Hot Rods 1932 Ford Gas Tank Question
Discussion in 'The Hokey Ass Message Board' started by LM14, Oct 17, 2017.
  1. LM14
    LM14
    from Iowa
    Looking for advise from those that have been there, done that. Shopping for a gas tank. Looking for stock looks. 99% sure it will be a normal steel tank.
    Searched and found Vintiques had some issues with holes not lining up and some clearance issues around the spreader bolts and the filler not being in the correct location.
    Didn't see anything about Tanks, tanks.
    I'm leaning towards a Tanks tank. Can anyone post pics of an 11 gallon vs 14 gallon in the car? Have been told by some that a 14 gallon looks like a full diaper on a baby. I can see how that could happen. I would like the extra capacity of the 14 gallon but not if it looks like **** (no pun intended).
    Also, I have seen "tank supports for stock style 32 installations" that look like wedges. What's the deal there?
    Good/bad on other brands or experiences? Lead me!
    Thanks in advance,
    SPark
  2. 325w
    325w
    Been using a Tanks for close to 20 years. Only isssue is gas splashing out around cap. That happens on real Ford tanks also. Just don't fill it full. They make a tank with a screw on cap. No splash issue on it. You will have to do a bit of fitting.
    lothiandon1940 likes this.
  3. swifty
    swifty
    Have had 2 Vintique tanks and had problems with mounting holes not matching original rails. Is this for a fully fendered car or a hiboy as the Tanks unit does not have the triangular bracket which comes from the sides of the mounting flange up onto the top of the tank same as the original. Would be visible on a hiboy and not on fully fendered. That's just if your a Deuce snob.
  4. alchemy
    alchemy
    Tanks company tanks look like real 32's, and be sure to buy the triangle braces and install those as well for more authenticity. Make sure to use a good cap and you shouldn't have any leaking problem. But then again, no tank should leak at the cap.
  5. LM14
    LM14
    from Iowa
    Going to be a hiboy. Anyone have pics of the triangle braces in place? I’ve never noticed them before but I haven’t really crawled around on any 32’s.
    Thanks,
    SPark
  6. HOTRODPRIMER
    HOTRODPRIMER
    I have use 4 Vintique tanks and misalignment was apparent on only one of them,I honestly believe it was the frame that may have been hit at one time or the other,
    I just chased the holes with a drill bit and everything lined up perfectly,
    Regardless of who's tank you use don't use the bigger capacity tank,they end up looking like a soggy baby diaper. HRP
    Andy likes this.
  7. alchemy
    alchemy
    Here's an original tank with the side braces.
    I don't know why they don't just install them at the factory? The originals are soldered on.
    lothiandon1940, lurker mick and LM14 like this.
  8. cheap-n-dirty
    cheap-n-dirty
    here is a Tanks 14 gal.
  9. dirt car
    dirt car
    from nebraska
    WENT WITH A SUMMIT 14 GAL. TANK , & WHILE IT WAS DEEPER IT LOOKED AS ORIGINAL BUT LACKED THE BOTTOM DRAIN DEPRESSION.
  10. Deuce Daddy Don
    Deuce Daddy Don
    Simple solution for "Splashing" around the filler & cap.----Use round gas proof fiber made anti spill elements that float around by filler preventing "Slosh" in hard curves, etc.----Try your friendly Harley dealer.
  11. Kiwi 4d
    Kiwi 4d
    The gas cap in Alchemys post is the one to use ( maybe a vintique) they dont leak. Had a plain cap that was an atrocious leaker, swap it out for the V8 one and never spilled a drop.
  12. LM14
    LM14
    from Iowa
    Once again, thanks to the HAMB for all the info.
    Looks like a Tanks 11 gallon with side braces is in my near future! Have a friend with an old school radiator shop that says he will solder the tank braces in place if I get them fitting nice first.
    Thanks all!
    SPark
  13. DDDenny
    Does your ch***is builder install the doubler plates that go between the frame rails and spreader bar ends, also, the spreader bars come in different lengths, a slight difference can make getting gas tank mounting holes to align with frame holes.
  14. I just installed a 13 1/2 gal Tanks in my full fender Tudor with bumpers and cannot see any big problem with it. Now on my high boy I used your standard 11 gal tank. The big tank on a highboy does look to big.
  15. Bandit Billy
    Bandit Billy
    I bought the 32 tank form TanksInc for my 34 cuz I liked the looks of it better on my fenderless car. I used the big capacity tank cuz I had to hack a notch in it to clear my QC. It looks tidy and lost people would never notice which is what I strive for. I am very pleased with the finished product
  16. LM14
    LM14
    from Iowa
    I will check on this. It's a Pete and Jake's ch***is with their spreader bar setup. All coming right from them. Figured that would cut down on issues with holes lining up, width differences, etc.
    SPark
  17. rusty rocket
    rusty rocket
    This is the big one. Doesnt look like a full diaper to me. IMG_0761.JPG DSC02835.JPG
    bct likes this.
  18. LM14
    LM14
    from Iowa
    Decided on a Tanks 11 gallon and got the gussets, too. Thanks for the feedback!
    SPark
    23439272_1987534784837659_2041466032_n.jpg 23416047_1987534788170992_710641504_n.jpg
    Bandit Billy, HemiDeuce and bct like this.
  19. 32owner
    32owner
    my tank is an original I think but I only have one hole someone made a pickup tube and that is in the hole does and original send have both on the same unit so it only has one hole. it had no sending unit and I keep running out of gas time to fix. any one know whats up with my tank
  20. brady1929
    brady1929
    Great info here.
  21. Ilari
    Ilari
    I have a Vintique tank and the holes are not lining up. Also the filler neck is too close to the body. How close it should be? I don’t have a spreader bar yet, I will make it from the scratch.
  22. Ilari
    Ilari
    Did you modify the holes in the tank or in the frame?
