Y Block Hoarders Identify yourselves !
Discussion in 'The Hokey Ass Message Board' started by Blue One, Apr 11, 2012.
  1. My aftermarket Valve Cover Collection a few years ago when I was going through some things.
  2. Truck64
    Truck64
    from Ioway
    Can I be your friend?
  3. I've got a '57 292 sitting on a stand, not sure why. Sold the car it was going to go in. I still kinda like the idea of dressing it up a bit.
    Boneyard51 and Deuces like this.
  4. jimmy six
    jimmy six
    You could always run a SBC or a LS and be like every other sw**g d**k.
    Atwater Mike, rpm56 and Boneyard51 like this.
  5. ahshoe
    ahshoe
    I have a Y block tri-power set up with 94's, car and a truck Y block bell housings ,a front mount, and a 60 Y block 2v intake , Y block distributor , My '56 F100 has a 292 ,Y in it. Also got a T-Bird with a 312 in it.
  6. Atwater Mike
    Atwater Mike
    Still have my '57 312 'Bird Y, gifted to me by my bud Lenny. My orig. 'Bird valve covers were 'lifted' by some a$$hole, probably just to sell...I have the '56 312 intake, single Holley. Thief that got the valve covers also took the Edelbrock three 2 intake, w/orig. 97s...
    I also have my '54 239 original mill from my '54 Ford Coupe, that now has a fresh 406 FE. Wheee!
  7. Haven't posted here in years but my hording hasn't gotten any better. I also horde Flathead and banger stuff too. ;)
    247189852_10227262508935528_6813668602783920542_n.jpg 247127880_10227262509175534_1332363681239671218_n.jpg 246772718_10227262509255536_5182901679021203585_n.jpg 246669359_10227262509295537_5876520024143169258_n.jpg 247238729_10227262509215535_6098430697246652513_n.jpg 247243759_10227262509055531_1477014595513962776_n.jpg 248016646_10227262509135533_7799102861174865506_n.jpg 248335850_10227262508975529_5940540852333069491_n.jpg 248668865_10227262509015530_8939424459292114833_n.jpg 248719908_10227262509095532_1654670812222078226_n.jpg
  8. J. A. Miller
    J. A. Miller
    from Central NY
  9. guthriesmith
    guthriesmith
    I am by no means hoarding any y-block stuff, but between my son and I, we have two 292’s in drivers and a 56 312 waiting on a rebuild to replace the 292 in my 56.
    Boneyard51, mctim64 and Deuces like this.
  10. williebill
    williebill
    When I retire, I'm going to hang out with Tim.
  11. Deuces
    Deuces
    That's a quazy lookin' intake on that Y-block....:confused: 247127880_10227262509175534_1332363681239671218_n.jpg
    Boneyard51, loudbang and mctim64 like this.
  12. It works. 196+ mph on 304ci. ;)
    Tickety Boo, partsdawg, rpm56 and 8 others like this.
  13. Deuces
    Deuces
    Cool....:cool:
    Boneyard51 likes this.
  14. 327Eric
    327Eric
    I could . I hate LS engine more. I have all the stuff to do a 302, which I bought because someone is LS swapping another poor 59 . If the 312 runs, and I hope it does,I'll run it. But 20 years of bad storage doesn't bode well. It's a cost point thing. I have everything to do a Chevy small block, but, a Chevy in a Ford isn't right, and not worth considering. I have had nothing but bad luck with Y blocks, and prefer any other Ford engine, but the keep falling in my lap. I have had multiple tri powers, valve covers, distributors, and manifolds p*** through my hands, and not one decent Y block to run them on. It is a boat anchor to me, but I would walk before an LS swap. Maybe the wrong post to say I hate the Y block, but the Irony of finding so many cool parts over the years is striking.
  15. famdoc3
    famdoc3
    Is it hoarding if you use them?. 1 for the hot rod and one in my 57 Tbird which has 2 4barrel original converted to twin throttle body fuel injection. I do keep some spares maybe 6 sets of heads, a 292 crank, 312 crank, manifolds, intakes and a spare long block 292. Maybe just enough “spares”. MIKE
    USMercUte likes this.
  16. Deuces
    Deuces
  17. famdoc3
    famdoc3
    The next part of the hoard…..80 over 312, isky 300 series cam, 2x4 manifold and twin throttle body fuel injection, gen 7 accel computer. Powering my 1957 T’bird. DB424071-9087-4451-A172-BDBACE0B8E59.jpeg FCD027E1-677C-4892-8227-D9370E85C02E.jpeg D75608BF-A05F-42D5-962C-CB275EA0B61D.jpeg
  18. spdster
    spdster
    Ran across one of these - never seen one before.
    loudbang and Deuces like this.
  19. junkyardjeff
    junkyardjeff
    Late last year I picked up a 64 truck 292 to get the distributor and PCV system but since it has a truck timing chain cover and a rear sump oil pan it might get built and installed in a 40 ford if I ever find one I can afford.
    Deuces likes this.
  20. Blue One
    Blue One
    from Alberta
    Looks like a box to contain a carb for a supercharger application.
    Deuces likes this.
  21. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Eric
    Tim McMaster is right down the road-so to speak (well 3 hrs down I-5). I am driving down on thursday to drop off my 312 for him to fix up. I can't wait to get it back so I can stuff it and run it.
    Mike
    Blue One, Deuces and rpm56 like this.
  22. rpm56
    rpm56
    Lots of cool stuff here. I'm just starting my hoarding, picked up a standard bore 1957 T-Bird 312 Special E code a couple years ago that spins freely. I hope $300 wasn't too much too pay.
    Deuces likes this.
  23. Blue One
    Blue One
    from Alberta
    It will be too much if you dis***emble the engine and check for cracks in the main bearing webs and discover that it’s cracked which is common to the 312 blocks.
    However if you end up with a useable 312 crank and usable ECZ- G heads then you can find a good 292 block and go from there.
    Boneyard51 and egads like this.
  24. I'm going to start hating the Y block, may the parts flow to me....
    mctim64, Boneyard51 and Truck64 like this.
  25. spdster
    spdster
    Ran across 2 pairs of NFS ( not for sale) 471 heads. 292 truck heads - low compression - not factory authorized but can be used with superchargers. Easier to find than EDB-D heads.
    Boneyard51, Deuces and mctim64 like this.
  26. im just watching.... totally not jealous of the ability to have parts when you need them. i still dont have pushrods...
  27. Deuces
    Deuces
    Did they all come with screw in studs????....
  28. Boneyard51
    Boneyard51
    I think those heads with screw in studs are SBF heads. Y- blocks have rocker shafts.
    Bones
    egads and Blue One like this.
  29. Blue One
    Blue One
    from Alberta
    Pretty hard to hoard Y block parts when you don’t even know what they look like. :D
    egads likes this.
  30. 57 Fargo
    57 Fargo
    I have one y block of unknown displacement….don’t think I qualify as a hoarder…
