Projects And So It Begins
Discussion in 'Traditional Hot Rods' started by Piewagn, Jul 14, 2019.
  1. Piewagn
    Piewagn
    I had to extend the radiator support rods....the new rad along with the grill were tilted to much rearward for my liking....I think this got it! Finally got my tri power dialed in and changed some wiring around. She started acting up the night before TROG so I drove my truck down. My rides have been getting longer and at greater speeds....she feels ******** GREAT!!!
    Thanks everyone!!!
  2. Piewagn
    Piewagn
    Got the tri power dialed in and drove a **** ton of miles this weekend! Just some small annoying issues like the clutch pedal arm s****ing the toe board and make a horrendous screech. Just need to clearance it some more.....the left rear drum contacts the backing plate or the outer edge of the brake shoes on left turns intermittently....yes, the axle nuts are torqued to spec. It’s not so bad that I can’t live with it. I’ll probably address it when I install my parking brake cables. All in all, I’m thrilled with it......AND I think I nailed the stance! Hope everyone had a great weekend! C5E51D97-7442-4373-8CED-543CA173537A.jpeg
  3. High test 63
    High test 63
    Your coupe looks SO good!
  4. Piewagn
    Piewagn
    Thanks Bro!! Been quite the journey.... Now I need to become an alliance member so I can get my HAMB badge! The support from everyone here has been tremendous, a priceless resource for info and motivation! Thanks for droppin' in!
  5. Stance is great. Well done. I appreciate anyone that can handle all disciplines-ch***is, body, interior, drivetrain, wiring-you are a five tool hot rodder, to use a baseball term!
  6. Piewagn
    Piewagn
    Thanks HB! I’ve picked up a few skills throughout my career in auto repair and body repair. My transition to machinist has been a blessing both mentally and physically aside from adding new skills to my ****nal. I still have to break out the wife’s sewing machine and make up some interior panels and removable a tonneau cover for the roof. Your support and motivation has been greatly appreciated!
  7. Piewagn
    Piewagn
    Same size my ***!! In the larger tube I found some remnants of a size that looks like it was ground off...the baby power enhanced it....AND they’re supposed to be Air Loc tubes! Seller being shady or supplier?
    No effing wonder I was springing leaks!!
    160BC3F5-987C-4F2C-94F9-2B68F46E4E81.jpeg 950CB14F-428A-4E3A-9191-0D6E0D160776.jpeg
    oliver westlund, Stogy and loudbang like this.
  8. Mart
    Mart
    I'm glad you pushed the top of the grille and rad forward. I thought it was a bit "off" before but didn't say anything. Didn't want to be a negative Nellie.
    Looking great. It just keeps getting better.
    Mart.
    Big mike 1968, loudbang and Piewagn like this.
  9. Piewagn
    Piewagn
    Thanks Mart! Just got back from a blast.....she's rollin' now!
    Yeah....when I installed the new radiator and moved the bracket I knew it was off....just finally got around to making the adjustments. I need to go check out your Holley 94 video....looking forward to it. I appreciate all your input Mart, you've contributed more than you know!
    Big mike 1968, Stogy, brEad and 2 others like this.
  10. Piewagn
    Piewagn
    Took a blast up to Matt’s at Irontrap to pick up a set of rear wide 5 drums. First long haul with the coupe and she performed flawlessly!! Up to 60mph sustained with no fwinky or wonky shakes, noises or vibrations.....just a plain old joy to drive! As soon as I get my accessory socket wired and a good camera mount, I’ll be getting some road trip videos.....until then, enjoy the rest of your weekend everyone!!
  11. I'm slightly jealous you lucky *******! Thanks for the updates, ty
  12. Piewagn
    Piewagn
    :D:D:D
  13. loudbang
    That is some great news. Looks like all your hard work paid off. :)
    Big mike 1968 and Stogy like this.
  14. Piewagn
    Piewagn
    Yes LB! Still have some things to finish like the removable roof tonneau and I still haven’t decided on a trunk latch system. I’ve got some old tool box latches and some more modern stainless latches, or I could go with the leather strap tie downs. Speedo is acting up, it needs lube ( thought I hit it good enough ) and it’s reads too slow.... Also have my interior upholstery to do. Gotta get the wife to break out her sewing machine! Little things will be coming together and I’ll keep everyone posted.....thank you all for the support!
