Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. j hansen
    j hansen
  2. j hansen
    j hansen
  3. j hansen
    j hansen
  4. j hansen
    j hansen
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Why wouldn't the 1915 Packard have been called the "Twin-Eight" if it had 16 cylinders? Or didn't they want street racers to know what they were packin'?
    Cutlas Fan, LAROKE, loudbang and 4 others like this.
  6. j hansen
    j hansen
  7. j hansen
    j hansen
  8. 1930 British Lanchester, Twin ignition 8.
    motoklas, tommyd, Jet96 and 9 others like this.
  9. j hansen
    j hansen
  10. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That one will also qualify for the unusual radiator photo thread.
    tommyd, Jet96, VANDENPLAS and 3 others like this.
  11. j hansen
    j hansen
    The first few seconds I looked, I did not realize it was the radiator:D
    loudbang and lothiandon1940 like this.
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I wonder what that pulley on the firewall drives? With all that copper plumbing running hither thither and yon it looks like it could be the oil pump feeding a total loss lube system.
  13. 1-SHOT
    1-SHOT
    from Denton
    You need a licensed plumber to work on that.
  14. Deuces
    Deuces
    This thread get moved????....
  15. AmishMike
    AmishMike
    That pulley looks like old type leather belt driven by crank/flywheel. Could it be early RPM counter?
    Deuces and loudbang like this.
  16. stude54ht
    stude54ht
    from Spokane WA
    wicarnut, tommyd, Jet96 and 4 others like this.
  17. j hansen
    j hansen
    From the inside. Skärmavbild 2021-11-09 kl. 06.11.57.png Skärmavbild 2021-11-09 kl. 06.12.31.png
    Cutlas Fan, wicarnut, tommyd and 7 others like this.
  18. j hansen
    j hansen
  19. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I'm still confused. Nevertheless, I love the look of all that br*** and copper. The Br*** Era - my my.
  20. Looks like the birth of steampunk.
    tommyd, VANDENPLAS and j hansen like this.
  21. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    loudbang and Deuces like this.
  22. The Lanchester straight eight i posted ( 1359 ) just up there ^^^^ looks to have the same. Why did the Lanchester design engineer just stick a distributer in the valve cover.
  23. noboD
    noboD
    A friend has two old RRs and I think they are both like that, dual ignition.
  24. treeman53
    treeman53
    I still have the first 10 or 20 issues of Old Car Illustrated around here somewhere...
    loudbang, VANDENPLAS and Deuces like this.
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    One coil fired and one Magneto fired?
  26. Fordors
    Fordors
    I was thinking the magneto is a backup in case the charging system fails.
  27. noboD
    noboD
    One is to start on, other to run on. I don't get it either.
  28. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That is what I guessed. Then I started wondering if the advance was variable on both (either?) systems, and if so, is it the same curve. Were both systems active during cranking?
    I find it fascinating to study these old cars for some common technical thread - like water pumps or fuel systems - and try to get inside the heads of those designers who made them to see why they did it that way. Its because I was an automotive engineer in a former life.
    loudbang and Fordors like this.
  29. warbird1
    warbird1
    Fork and Blade connecting rods Archaic? They actually work very well...
    wicarnut, loudbang and j hansen like this.
  30. Fordors
    Fordors
    Here’s a couple of photos showing the George Riley SOHC engine. I think George used Ford flathead cranks and rods.
    Normally aspirated with Winfield carbs.
    Blown by a centrifugal blower with a Riley carburetor.
    wicarnut, motoklas, 63fdsnr and 10 others like this.
