skills...
  12. X38
    X38
    Exactly! It might seem captain obvious, but when seeking a higher stance, don't use a dropped axle.
    Edit:
    Hang on, I just twigged...this is going in a 1929 Chrysler roadster?
    Stogy likes this.
  13. Stogy
    Stogy
    Perhaps the happy medium will require the dropped axle...
    With my limited knowledge of the big picture the shackles will be at a 45° angle when at proper ride height...others will confirm...
  14. Doug Sonnenberg
    Doug Sonnenberg
    Yup i hear ya. Its been fun building this roadster. Ya i dont want much more height but i do want a bit more height knowing that it will drop once the weight is on. I plan on setting it now then loading a bunch of weight on it to see how far it drops.. thanks for the input
    Stogy likes this.
  15. Doug Sonnenberg
    Doug Sonnenberg
    Yes im building a 29 chrysler roadster
    Stogy likes this.
  16. jimmy six
    jimmy six
    I’d re-arch the main leaf to save some $$$ on buying another spring …. But I’m cheap. It’s not rocket science.
  17. Stogy
    Stogy
    If one farms this out is it still a general mod for spring shops and if you have a multi leave spring is the uppermost leave that's actually the shortest the one your referencing?
  18. wvenfield
    wvenfield
    It isn't rocket science and I re arched my springs but after watching a spring shop do it and hearing the price, I'll never do a set myself again. LOL
    jimmy six likes this.
  19. Hot Rods Ta Hell
    Hot Rods Ta Hell
    You're way ahead of yourself. You may go to all the labor and expense of reversing that main leaf to find the car now sits an inch too high when you're through final ***embly.
    Get all the weight on the car ( body, engine, radiator, etc) for your final mock ***embly, then fine tune it an inch or two-IF you even need to.
    When you blow it all apart for paint, you can then send out for spring work, etc prior to final ***embly.
    kadillackid, Doug Sonnenberg and X38 like this.
  20. jimmy six
    jimmy six
    Like I said. I’m cheap and have plenty of ear plugs..
    wvenfield likes this.
