Fibergl*** Pickup Cab p***enger style 2 1/2 Chop (new)This is the only Cab (1) pulled from a mould making a pickup cab from a p***enger car 5 window body..Windshield frame, Doors are save as 5 window except rounded corbners..Doors hinged and latched, manual windows with gl*** installed, Pickup bed Last refuge Hot Rods, 32 ford ch***is,ASC RAILS ,. crossmember foward 1 1/2 inches down 1/2 inch, front axle with split wishbones, complete wilwood disc brake front kit with alloy hubs, 9" Currie rear big Ford Torino drum brakes, Coil over rear shocks,. 9" center section rebuilt w/ new bearings,Driveshaft new and installed, gl*** for cab 2 side windows and 1 rear, coker tires, 4 early ford steel wheels, Vega Box, Aluminum radiator and formed aluminum shroud, Zips water pump kit, vintage air a/c system for 32 ford,EZ Wiring new in box , Hood center hinge with louvers, 32 grill shell, grill insert aftermarket,Fibergl*** fenders front and rear,Engine is a 350 chevy and trans good running not rebuilt,..would consider selling without engine trans , headlamp bar, . Clear New Jersey ***le OVER $20,000 IN PARTS!This is a project and must be completed.. NOT A BUILDER? NO PROB, WE'LL FINISH IT FOR YOU! New Price $14,500... 973 222 7265
