Technical The upholstery thread to end all threads
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 5, 2021.
  1. LongT
    LongT
    I did a bicycle seat about 40 years ago with spray adhesive. The naughtiest is still stuck.
  2. Very nice
  3. Roothawg
    Roothawg
  4. I went to a guy that a friend of mine told me about & he
    told me a price that was too High 85 hundred dollars.!
    So I told when Hell Freezes Over I wood have it Done.
    I have the Front Seat done 2 years ago but he put 2 much
    Foam on the Bottom part of the Seat which I had to move the Seat back
    on the Track.
    Just my 3.5 Cents
    Live Learn & Die a Fool
  5. ZZ Top Chop
    ZZ Top Chop
    After several weeks of hunting down a replacement for this broken screw. I think I fixed the s***ch length issue. Someone said on this thread, that it sounds like I'm going to get to know this machine real well. Yep
    Whoamel, loudbang and Roothawg like this.
  6. Whoamel
    Whoamel
    from So Cal
    I brought this home yesterday. Got an insane deal on it from a nice couple who bought it new. They had a boat, and they bought it to do a few things to their boat and then never used it again. It is literally new, and I paid less for this than I paid to have carpet done on my last project car.
    I've got a lot (most everything) to learn, but anxious to start. I'm going in head first!
  7. SDS
    SDS
    Anybody using an Artisan model 601 RB?
    A buddy just gave me one, in serviceable condition, but I'm used to JUKI walking foot machines - looking for usr-experienced tips & nuances on this Artisan (limited parts availability because it was only imported from 1994-97, so I don't want to crash anything).
    Thanks,
  8. continentaljohn
    continentaljohn
    @Whoamel great score on a great machine. I recommend heading over to sailrite for some how to videos . I recommend doing some covers like tool box grill welder and then move to stadium cushions .I use the stadium pads for working on the car and wife in the garden. You can pickup cheap materials from rochford supply in mn. You can get seconds of Carhartt materials for 5 bucks a yard. Have fun
    loudbang and Whoamel like this.
  9. Whoamel
    Whoamel
    from So Cal
    Thanks! It was a really great price on a (pretty much) new machine. I did order the Lucky Needle Apprentice Course, and I need to get oil, thread, and nearly every necessary small item before I can get started. I've seen a couple of the Sailrite videos, along with Cechaflo, and one or two others. Luckily for me, there are a lot of videos on how to thread, adjust tension, etc, etc on my machine. I appreciate the suggestions. Thanks!
    I should mention that I recently acquired a '40 Ford Coupe, and while I was looking for a car, I told myself that if whatever I bought needed upholstery, I was going to get a machine and get started on learning how to do it. My car has fairly nice upholstery, but it's a very strange combo of 60's meets the 90's. I much prefer the 60's.
  10. hotrodlane
    hotrodlane
    I have the same machine and as long as you keep it oiled good it will treat you rite! It is branded Consew But is basicly the same standard Singer head used by tons of shops over the years. I have had mine for over 20 years and it has never let me down. Sounds like you got a great price on it.
    continentaljohn, Whoamel and loudbang like this.
  11. continentaljohn
    continentaljohn
    Congratulations on the 1940 coupe @Whoamel The one accessory I got for my sewing machine is a welting foot . It has been on my pfaff machine for 20 years and never take it off.
    @hotrodlane is your consew a updated Singer 111rb
    Whoamel, 6inarow and loudbang like this.
  12. hotrodlane
    hotrodlane
    @hotrodlane is your consew a updated Singer 111rb[/QUOTE]
    John, Yes it is the consew version of the old 111 I bought my consew head at a salvage freight auction over 20 years ago, It had been damaged in shipping (just the wheel was cracked) I gave like $35.00 for it and replaced the wheel. I sold my old singer 111 for $400 in the star cl***ifieds and went and got a new table and motor for my new head. (So I was money ahead and had a brand new machine) The singer still worked great but needed a good cleaning from me not keeping it covered good in the shop while not in use. For a short while I had a older "juki" machine that some seem to favor, But In my opinion it is hard to beat the 111 style machine regardless what name badge it has on it.
  13. Whoamel
    Whoamel
    from So Cal
    First day sewing, ever.. My machine was used for doing canvas work on the PO's boat, so it had a larger needle and heavier thread than I needed. When I changed it over, I had to adjust tension, and I found this English leather worked explained it and demonstrated it very well in his video. I put a link to it in case someone is starting at ground zero, like myself.
    I used his example of using two different thread colors so you can clearly see when the tension is off. The white is the top s***ch, and the black is from the bobbin.
    You can see where my tension is off and the overlapping horizontal and vertical makes it hard to tell, but I did get it sorted in a fair amount of time.
    You can clearly see mistakes, but this is really my first time using a sewing machine. When I got a bit flustered, I thought back to my first day mig welding, my first day tig welding, etc, etc. I think this went a bit smoother.
    I did order the Lucky Needle Apprentice course, but I ordered the DVD which I am still waiting on.
    I am going on the ***umption that it will only get better from here..
  14. continentaljohn
    continentaljohn
    You did great for your first day sewing and understanding the mistakes and fixing them will make you better yet. The needle should fit thread size here’s a chart from Toledo sewing machine and a great place to get thread and needles. I also get parts for my machines as well with a great ***ortment of patcher parts. A7A0637C-559F-4D98-A9C7-0127C8DC6C13.png
    brEad, Whoamel and loudbang like this.
