Hot Rods Which bearing
Discussion in 'The Hokey Ass Message Board' started by Vern Lee, Oct 20, 2021.
  1. Vern Lee
    Vern Lee
    I'm putting 1940 rear brakes on my 31 Model a , getting ready to order new wheel bearings part # 68-1225 , the problem is I'm finding different sizes for the same part # , some say 2.840 O.D. others say 2.780 O.D. , I even found a 3rd. size , does anyone know which size I need ? The best brand or supplier to purchase from ?
    Vern
  2. Mr48chev
  3. Lloyd's paint & glass
    I'd mic what you have and go with that.
  4. Vern Lee
    Vern Lee
    Sounds like a plan , thanks
  5. 42merc
    42merc
    The '40 hubs take the larger OD bearing.
    The ID is the same '28-"48.
    leadsled likes this.
  6. leadsled
    leadsled
    Unfortunately it appears Ford stopped using Timkens after 32 and went to them in 1 ton trucks in 44.
    Anyway. The Model A & B used bearing 28156 (Bore 1.574") the pinion cone was 28314XD and other cones were 28317 (OD 3.151")
    cone=outer race
  7. leadsled
    leadsled
    I can cross some other bearing part numbers, but I need the number on the actual bearing,
  8. Vern Lee
    Vern Lee
    I don't have the actual bearing , all I have is the # 68-1225 , which is supposed to be the correct # for 1940 rear hub .
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    In the early 80's as a cabinet maker a woman came in (small work welcomed) with a piece of wood to be cut. When I asked how long she presented me with a piece of yarn she had cut to length.
    Max Gearhead and BJR like this.
  10. rusty valley
    rusty valley
    Unless your old bearings are really shot, I would clean them up and use them. Some of the new ones are too soft, and the cages have been known to fall apart too
  11. Vern Lee
    Vern Lee
    I have no old bearings , That is why I'm inquiring about what size new bearings I would need . and where would be the best place to buy them .
  12. Lloyd's paint & glass
    Oh I wasn't being a smart ***, I wasn't aware you didn't have anything to go on. You can't mic the inside diameter of the axle tube? I guess I'm not understanding what you've got going on. I'll slowly back away :D ms-MTbgeS.gif
    Johnny Gee likes this.
  13. Vern Lee
    Vern Lee
    No I didn't take it that way , No problem here , I have new Model a bearings for rear hubs but I guess their not same as the 40 hubs I'm putting on the A converting to hydraulic , I'll check all dimensions tomorrow , and figure out exactly what it is I need for the conversion.
    Lloyd's paint & glass likes this.
  14. Vern Lee
    Vern Lee
    Ordered new bearings today , I have another question about the 1940 backing plates , toward the top of the plates there is two disc on the inside toward the top and on the back side two bolts hold these disc in place , there is also two heavy duty springs on the bolts , what are these ? and what is their function . The brake shoes cover these disc .
  15. Vern Lee
    Vern Lee
    this is what I'm talking about
  16. BJR
    BJR
    Which answers the age old question....."how long is a piece of string".
  17. 42merc
    42merc
    The 11/16" "bolts" & the cams inside are the upper brake shoe adjusters.
    At the bottom, outside of the plate are the lower brake shoe adjusters.
    There is a bunch of info available on "how to" adjust the shoes.
  18. Vern Lee
    Vern Lee
    42 merc ,Thank you I appreciate it.
