Technical Is my setup strong enough? Cowl Steering Question
Discussion in 'Traditional Hot Rods' started by c6matt, Oct 23, 2021.
  1. No, needs to be steel, it'll break down at the bottom where the drag link attaches. Get in touch with Ross Steering people or the like such Schroeder Racing Products in Burbank Ca.
  2. RustyTub
    RustyTub
    from Washington
    I appreciate this simulation as I am a cad guy as well but that is a lot of movement for an early model vehicle. I understand it’s for demonstration purposes but it also demonstrates how little it would actually move if you suspension moves, what an inch and a half.
  3. RustyTub
    RustyTub
    from Washington
    I agree with everyone else. Very cool looking but I would not trust it. Like they say, nothing built too strong ever broke.
  4. dmar836
    dmar836
    But also some things built too strong could never move. ;)
  5. spanners
    spanners
    Hand up anyone that hasn't heard of an axle key shearing off just going around a corner with a squirt of throttle?
    Lloyd's paint & glass likes this.
  6. X-cpe
    X-cpe
    Reminds me of my brother, "I was just driving normal when it (whatever) broke", never mentioning the 1000 times he hammered the snot out of it.
  7. Flathead Freddie
    Flathead Freddie
    Hi if it's the box flexing I would consider a mounting plate made of stainless 403 and design it to web in with whatever you can attach it to stainless is not flexible and looks alright set off with your stainless hdwe
  8. Flathead Freddie
    Flathead Freddie
  9. theHIGHLANDER
    theHIGHLANDER
    Potholes in and around Motown? I recently swapped to a different DD because I blew 3 tires in 18 months from the holes around here. You avoid one to drive right into another. They were bad*** Pirelli run flats too, you'd think strength right? So bad that defensive driving didn't help in some areas. Would I want to hit any of them with that arm? No thanx. Then when they do fresh pavement and the mopes don't raise or lower the manholes? You think potholes ****, hit one of those unaware. Just hit one with a 3500 GMC last week. I'd like to find that ***hole and have a "discussion" with em.
    borntoloze likes this.
  10. patmanta
    patmanta
    from Woburn, MA
    I would suggest that all that flexing you mentioned is what is keeping that little br*** arm from snapping (so far).
    I like the MOPAR or Corvair box replacement idea with a good pitman arm. You could just paint, dip or try to plate the new pitman to keep the general look.
  11. Too funny ... quite a few years ago a friend of mine and his wife moved to Detroit (from Ontario Canada). She took a position as a manager of some sort at the large company they both worked for (same company they worked for in Canada). Not long after taking over as manager in Detroit, she noticed a few too many people coming in late with the same excuse ... "I got a flat on the way to work". She figured something else was up so she asked other managers and they all stated "nope, it's legit ... the roads around here are so bad that it is VERY common for people to show up late due to flat tires. No one is lying to you, they ARE getting that many flats".
    theHIGHLANDER likes this.
  12. c6matt
    c6matt
    Closeing this out, This is what I made after seeing silmilar on here, 1/2 steel with br*** overlay to keep the look. Powder coated the steelblack to fade into the background
    Tman, Joe Blow, HotRod33 and 8 others like this.
  13. DDDenny
    This is probably still in the mockup stage but if not the bolt needs to fully p*** through the elastic part of the Nylock locknut.
    stanlow69 and c6matt like this.
  14. c6matt
    c6matt
    Agree, it is not tightened up, was checking clearance. i also will be drilling for safety wire...
    Tman, loudbang and pprather like this.
  15. nochop
    nochop
    from norcal
  16. mattyrz05
    mattyrz05
    I'd like to disagree on that one. All that's needed is to actually understand how steering geometry actually works. If the steering arm coming from the cowl is the same length, and on parallel planes with the hairpins, no bump steer(or very minimal) will be noticeable. There may be some there, but you should be able to minimize it if you can't eliminate it. Is it an easy thing to accomplish? No, it's not. Is it achievable? Absolutely. All it'll take is time with a bump steer gauge, welder and a grinder. Tack the mount, check the bump, move the mount, check the bump. And repeat as needed. This all comes from a racecar background. Geometry is geometry.
    Here is a link to a diy gauge: https://www.homemadetools.net/homemade-bump-steer-gauge
    Do your thing. Listen, not always right, to what folks say, do your research and you'll get it.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    It is proven in Mr Eastwoods thread on cowl steering. I suggest you get a copy of pete and jakes information on the subject. parallel and same length has nothing to do with it
    look here, and read the whole thread
    https://www.jalopyjournal.com/forum/threads/cowl-steering-just-stop.1101046/
  18. And dozens of Rolling Bones cars prove they work. So, lets agree to disagree.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    That proves nothing. Stiff springs and almost no front suspension travel limits the amount of bump steer. It is proven in Mr Eastwood’s thread with real math and articulating videos
    31Apickup and WiredSpider like this.
  20. I highlighted part of your quote. You describe ALL our buggy sprung hot rods. None of these are rock crawlers. And I still call BS on that vid that Hot Rod Works posted, the movement shown is exaggerated to prove a point. In the real world, Ken and Keith have satisfied customers that drive the piss outta their cars. Not to mention others including myself that designed and built cowl steer cars that work excellent.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    just get up on the spreader bar and jump up and down, the bump steer will be obvious. I am not saying people don't drive them, they just drive them with bump steer....
  22. My daily 2000 Ford Ranger actually had more bump steer than my touring. And the steering wheel had an oblong path in its rotation. Actual engineers designed that one...
  23. Back to the OP, looks like a great improvement!!! And you managed to keep the vibe the same!
    c6matt likes this.
