Technical Is my setup strong enough? Cowl Steering Question
Discussion in 'Traditional Hot Rods' started by c6matt, Oct 23, 2021.
  1. oldsman41
    oldsman41
    Looks pretty but I wouldn’t trust my life with it
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    I haven't seen a picture of the whole car yet, so I will ask, does it have wishbones split or otherwise, hair pins or 4 bars? There is no such thing as correct geometry for cowl steering with anything but 4 bars. I am not trying to be an ***hole, just want you to have a safe car. People weld up holes in sheet metal every day.......
  3. Blues4U
    Blues4U
    from So Cal
    I was going to post the same thought, if the hole in the cowl is holding you back, patch it.
  4. Mom.... Lloyd and Vandy are *****-fighting again!
  5. HotRod33
    HotRod33
    Rolling Bones builds a lot of cars with cowl steering and split wishbones....and they get driven... Strengthen your steering box mount... Put a strong pitman arm on it and drive it.... It's your car and as usual guys can't answer a question here on the hamb without trying to tell you what to do...
  6. 282doorUK
    282doorUK
    Aside from the br*** issue, am I the only one to think that the keyway is so badly hand formed by file that the key isn't fully home, which means that there is air between the shaft and arm to the left of the key in this pic?
    Also, is there some porosity in the bolt area, sure looks like it to me.
    Happy to be proved wrong on this.
  7. nochop
    nochop
    from norcal
    And plumbing
  8. Very spindly arm, build a new one
    HotRod33 likes this.
  9. I'm kind of amazed the damn arm hasn't broken yet -- bet it wouldn't last long with me at the wheel. Having anything br*** or cast br*** anyplace in the steering or suspension of a car is about the worst idea I can imagine. You've already acknowledged you're making changes - exactly the right thing to do.
    HotRod33, Tman and c6matt like this.
  10. Marty Strode
    Marty Strode
    I would worry more, about breaking one or both of the clamping ears at the top, than the key, however the key slot in the sector shaft looks questionable. You could be just one chuckhole from disaster.
  11. It sure is purdy, but in reality that is art car stuff. I have no qualms about cowl steering, have built my own. Br*** a no no
  12. spanners
    spanners
    Am I correct in ***uming that there is no spline on that shaft, just the keyway?
    One question for the metallurgists out there, just for curiosity , not slagging on the O.P.? Is bronze stronger than br*** because it's a mixture of alloys?
  13. pitman
    pitman
    Number of alloys, treatments. Yes.
  14. mgtstumpy
    mgtstumpy
  15. flynbrian48
    flynbrian48
    I can't get past the "I'm just going to drive it to get ice cream..." part.
  16. Hollywood-East
    Hollywood-East
    I've read you're going to redo it..
    Here's something not touched on, That arm may not have given up the ghost Yet, Because you haven't strengthened up the box, That lil bit of movement is stopping the Shear headed for the arm, If that make's sense..
  17. 57 Fargo
    57 Fargo
    But Brian, nothing bad happens going for ice cream! As I know that Brian uses his cars, as I do, I would rather not be wondering if something was going to fail no matter the speed I was driving at….
    flynbrian48 likes this.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    video with correct geometry, with a normally mounted steering box
    mgtstumpy and kadillackid like this.
  20. jimvette59
    jimvette59
  21. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    It is indeed an elegant looking piece.
    But...
    I would make a stronger arm from steel and powder coat or paint it for the br*** look. You can repurpose that into a shifter handle, trunk latch, windshield crank, or other non-life-threatening use but still retain it on the car.
    VANDENPLAS and TA DAD like this.
  22. My late model OT Ranger had that much bumpsteer and it was designed by "engineers"
    2OLD2FAST and HotRod33 like this.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    the difference is that 32 fords as designed did not
    Lloyd's paint & glass likes this.
  24. Lloyd's paint & glass
    Was bump steer only an option on a Ford? If so can I adapt it to a Chevrolet? I'll go see if speedway has a kit, be right back
  25. HotRod33
    HotRod33
    I'm not sure if you could get bump steer on a Chevrolet but you could order it on a Dodge ...
  26. Of COURSE you could get it on a Dodge! Always a Dodge!!
    VANDENPLAS and HotRod33 like this.
  27. AIGHHHHH ... I said I wouldn't comment on cowl steering but I can't help myself :(
    The two videos posted by Mori show it perfectly. In the first video (Bump Steer) the blue and the black bars travel on different arcs with the two pivot points being far away from each other. In the second video (Minimum Bump Steer) the black and the blue bars travel on the same arc or as close as possible to the same arc, as they both use virtually the same pivot point (getting the pitman arm pivot point as close to the rear split bones mount) with the bars being roughly the same length.
    The easiest way to completely eliminate bump steer when running split bones and a parallel drag link is to .... solid mount your front axle to your frame :D:rolleyes:
    The next best thing is to severely minimize suspension travel o_O
    The size of the arc (as determined by the length of the bars) and the amount of conflict (as determined by the amount of suspension travel) will determine how much bump steer a car is saddled with.
    Have I ever built one with cowl steering? No ... for exactly the reasons posted above.
    mgtstumpy and Moriarity like this.
  28. Except if your split wishbone hotrod was articulating THAT MUCH it wouldn't be a hot rod, it would be a Jeep. The video simply exaggerates things to try and illustrate the differences.
    Xman likes this.
  29. I am in total agreement with you. I stated 'severely limit your suspension travel'. Too much travel with a "flawed design" (my words) will cause unacceptable amounts of bump steer. The root of the problem being the decision to use a 'flawed design' in the first place.
    Split bones on a forged axle and your axle becomes a sway bar. Split bones on a solid axle rear end where the solid axle doesn't flex and you've just designed a flawed rear suspension. I get that people do this all the time and I get that very few have problems but that doesn't mean it is not a flawed design (sorry, just another example of a commonly used design that is flawed from the get go). I broke welds on ladder bars (on a street driven car) for the very reason listed above ... it was and is a bad design.
    Sigh ... I knew I should have just kept quiet :rolleyes::D
    joel and Moriarity like this.
  30. Lloyd's paint & glass
    Could be worse, it could have an ifs.
    joel, VANDENPLAS, Moriarity and 2 others like this.