  15. RodStRace
    RodStRace
    Having the trunk lockable is probably a good idea.
    You could go with a vintage look or a simple round key tumbler with a popper spring.
  16. Piewagn
    Piewagn
    Yeah....still batting some ideas around in my head. I do have several different types of locking levers with keys, but I don't want it to look "too new" or outta place. Thanks for the input Rod!
    Big mike 1968, loudbang and RICH B like this.
  17. The 37 ford trunk latch is pretty cool
  18. Piewagn
    Piewagn
    I’ll have to look into that Os! Thanks for the input!
  19. Piewagn
    Piewagn
    Saved myself 100 bucks and made my own cross braces....finally got around to installing them. I didn’t like the look of the hole saw method to relieve the side rails, so I used my 3/4” spot weld cutter and a wood chisel to carve them out. Came out pretty smooth.... Now I can start on my tonneau cover!
    A074E89D-1B85-4DF8-8C7C-AB57B27A584E.jpeg F96BFBB7-8E43-41FE-8963-1A76981073B3.jpeg 4C613853-A41D-4006-B574-17C0AF2B48E3.jpeg C0D947F7-606A-4E20-AD38-CB61A629EAB5.jpeg
  20. Piewagn
    Piewagn
    Holy ****! Coupe was using too much gas, plugs looked fat and it felt “squishy”. So I did some tinkering....took the .052s outta the primary and intalled .051s and swapped the .050s in the secondaries for .049s and installed 3.5 PVs....and holy s**t did this thing wake up! I still need to move the accel pump over a hole to address a slight blip when accelerating lightly from cruising speed and see if that corrects it. I may just install the leather accel pumps I picked up.... will report back....Happy camper here! Happy weekend everyone!!
    Big mike 1968, Tim, brEad and 8 others like this.
  21. Piewagn
    Piewagn
    Drove it to work today! Beautiful afternoon for the ride home...70mph down the highway.....
    It's still using too much gas and I gotta figure it out. I'll get it....just some trial and error. I did dig out the material for my roof tonneau and ordered the snaps, also got some backing for the door and kick panels. Time to dig the wife's sewing machine out! Will do***ent that process too.....have a great evening fellas!
  22. RodStRace
    RodStRace
    How did all your co-workers who doubted you react to a commute in the rod?
  23. Piewagn
    Piewagn
    They still can’t believe it Rod! They look at it and shake their heads in disbelief.....but then say “you did good”.....
  24. RodStRace
    RodStRace
    I think this is the first picture from the workplace, showing what this started from.
    Those guys just don't have vision!
  25. Piewagn
    Piewagn
    Wow.....I had a vision alright! Thanks for the post Rod, It took me right back to standing there and staring at that and going through my head my next move. Seems like ages ago......
  26. Piewagn
    Piewagn
    Made this nifty glove box handle at work today....some s**** br*** pipe and a couple old stainless cap screws....turned the screws down to fit and pressed them into the ends of the pipe....turned it all down in the lathe to same diameter and rounded the edges. Made the stands out of smaller pipe and polished it all up!
    Not bad for a hairlip as my Father used to say.....never got the reference though....haha.... Anyway, taking care of the peripheral things... I keep hounding my wife to break out the sewing machine so I can do my removable roof cover and interior panels! Still gotta get some type of carpeting and also finish installing the sound deadener.... I’ll update when I get there...happy weekend fellas!!
    4A78A654-BE10-49C3-AF33-9771F584FEFE.jpeg EB61AC73-BE7E-4EFA-AB97-5AB62EBC0E37.jpeg
  27. Piewagn
    Piewagn
    Only have one hole left to fill!!
  28. brEad
    brEad
    Looking good! I really like the glovebox handle!
    Piewagn, loudbang and Nicholas Coe like this.
  29. Piewagn
    Piewagn
    Thank you! I couldn’t see spending the money for a stock looking 36 knob when we had plenty of s**** at work to make one that more matched the theme...I was afraid it would be too heavy and overwhelm the magnets I’m using to basically latch the door closed....but I’ve hit some decent bumps and so far so good!
    brEad and loudbang like this.
  30. Piewagn
    Piewagn
    Yea or nay on the caps? Of course I’ll be finishing them and they’ll go on with the trim rings I have....whaddya think fellas?
