Hot Rods 34 Drag Truck 60's Style
Discussion in 'The Hokey Ass Message Board' started by Barbarian, Oct 26, 2021.
  1. Barbarian
    Barbarian
    from New Jersey
    ** This project has taken a turn for the better around page 6, feel free to jump to there for the new followers**
    Quick recap - started as a 32 fenderless 'shop truck' and quickly turned into a full fendered 34 drag inspired truck, that was originally chopped back in the 60s.
  2. Barbarian
    Barbarian
    from New Jersey
    And here for the pics...
  3. Barbarian
    Barbarian
    from New Jersey
    Current state of mock up
  4. 41rodderz
    41rodderz
    from Oregon
    It looks like a fun project , and I encourage you too bring your to the pavement, the only thing I would suggest to step back and put some thought into the final wheelbase for ride quality.
  5. HotRod33
    HotRod33
    That will make a nice truck... How long is the bed???
    loudbang and Barbarian like this.
  6. Barbarian
    Barbarian
    from New Jersey
    Bed is currently 60”. It’s a stock 31 model A wide bed. Similar to a 32 in size but a foot shorter
  7. Love the plan. Made me think of this little guy which is one of my faves! (I realize it is a Model A but the vibe translates!) 5A91FDE2-1118-4637-BA1B-06DEECC79FAF.jpeg
  8. Good idea!!!
  9. Barbarian
    Barbarian
    from New Jersey
    Thanks for the feedback. Wheelbase will stay as is, I like it. Bed may shorten, grille will likely have 4” added back to bring it back to stock height. Bed may be lowered slightly as well. Also will probably not chop it, with a roughly 4” channel, I’m surprised how much I like it unchopped.
  10. 51 mercules
    51 mercules
    Cool!Following!
  11. Sounds like a great plan!:cool:
    Here's a bit of inspiration from my "good idea" folder:
  12. Barbarian
    Barbarian
    from New Jersey
    Coming soon to a hot rod near you...
    new radir 9..x15 cheaters and straight spoke torque thrusts that’ll get a ‘magnesium’ treatment
  13. Barbarian
    Barbarian
    from New Jersey
    Mounted up
  14. -Brent-
    -Brent-
    Right on!
    @Barbarian when you post pics, if you select insert every image as a... full image it will put it in your post as a large pic.
    Can't wait to see more. That's a great wheel/tire combo.
    dwollam, loudbang, Barbarian and 2 others like this.
  15. wheeldog57
    wheeldog57
    Mint bro, great project there. Keep at it and keep us in the loop.
  16. Barbarian
    Barbarian
    from New Jersey
    Little more mock up this morning. Wheel tire setup changes the entire look and almost perfects the stance. Not sure if I even will lower the bed anymore, it looks nasty as is. Bolted on the fenderwell headers that not in a fenderwell. These fit almost perfect as well and mask the area I was most concerned about - the narrowness of the A frame where the cab firewall is channeled looked goofy. Now you can’t see it and these go with the vibe. This is turning into a 60s drag/altered/fenderless gasser? whatever you want to call it, more than a shop truck. Hahaha woops ! Party on
    1C48F632-E019-4BCB-B002-AF1F036144FB.jpeg A65DFDFD-771E-450E-8321-FF7CDCB6CCE5.jpeg A475D3D8-89B4-43F8-AACD-0EF691B92265.jpeg DBDB6D03-35CA-4A14-B432-2DB216B96296.jpeg 7B5E38C5-5D26-4DD2-9010-CD895823CA33.jpeg 59B55F12-ECFF-416E-990D-405E3E720D3A.jpeg F6DDF348-9CE8-4226-8DAB-BB76713DEDEE.jpeg
  17. Looks great! What front tires are those? BFG?
  18. Barbarian
    Barbarian
    from New Jersey
    Coker Firestone vintage bias
  19. Even though you are not soliciting opinions, like everyone, I have one....I think you should channel it more.
  20. Barbarian
    Barbarian
    from New Jersey
    Likely won’t happen, but I’m curious, how much more would you go? It’s about 4” in the pictures and will end up around 5-6” once the bottom sheet metal is replaced that is currently missing.
  21. HotRod33
    HotRod33
    If you channel it anymore you will have to lower the bed .... I like the look you have right now .... The bed and the body line on the back of the cab are in proportion... Also the tire to the fender bead line looks good
    Deuces, coupe man, B Bay Barn and 7 others like this.
  22. Barbarian
    Barbarian
    from New Jersey
    Yea that’s not happening. Haha
    Agreed, it’s pretty well spot on as is. Not even sure I need to shorten the bed. Proportions seem good. I even like it not chopped. The angle of the pics sometimes are deceiving.
  23. -Brent-
    -Brent-
    If I could find some fenderwells (Nova) headers, locally, I'd be interested to test them on my coupe, just to see. They definitely have a wild look on these vehicles.
    I love that this is getting a 35/36 Ford dash. Can't wait to see more.
    mad mikey and loudbang like this.
  24. carpok
    carpok
    from Indy
    Nice find will be following along. Thanks for posting love old shop trucks.
  25. Barbarian
    Barbarian
    from New Jersey
    I got these off speedway, around $200 shipped. Cheap as dirt so I took a gamble and they fit insanely well for my build.
  26. Guy Patterson
    Guy Patterson
    Just me but you might do a photo shop an take some out of the bed and see if it changes the look of the truck. I think about 4 inches out of the bed would improve the look
  27. Barbarian
    Barbarian
    from New Jersey
    yea I’ve photoshopped around 6” taken out and it does look good, not sure better but definitely good. This will likely only get red oxide primer so I may shorten it at a later date. Going to get it up and running asap then tweak as I drive it. The cab is pretty rough, the major problems will be fixed but it will still be a little crusty so shiny paint isn’t very likely.
  28. Barbarian
    Barbarian
    from New Jersey
    Here's roughly 6" removed via photoshop, it does look very good. This will likely happen after the truck is running driving and being enjoyed. But I do also have a roadster on the back burner so who knows!
