Technical 3x2 or 2 4bbls
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Oct 31, 2021.
  1. Ron Brown
    Ron Brown
    Considering running a 3x2 holley carb or a 2x 4bll set up on a slightly warmed 350 sbc....
    want alot for the looks but still want it to be usable.
    pros and cons on either setup?
    going in a 1800 lb highboy roadster with TH350
    thankx
    chevy57dude likes this.
  2. swade41
    swade41
    from Buffalo,NY
    To me the 2x4 setup represents horsepower, the 3x2 represents hot rod, something more than the 4 barrel can offer but not up to the point of dual quads.
    It really depends on the build, 3x2 goes good with wide whites, the 2x4 goes well with magnesium 5 spokes.
    I bought a 3x2 to maybe some day replace my 2x4 in my t-bucket, but so far I just can't bring myself to do it.
  3. bchctybob
    bchctybob
    ^^^^ What he said. I have had 3x2s on several cars and I like the look and they ran great but you have to open up the secondary carbs frequently to get fresh gas in them and sometimes that isn't easy to do considering how much a ticket can be in California. Carbking usually recommends dual 4bbls with straight linkage and that does away with that problem. I will be running two 4bbls on the Nailhead in my '33 pickup. I haven't had inline dual quads on anything since the early '70s but they were perfectly fine back then (394 Olds w/2 AFBs) and I have a lot more patience for tuning than I had back then. Your roadster would look good either way.
    jaracer, loudbang and Deuces like this.
  4. Boneyard51
    Boneyard51
    I’m a 3X2s man……just for the looks! Back in the day, three dueces were common, 2x4s not so much in my area. So, it ‘s three ducks for me!
    Bones
    deathrowdave, LowKat, GordonC and 2 others like this.
  5. 41rodderz
    41rodderz
    from Oregon
    Yes sir , 3x2 for the win if you can set them up.
    Deuces likes this.
  6. vtwhead
    vtwhead
    I have had both but prefer the 3x2's as the traditional hot rod setup. Bob is right about keeping fresh fuel in those secondary carbs though. My latest set up will run 3 97's non progressive. That will keep fresh fuel in all 3.
    Boneyard51 likes this.
  7. Roothawg
    Roothawg
    I have both. They each have their place. Personal preference.
  8. BamaMav
    BamaMav
    from Berry, AL
    With 3x2, you can just run the center carb and block the other two off. Hard to run just one on a 2x4 setup.
    Either can be made to look good.
    Deuces and Boneyard51 like this.
  9. Roothawg
    Roothawg
    Sacrilege!!!! Heresy I say!
  10. Elcohaulic
    Elcohaulic
    I like the Tri-Power for looks. They do haul *** though.
    One of my all time favorites is the older Weiand intake with the stars and the Carter Thermo Quad carburetor..
  11. Blues4U
    Blues4U
    from So Cal
    To each their own, but IMO 3 x 2 has been over done. I've gone to 2 x 4 just recently.
  12. carbking
    carbking
    ***uming V-8 engine:
    Performance - single 4
    Looks - 3x2
    Looks AND performance 2x4
    EDIT: There really is no "right" answer. The above summarizes performance potential. Looks is entirely up to each individual. Price will be single four, dual four, tripower, least to most.
    Second edit: here is a link to an article you may (or may not find interesting):
    https://www.thecarburetorshop.com/Multiplecarburetion.htm
    If you read to the end, there are links to other articles with supporting information.
    Your build, your call.
    Jon
  13. 57 Fargo
    57 Fargo
    I see no point In having a multiple carb set up with not all of them functioning, just use them all! I have dual fours (AFB) on a big block in my convertible with straight linkage as per Jon’s suggestion and wouldn’t go back. Looks and runs awesome.
    Deuces, swade41, bchctybob and 2 others like this.
