Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. j hansen
    j hansen
    @2Blue2 Now that it is clean,,,,,give it some paint:) IMG_6813.jpeg
    winduptoy, Dave Mc, 2Blue2 and 7 others like this.
  2. Orn
    Orn
    Replace the rear axle on my -53 Chevy today. 247021115_6444174942320356_202821237519002513_n.jpg
    Dave Mc, 40two, Fabulous50's and 18 others like this.
  3. LAROKE
    LAROKE
    From the BillyBob Shop log
    October 26th 2021 Slacked off a week for dental work. Extracted a quarter of my remaining teeth and got fitted for new choppers. Mourned the loss of three that have been with me from the beginning. Wasn't as painful as it sounds. Should have cowboyed thru it better.
    Quik-n-durty cleaned the remaining valves to measure them. Shined them up some by chucking them in a 1/2" drill motor secured in my bench vice. Set it running and used wire cup in the electric die grinder. Exhaust valves, in general, were in better shape than the intakes. Three of the intakes had raised "GM" and "TP" letters on their faces.
    Cleaned the guide bores with Hoppes #9 and engine bottle brush. Measured the valve stems with the mic and the guides with a small hole gauge and mic. Initial readings were pretty even at "0.3317" for the stems and "0.3327" for the guides, including the new one. Must have not done it right. Gotta recalibrate, bone up on procedure and do it again.
    Beer of the day was Millstream Brewing Company's Schild Brau Ambar Vienna Style Lager. Background music was Return of the Grievous Angel: A tribute to Gram Parsons.
  4. TA DAD
    TA DAD
    from NC
    One more thing checked off my list ! I had everything to build the fuel line on hand. I do have to get some 3/8 fuel injection style clamps as all I had is some 5/16. I will also slip a piece of Firesheild over the steel line when I finish it up. studebaker build 003.JPG studebaker build 007.JPG
  5. WB69
    WB69
    from Kansas
    Took the back seat out of the 29 A to get rid of a dead stinking mouse. Amazing how a small mouse can cause that much stench.
    bchctybob, 2Blue2, RICH B and 2 others like this.
  6. LAROKE
    LAROKE
    October 28th 2021 Recalibrated my micrometer and took another go at the nailhead valve and guide measurements. Ended up being more confused then a blind man feeling his way around the elephant.
    Number one cylinder intake valve was pretty pitted so, when I ordered a new exhaust valve for the one I ******ed, I ordered an intake as well. These came from Fusick Automotive Products and now I can compare them to the existing valves.
    My new measurements were unclear but they gave me a sloppy .0005" average valve clearance between valves and guides. The new valves and guides were consistent with the old ones, however, and this was a good sign to me.
    According to my Dad's old 1959 Chiltons manual, the valve readings were closer to a 364 nailhead than a 322. This is a head scratcher to me unless replacement valve specs changed over the years. At any rate, I have enough info to take to my friend John to help me suss out.
    Beer of the day was Sprecher Brewing Company's Scotch Ale. Background music was Asleep at the Wheel Ride with Bob: A Tribute to Bob Wills and the Texas *******s.
  7. vtwhead
    vtwhead
    Finally after a ten year project we put some color on the A. Wimbledon white for the firewall, black for the body maybe next week.
    Dave Mc, bchctybob, Joe Blow and 10 others like this.
  8. RICH B
    RICH B
    Picked up some pieces from the sandblaster; went to fill a couple pin holes in the rear splash panels, decided to hold one in place and learned they didn't clear the rear hanger for the added parallel leafs. Trimmed them back, bent a new flange around the edge, and welded the corners. Then filled the pin holes. Always love finding unplanned work. I am thinking of epoxy prime and bed liner for these, good idea?
    bchctybob, Joe Blow, HotRod33 and 7 others like this.
  9. Jkmar73
    Jkmar73
    from Tulare, CA
    Worked on dash today. Installed 32 dash for model A. And fitted in sub dash for switches. Also worked on seat mounts for bench seat. 15D6E235-B35F-414C-B7AA-6B4C31FA40A9.jpeg
  10. High test 63
    High test 63
    IMG_20211030_173728331_HDR.jpg IMG_20211030_184403504.jpg may be in over my head, but i finally made the move to upgrade my roadster from gl*** T body to steel A body.
    I have the major parts for the ch***is upgrade also. Now I just need to make the time to make it happen.
  11. alanp561
    alanp561
    I'm telling you, that cheap *** beer you keep drinking is rotting your teeth. Single malt Scotch is much better for you;)
    Joe Blow, Lil32 and High test 63 like this.
  12. Nah, it is the music!:D:D
    Keep on keeping on, .
    Ben
    alanp561 and High test 63 like this.
  13. Bjorn Wilsson
    Bjorn Wilsson
    Went to a swapmeet, with mostly american parts. Looking for 40 ford stuff in Sweden is not that easy, they where never sold new because of ww2. After twenty minutes I found something I been searching forat least two years. Taillights from Studebaker -41. Brand new repos in really good quality. I know they cost 450Dollars + shipping , toll and tax easy 600 before I have them in my hand. This was 280 dollars and igot them directly- no waitning. Score of the dav 063.jpg
    Dave Mc, 40two, bchctybob and 16 others like this.