  15. SDS
    SDS
    I finally got my freebie Artisan model 601 RB up and running. Still trying to find a manual or anybody that's used one of these for advice.
    brEad and loudbang like this.
  16. 12amrider
    12amrider
    from tacoma wa.
    Did my first upholstery job around 1965. It was my first 57 Chev. I watched an upholsterer sewing a diamond tuck seat. All the s***ching was done on the back side of the material so there was no s***ching on the face. Bought some black vinyl and premade ****ons. Mom was leary about my using her sewing machine but let me do it. Years later while working nights I was able to go to Voc school in the daytime. Did cars for people nights and weekends. Worked in the parachute shop at McChord AFB for years. Sewed up a lot of C141 interiors including the cargo bays. At 74 I still do small jobs. No more complete jobs. I remember using machines that didn't have reverse to lock your stich, sewing rolls and pleats then stuffing them with cotton between two yardsticks. using horse hair for stuffing on furniture. I'm glad to see so many of you are interested in learning how to do upholstery. A good web site is The Hog Ring, lots of info in their library. Hope I didn't bore you. Wayne
    i
    Bullit68, GuyW, Whoamel and 4 others like this.
  17. Mimilan
    Mimilan
    You will get better...It takes time to get a feel of it.
    Just remember the tension should be set to the fabric weight [both top and bobbin] , If the fabric is too lightweight or tension too strong the sewing will pull the fabric like a draw-string.
    Once you have got a "feel" for s***ch length and machine speed, I recommend changing sewing style by using a leading hand. [this is an awesome "cheat" technique]
    Put your Left hand around behind the machine needle and hold the fabric like a "hacksaw" [one hand behind,one hand in front]
    This method allows you to control the fabric stretch, and fabric speed so you end up with consistent s***ch length.
    This ^^^^ is very helpful when sew something that is cut on a diagonal [onto something cut straight]
    Now another "cheat" method when sewing stretchy fabrics [open weave, or sheepskin/soft leather]
    Use 2" wide SELLOTAPE.
    Tape the edges to be sewn, so it doesn't stretch. Then sew straight through the tape which ends up getting perforated .
    Then peel the tape off later [it rips off easily through the perforated s***ch holes]
  18. SDS
    SDS
    Great story, thanks for sharing - keep on sewing, man!
    loudbang and stanlow69 like this.
  19. fatboys69
    fatboys69
    from Tennessee
    just saw this and following . picked up a consew and am getting ready to start practicing.
  20. Whoamel
    Whoamel
    from So Cal
    Can anyone recommend something for marking removable lines on vinyl and/or carpet? I've tried a few things and haven't had the best success. Thanks!
  21. 6inarow
    6inarow
    space pens. amazon has 100 refills almost as cheap as a couple in the cartridge. wipe off vinyl very easy. calk triangles for carpet
    loudbang, continentaljohn and K13 like this.
  22. SDS
    SDS
    Sailrite makes some great marking implements... Here's a guide on how to choose which one to go with
    https://www.sailrite.com/How-to-Pick-the-Best-Marking-Pencil
  23. Whoamel
    Whoamel
    from So Cal
    Thanks! I ordered a tailors chalk, and I ended up buying some scribe-all pencils that work fine, and were available locally.
  24. Practicing on some chairs. Here's a panel I sewed up with an old singer 20220114_214921.jpg
    Whoamel, Rocky72 and loudbang like this.
  25. topher5150
    topher5150
    Bought some hard board today and I have a couple of questions. Does it matter which side is out (shiny/textured) and can this be stapled?
  26. Bullit68
    Bullit68
    from Verona, PA
    Yes, I’ve used it and I used short stainless steel staples with good results!
  27. Bullit68
    Bullit68
    from Verona, PA
    I bought a Tacsew walking foot machine. It’s a chinese exact ripoff of a chinese made Consew machine. I had never operated a sewing machine ever. Got some chipboard and made patterns for my 36 pickup doors. Cut some hardboard to match size of pattern, then laid out material pattern on my chipboard. Hit the fabrics store for some vinyl, Bought all my thread, needles, sew foam, through Sailrite. Then are known for boats, but they have everything you need, plus show some automotive videos on YouTube. Started on a couple pieces of s****, got tension set and went at it! My wife was impressed when I showed her the finished door panel.
    22F68980-89B6-4886-8CB0-199B44FFAE2B.jpeg D87E4496-DAEC-4D8E-83C8-BBFADBB8BDD2.jpeg 4309D9C3-D24A-4D71-900F-B16885BE3026.jpeg 3DE1126D-48EB-4782-9F04-0ADC4DC384B7.jpeg C266FAC6-917F-4BDD-9526-7F2A249AF9A2.jpeg
  28. 12amrider
    12amrider
    from tacoma wa.
    Fabric stores have chalk markers that have refills in two collars blue and white. If you need something different the powered chalk carpenters use in chalk lines will work. For carpet upholstery outlets have tailers chalk . They are usually triangle shaped and are much harder so they don't break so easily. I hope this is some help. Wayne
  29. Whoamel
    Whoamel
    from So Cal
    That looks good! The panel fits really nice, and the sewing looks clean, too. I'm likin' the Gator Hyde...
  30. topher5150
    topher5150
    Not sure if this has been covered before or not but would some heavy duty sheet metal screws into the door be enough to hold the arm rest in place?