  14. jimmy six
    jimmy six
    I love dual quads. By 56 almost all manufacturers had them and very few had 3-2’s which came later. I personally like progressive linkage but understand those who don’t. I idle on both and have never have a fuel problem with the front one in 6 years. To me sizing is very important especially with street use and a non-high performance engine. (think 245 hp 283 here)
    My opinion is they both say Hot Rod. It’s also personal that I like stock or stock appearing air cleaners on them.
    Deuces, carbking and bchctybob like this.
  15. de-fenders
    de-fenders
  16. nochop
    nochop
    from norcal
    I kind of like the idea of tooling around on a two barrel, then stomp and open up all six.
  17. 6sally6
    6sally6
    2.32 mining nose gold!.jpg IF......you're not gonna cam it.....and have at least 9.5:1 CR either /or will run like a dawg but 'may' impress the "air-head millennials " who stare and 'axe' stupid questions at car shows!
    2-fours with a snotty cam and plenty of thump at idle .........they do tend to get me aroused at the cruise-ins!!o_O
    Like a snotty nose............YOU PICK!
    Your choice
    6sally6
    rpm56, jimmy six and Roothawg like this.
  18. olscrounger
    olscrounger
  19. Mike_B
    Mike_B
    I agree that the car's style is a factor. I put a 2x4 setup on a 350 in a friend's 37 Chevy. Carbs are Edelbrock 500 cfm models. Progressive linkage starts opening the secondary at around 2/3 throttle, I'd guess. I'd have to check my notes, but I think both idle circuits are adjusted as usual, and I did some jet & rod changes based on suggestions from Edelbrock and others. The setup has zero issues, and is as well behaved as a single well-tuned 4bbl.
    Deuces and olscrounger like this.
  20. Blues4U
    Blues4U
    from So Cal
    LOL, I've never had a problem with fuel sitting in the secondary carb too long either! I guess we have lead feet Jim! :D
  21. I vote 3 4s or 4 2s
    Deuces and Almostdone like this.
  22. brigrat
    brigrat
    from Wa.St.
    bchctybob, dana barlow and Deuces like this.
  23. Dooley
    Dooley
    from Buffalo NY
    You run 2 fours.... never knew that
    BTW I'm still thinking of that one you offered awhile ago
    Boneyard51 and Deuces like this.
  24. 3 X 2s look cool, and properly tuned work very well.
    I've never had a problem keeping fresh fuel in the outside carbs, but I'm not about to let the throttle linkage go without proper exercise for long. :cool:
    2 X 4 would be ok too though. :)
    Boneyard51, Deuces and Blues4U like this.
  25. birdman1
    birdman1
    Nothing says hotrod like 6x2s on a 430 Lincoln
  26. belair
    belair
    3x2 for "the look," 2x4 for bad***ery. I like the spaces between the carbs on a 3x2, and the three air cleaners. 2x4 can just look like a lump sitting on the intake.
  27. 55blacktie
    55blacktie
    To quote Blind Faith, "Do what you like."
    1929rats, wvenfield and Deuces like this.
  28. 55blacktie
    55blacktie
  29. 55blacktie
    55blacktie
  30. Jessie J.
    Jessie J.
    3x2s was the go to hot flathead setup from the 40s into the 50s, thus early on took the crown of being the 'traditional' setup.
    4 barrel carburetors did not become available until the early 50s, (1952)
    but when they did, half a dozen companies rushed into producing and selling aluminum 2x4 manifolds within months.
    Think about it. With 2 four-barrel carbs you have equivalent of 4 2 barrels, without all the leakage, linkage, and tuning problems that plagued the traditional 4x2 carb setups.
    Factory production 3x2s carburation after 1953 was no longer the actual 'Hot' setup, but the traditional eye candy bling that old and moneyed luxury cars buyers demanded.
    Cadillac going from 2x4s of '55-'57 to the 3x2s of '58-'59 was actually a step backward in both technology and in performance. They made up for it with increased displacement, but a 390 still gives its best when fitted with 2x4s. GTOs too.