  14. ROADSTER1927
    ROADSTER1927
    IMG_0583.JPG IMG_0696.JPG Put both hot rods away for the winter sleep. Had the Pontiac out last weekend and the Roadster to a Halloween party yesterday.
    Dave Mc, bchctybob, Lil32 and 4 others like this.
  15. junkyardjeff
    junkyardjeff
    Starting the installation of the new trans in the sunliner,it will probably nit get done as quick as I could a few years ago,
    Joe Blow, winduptoy, HotRod33 and 3 others like this.
  16. Those are gonna look sweet on your '40!
    Bjorn Wilsson likes this.
  17. lake_harley
    lake_harley
    IMG_20211101_133504548_BURST000_COVER.jpg IMG_20211101_133429672_BURST000_COVER.jpg I finally got my Model A on the ground in pretty much its final form.I had the engine running a couple days ago but probably need to recheck and set timing, fiddle with carburetor, rebleed brakes, and hard telling how many more things, but it should be ready to move under its own power soon. Hopefully that will happen in the next few days. It's been a longer journey getting this car together then I would have ever imagined! I am pretty pleased with it's stance now that it's on the ground with everything on it.
    Lynn
  18. Blues4U
    Blues4U
    from So Cal
    Got the carb swap on the 283 in my A pickup mostly done, still need to hook up a choke, and will probably need to do some sorting out , but I have a few miles in on it and it runs good. My seat of the pants dyno says there isn't much, if any, more power out of them than the dual 2GC's, but there's certainly a large visual impact.
  19. Lil32
    Lil32
    dropped coupe into mate's shop to have rear axle seals and bearings and brake shoes replaced
  20. junkyardjeff
    junkyardjeff
    Got the old trans out and the rebuilt one in,ran out of energy and patience so time to quit and finish it tomorrow. A couple years ago I could do all in one night but not now.
  21. RICH B
    RICH B
    Nothing too note worthy accomplished today on our '47; but a little progress. Installed a new SW speedo and hooked up the cable. Added a couple diodes to the signal indicator wires since I am only using one indicator. Cut the tie wraps and rearranged the wires for the high beam and turn indicator since I changed ideas. Installed the cable to water temp control valve; hated enlarging the hole in the dash; but managed to not chip the paint. Ended up making a slotted socket on a stick to tighten it as a crows foot didn't fit. Made a new hanger bar for the heater as the first one I made years ago didn't account for the glove box. Made a pattern for the air box to go behind the speaker grille. Welded and sanded on my bumper guard tail lights some more; still need to add some mount plates or something. guess that means digging out the bumper.
  22. lake_harley
    lake_harley
    Blues4U, ^^^^The loops on the fuel lines are a nice touch
    Lynn
    High test 63 and Blues4U like this.
  23. Blues4U
    Blues4U
    from So Cal
    Thanks Lynn
  24. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Got the new rear springs in the wagon and slid the diff into place on Sunday. Tomorrow I am hoping to lock it down and install the brakes over the next two days. If everything goes well-here's to hoping-I will roll her out of the garage on friday for the first time in years. She will get hose job just to get all of the dirt off of her prior to yanking the dead ****** and stuffing the new engine and ******. I will post pics in my 'finally a longroof' thread.
    Mike
    High test 63, RICH B and Lil32 like this.
  25. alanp561
    alanp561
    Got the roller back on the ground so I could do a final fit for the body. Looked around and all my help had disappeared. Sometimes, you just gotta work with what you've got;) 20211101_184854.jpg
  26. Blues4U
    Blues4U
    from So Cal
    Nice! I drove a Ford F800 service truck for about 5 years, with an IMT service body with 8600 # hydraulic crane. Your picture reminds me of those days. I kept the truck at home and often travelled directly from home to the job rather than going into the shop and being dispatched from there. That often saved the customer a lot on travel time & mileage (and saved me wear & tear on my personal vehicles). It was convenient having all my tools, plus oxy/acetylene torch set, air compressor and Miller welder all in one tidy place, a complete shop on wheels. Wish I still had that at my disposal.
    winduptoy, alanp561 and TA DAD like this.
  27. alanp561
    alanp561
    I'll sell you mine. I was replacing dock levelers for a trucking company that had 13 terminals all over the south from Memphis on the west to Raleigh, NC in the east to Columbia, SC, Birmingham, AL and points between. I looked for a truck like this for 2 years before I found it. It made me a heck of a lot of money and I didn't have to pay a helper to ride from home to the job, most of the time while he was sleeping. Didn't have to pay his motel and daily meals, either. Right now, it's serving as tool storage and comes in handy when I get the occasional welding job.
  28. lake_harley
    lake_harley
    ^^^^Daily driver perhaps?
    Lynn
    HotRod33 likes this.
  29. OL 55
    OL 55
    Trying to find an oil leak. Got outa control! :rolleyes:
    1827F790-6687-46FD-8665-6A8D19F451FB.jpeg 11A1F76A-FE77-4043-82AF-0C44AF8E6B7B.jpeg
  30. HotRod33
    HotRod33
    Yes.... I'm going to go thru the brakes and steering and then drive the **** out of it
