Technical Engine ID?
Discussion in 'The Hokey Ass Message Board' started by MFG, Oct 31, 2021.
  1. MFG
    MFG
    So I bought a 1937 Plymouth with an updated engine. The value covers say red ram dodge but the carburetor is a gm so I’m a little confused as to what I actually have for an engine. Here’s a couple of photos. I’d like to know what I actually have so I can put an automatic transmission in eventually this winter
    Deuces and kidcampbell71 like this.
  2. macdave06
    macdave06
    Somebody correct me if I'm wrong but I'm pretty sure that's a 241ci "baby" hemi
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    I moved this to the main board so more people will see it. You are going to have to find the casting numbers and the stamped ID numbers before it can be completely identified
    Desoto291Hemi and kidcampbell71 like this.
  4. phat rat
    phat rat
  5. squirrel
    You have a little Dodge hemi with a Chevy carb on it.
    one little trick in this situation, is to use google to search for pictures of Red Ram hemi engines....and you'll see they look just like yours, except for the carb.
  6. MFG
    MFG
    Okay thanks, so now the next question is what automatic transmission can I use
  7. No ,no ,no,,,,,
    That’s one of those rare GM Hemis,,,,,they just painted Dodge on the valve covers to fool everyone . Lol
    It looks to be a good engine,,,,,should work fine .
    Like Mark suggested,,,,,get the stamp code off the block and it will tell you everything you need to know .
    Those numbers and letters will be located ,,,,stamped in the front .
    In your pic,,,,,right about where the oil fill tube is located,,,,top of block surface .
    1953-1954. Red Ram. 241 CID
    1955. Super Red Ram. 270 CID
    1956-1957. D500. 315 or 325 CID
    You can get the codes in several places,,,Hot Hemi Heads is one of the easiest to find .
    By the way,,,those valve covers doesn’t mean that’s what is,,,,they will fit other engine sizes .
    However,,,only Dodge covers fits a Dodge .
    Also,,,,Chrysler only fit a Chrysler,,,,,and Desoto only fit a Desoto .
    Plymouth didn’t have a Hemi,,,,,it was a Poly .
    Tommy
  8. MFG
    MFG
    Well okay, I kinda wondered why it had a gm carb. I do know that the engine was not factory because back then it would have been a straight 6 and not a V 8. Who ever did the work on the car added front and rear disc brakes and a rack and pinion steering.
    I’m just coming to you guys to get an idea as to what I do have so I can replace the standard transmission with an automatic transmission.
    Desoto291Hemi and loudbang like this.
  9. gimpyshotrods
    gimpyshotrods
    You need an adapter from Wilcap.
    You can go with any garden-variety GM automatic.
    Get the starter from them, too.
    Shifter is up to you.
    You will need to have a driveshaft made.
  10. oldiron 440
    oldiron 440
    Cool looking but only 100 hp, maybe....
  11. phat rat
    phat rat
    loudbang and kidcampbell71 like this.
  12. It's ALWAYS a Dodge!!!
    caseywheels likes this.
  13. MFG
    MFG
    I looked at the engine in front of the breather tube and this what I saw
    D08798. D502-68227
  14. That’s a 1954 Red Ram 241 cid. 2 barrel. 150 HP .
    68227 is the serial number ***igned to the engine .
    Tommy
    Deuces and mgtstumpy like this.
  15. mgtstumpy
    mgtstumpy
  16. MFG
    MFG
    Okay so now we know what engine I have, am I stuck with getting a 727 automatic transmission or can I use something else
  17. squirrel
    Your question was already answered.
    The 727 was made after Dodge and the other Chrysler divisions finally settled down with their engine and transmission designs, and it won't fit the early Hemis without some effort.
    Desoto291Hemi likes this.
  18. Use whatever ****** you prefer,,,,you will just need the correct adapter .
    Hemi engines have been used with probably every trans ever built ?
    Tommy
  19. 73RR
    73RR
    Hey, what about me ??;)
    OK, some effort, but not m***ive amounts.... Tap the crank flange, bolt on the block adapter , add the flange adapter, flexplate, converter and off ya go.
    And a note to the OP, the 904 series does not fit the Hemi engine due to starter location.
    Desoto291Hemi and squirrel like this.
