Projects Belly Tank Build, NZ.
Discussion in 'The Hokey Ass Message Board' started by 26 T Ford RPU, May 3, 2021.
  1. Stogy
    Stogy
    Hows thing progressing...Tanks...:confused:...I mean Thanks...:D
    Gonna Run Whitewalls on it...just kidding...:p...hope your situation with the Airborne nasties over your way is pacifying...
  2. 26 T Ford RPU
    26 T Ford RPU
    Hey Bud, the set up tires on the back are whitewalls, worn out from my 37 Willys. As for progress, its slowed a lot due to spring projects around the property but i'm planning more Belly Tank progress and i have bought my full SFI rated race suit so i can start finishing the drivers area and start the roll cage soon. Still finishing the fuel tank and i have bought some fibergl***ing stuff to reinforce around where i will cut the axle openings. Updates soon. JW
    brEad, kadillackid, AndersF and 4 others like this.
  3. 26 T Ford RPU
    26 T Ford RPU
    Except for welding the seams the tank is done, the mounts are tacked in place and it all fits like it should' Should hold 4-5 gls which is plenty. JW
    Lil'Alb, Dean Lowe, JamieUC and 6 others like this.
  4. 26 T Ford RPU
    26 T Ford RPU
    The fuel outlet can be seen here and there is plenty of room to get to the lines with the lower body in place. JW
  5. 26 T Ford RPU
    26 T Ford RPU
    Made a special mount bracket to support the front of the ch***is to give clear access to be able to offer the lower body up to the new ch***is / body mounts. Lower body is bolted in place and masking tape where the axle reveals are going. Once they are cut out i will refit the axle and check my handy work and then make cardboard patterns in order to make 2mm alloy reinforcements to support the cutouts and fibre gl*** them in. More updates on this very soon. JW
    brEad, AndersF, loudbang and 2 others like this.
  6. 26 T Ford RPU
    26 T Ford RPU
    It was with great excitement to be finally cutting the axle reliefs. I set the lower body section on stands and started marking out, cut them out and felt very pleased. I had bolted the axles back on so i slid the body back under and lifted it up and put a couple of bolt in AND then i notices it wasn't that good...."well that't a ****up''. Not all bad as i can still trim where it hits and i kept the bits i cut out so i can fix the gaps. JW
    brEad, loudbang, Stogy and 2 others like this.
  7. 26 T Ford RPU
    26 T Ford RPU
    The rear axle touches the back of the reveal. JW
  8. 26 T Ford RPU
    26 T Ford RPU
    A while back i stated making a fancy gas pedal, always wanted to use one like this and now i made it i don't think i will use it as getting enough stoke for the master cylinder will be an pain so i started making some pendulum ones instead. The master cylinders has 1 1/4'' of travel so these will work better, the right hand one just won't look as interesting, will mock them up along with fixing my axle relief hack job. JW
    juan motime, brEad, loudbang and 2 others like this.
  9. I made a pattern and had some pedals cast when I started my racecar
    [​IMG][​IMG]
  10. 26 T Ford RPU
    26 T Ford RPU
    they look nice ! :cool: JW
    Stogy and loudbang like this.
  11. 26 T Ford RPU
    26 T Ford RPU
    Got my new helmet the other day so put all my gear on and had a play. Main reasons were to try my pedal locations and see where the top off the helmet was. It felt very good, compact but good. I will redo the pedals so they are longer and rotate the pads to be the same orientation as my feet. Once thats done i can start mounting them as well as the two master cylinders. JW[​IMG]
  12. 26 T Ford RPU
    26 T Ford RPU
    I also removed the lower body and ''adjusted'' the axle and tie rod reveals so it now works, a bit more to do on those but thats OK for now. JW
  13. 26 T Ford RPU
    26 T Ford RPU
    A bit fuzzy but shows the pedals and feet and as said i will rotate the pedal treads/pads to match the angle of my feet. JW
  14. Stogy
    Stogy
    That looks great...there's more room for pedals in there than I would have thought...The arched pads are a great idea too...
    loudbang and 26 T Ford RPU like this.
  15. 26 T Ford RPU
    26 T Ford RPU
    Its also rather comfortable to be in that position for a while although it was very hot in there. More soon! JW
  16. 26 T Ford RPU
    26 T Ford RPU
    Made the new pedals, MKIII model. Making the mounts now. JW
    kadillackid, brEad, loudbang and 4 others like this.
  17. Thanks
    Stogy and 26 T Ford RPU like this.
  18. Don't forget you need a return loop for the throttle
    loudbang, 26 T Ford RPU and Stogy like this.
  19. 26 T Ford RPU
    26 T Ford RPU
    That will be made soon. JW
    Stogy, loudbang and Tman like this.
  20. loudbang
    I don't know if you need smooth or rough surfaces on them wearing your booties but found this in the local home builder type store. It's to go on stair edges so old folks don't slip on the stairs.
    It's rough but not aggressively so and has peel off sticky tape on the back side. :)
    brEad, Stogy and AndersF like this.
  21. 26 T Ford RPU
    26 T Ford RPU
    Thanks, i have thought of that and i have that at work (3M). I fit out vans so wheel chair bound folk can drive from their chairs. The pedals should be alright without it but i have the option. Cheers for that.:) JW
    loudbang, Stogy and AndersF like this.
  22. Bearing Burner
    Bearing Burner
    from W. MA
    We used nonslip stair tread on out lakester pedals
  23. 26 T Ford RPU
    26 T Ford RPU
    Got some more done on the pedals and master cylinders. Soon i will start the dash area and still sneaking up on the roll cage. :rolleyes: JW
    Stogy likes this.
  24. 26 T Ford RPU
    26 T Ford RPU
    The other side. I have some friction shocks that i want to use but may not work now unless i have the whole unit outside the body, may just go with some small tube shocks instead....thinking time! JW
    loudbang, kadillackid and Stogy like this.
  25. AndersF
    AndersF
    Is there a reason you cant mount them on the firewall under the spring facing outwards?
    26 T Ford RPU and loudbang like this.
  26. Who the hell you callin' "old Folks"? Most of us on here are 'seasoned citizens', NOT old folks! Damned kids and hoodlums anyway!
    Dave G in Gansevoort and Stogy like this.
  27. It looks like there is more room in there than I would have guessed. To get a perspective... how tall are you?
  28. 26 T Ford RPU
    26 T Ford RPU
    5' 8'', when seated i am as tall as a 6 footer. I can also straighten my legs between the pedals. JW
    loudbang and Stogy like this.
  29. 26 T Ford RPU
    26 T Ford RPU
    I have't looked at that yet but a good point. I wanted them just above the top tube but i had to put gussets there when i needed to cut the ch***is for spring clearance. I wanted just the arm sticking out and the top body over the drivers area will hinge at the nose, i don't wont a big gap in the body to clear the shock when lifted. I may just make a mount and have the whole of the shock outside the body. Will get some mock up pics posted tonight. JW
  30. 26 T Ford RPU
    26 T Ford RPU
    These are the shocks for it. I 'am trying for a vintage look as much as i can and really want to use them but not at the risk of it looking Fugly for the sake as using them. JW
