Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    don't tell anybody but I did drive around the block,
    it is quite quiet compared to the '27
    tune is in order, driver side exhaust is running hotter than p***enger side,
    I will need to go through carburetors again,
    I suspect throttle plates not closing 100% in secondaries..
    and maybe float levels..
    I don't know but it's a place to start.
    X38, Moriarity, patmanta and 14 others like this.
  2. Tim
    Tim
    from KCMO
    Imagine how much you’d get done if you didn’t have that huge lawn to take care of lol
    kidcampbell71, loudbang and Paul like this.
  3. Stogy
    Stogy
    'The Ole' is Rockin' and Rollin'
    Just awesome @Paul
    @Tim in Suburbia every bit of real estate that distances yourself from neighbors is worth its weight in gold...
  4. kidcampbell71
    kidcampbell71
    Damn.
    .. off topic maybe .. but dig the house ! And that concrete, man !!
    Oh yeah. Yeah, yeah .. car is cool, too. Whatevs' !! :D
    loudbang, Paul and Stogy like this.
  5. Paul
    Paul
    Editor
    We live in an older part of town, neighbors on all sides, but it's a double lot with a small yard in front of the house and a little bigger secluded yard behind the shop.
    It ain't much but we like it.
    bchctybob, brEad, bct and 6 others like this.
  6. Tim
    Tim
    from KCMO
    I just thought it was very car guy to have the entire back yard paved. I can dig it :)
    Just Gary, Stogy, brEad and 3 others like this.
  7. Paul
    Paul
    Editor
    Blister to clear sender
    PXL_20211024_192537887.jpg PXL_20211024_185926004.jpg PXL_20211024_192718627~2.jpg PXL_20211024_185947983.jpg PXL_20211024_194153160.jpg PXL_20211024_194207236.jpg PXL_20211024_195322814.jpg PXL_20211024_200708751.jpg PXL_20211024_220115660~2.jpg
    AHotRod, OFT, Stogy and 13 others like this.
  8. Dave G in Gansevoort
    from Upstate NY
  9. Paul
    Paul
    Editor
    Thanks Dave.
    Some of the updates posted here seem a bit minor to be included in a build thread.
    I went through the carbs, they all looked fine, all p***ages clear, floats levels good, one float drop was about 1/8" high, fixed that. All gaskets correct.
    Waiting for it to stop raining to test fire.
    Got yom plates attached to ***le, so it's registered.
    And scotch brighted heat blueing off headers so I can better gauge exhaust heat when I do fire it up.
    AHotRod, rod1, bchctybob and 5 others like this.
  10. Dave G in Gansevoort
    from Upstate NY
    I think that showing the little things that need to get done is valid. I'm constantly amazed at what seems to be a nothing task actually taking more time than some of the more major parts of building a car, or anything else for that matter. Get me talking, and I can tell you about all of the things that I have worked on over the years where that has been the case.
    So keep those little tasks as well as your major accomplishments coming!
    AHotRod, High test 63, OFT and 7 others like this.
  11. Paul
    Paul
    Editor
    Stripped the 100 year old paint off the turtle deck, paint was too far gone to save but the steel underneath is as clean and fresh as yesterday's.
    PXL_20211028_230326041.jpg PXL_20211028_230314184.jpg PXL_20211028_230241937.jpg
  12. Paul
    Paul
    Editor
    Satin black to seal it and rub with grey scotch brite to take some of the shine out of it.
  13. 64 DODGE 440
    64 DODGE 440
    from so cal
    Really looks like a proper hotrod.
    Stogy, bct, The 39 guy and 1 other person like this.
  14. Paul
    Paul
    Editor
    Started wiring the dash yesterday.
    I have plenty of proper gauge wire, all new left over from previous projects
    but color choices are limited.
    RodStRace, patmanta, brEad and 10 others like this.
  15. Dave G in Gansevoort
    from Upstate NY
    Wow! Look at the spaghetti! I don't know about anyone else, but I go thru a couple of bundles of tywraps every time I wire something. Most of them end up on the floor cut off as I keep adding/changing/revising the harness. You should see my trailer, and it's not even complicated!
    brEad, loudbang and Paul like this.
  16. Paul
    Paul
    Editor
    Fuse panel and ballast resistor mounted and dash ready to go back in.
  17. X38
    X38
    Yes, I have been following this build thread. ;):)
    Paul likes this.
  18. The 39 guy
    The 39 guy
    Nice and tidy!
    Paul and loudbang like this.
  19. Dave G in Gansevoort
    from Upstate NY
    If you are ever in upstate New York, I want you to stop by and wire my project for me. Mine never look good...
    vtwhead, loudbang and Paul like this.
  20. Paul
    Paul
    Editor
    Tail lights I ordered came today,
    Cheap reproduction Chevy style.. hopefully I can find some heavier bezels to fit because these are about as thin as tin foil..
    Oh well,
    I put blue tape around where they might fit, scribbled a bunch and drilled some holes and stuck them in place.
    Also mounted an NOS Hollywood tag light and YOM plate.
    Location will do but it will all need a little fine tuning to make it done.
    PXL_20211108_210602795.jpg PXL_20211108_224609906.jpg PXL_20211108_224629175.jpg
  21. Paul
    Paul
    Editor
    Also begining to hate the tail pipes..
    Atwater Mike, brEad and loudbang like this.
  22. 64 DODGE 440
    64 DODGE 440
    from so cal
    Liking that taillight treatment a lot. Looks natural.
    Don't sweat the tailpipes, that's an easy fix.
    loudbang, Stogy and Paul like this.
  23. Paul
    Paul
    Editor
    Yeah I know, not a big deal.
    Actually I'm doing ok on this build, only having to redo half of it so far, used to be everything would get redone at least once to get it where I could accept it.
    I don't know if I'm getting better at getting it right the first time or if my standards are slipping.
    Tim, brEad, OFT and 6 others like this.
  24. rob-redm
    rob-redm
    maybe bend them straight ? looks great Paul
  25. vtwhead
    vtwhead
    LOL, Paul I doubt seriously if your standards are slipping even a little bit. The one thing that I struggle with in my builds is finishing something only later realizing I need to change it. I have always maintained that it is just part and parcel of design and build. Moreover, in my particular case, it may be that I am impatient and often don't look forward as often as I should.
  26. Paul
    Paul
    Editor
    Dash wires starting to fall into place..
    AHotRod, rod1, kidcampbell71 and 12 others like this.
  27. Paul
    Paul
    Editor
    drew up a wiring diagram.. hope it doesn't have too many bugs..
    winr, AHotRod, brEad and 13 others like this.
  28. charleyw
    charleyw
  29. Paul
    Paul
    Editor
    Yes, Auto CAD 2015
    Atwater Mike, OFT, Stogy and 3 others like this.
  30. Just checking in on the progress.
    Stogy, Paul and loudbang like this.
