Technical 392 hemi dimensions
Discussion in 'The Hokey Ass Message Board' started by Jasoncamaro, Oct 29, 2021.
  1. Jasoncamaro
    Jasoncamaro
    Hi I’m looking for dimensions the block and heads of a 392 Hemi , I build models and want to cad draw and print a 392 hemi
  2. mickeyc
    mickeyc
    To find dimension details that precise you probably would need
    have an actual motor on hand to reference as you proceed.
    Other than that you would need actual blue prints from the
    original Chrysler development of said motor. I am no expert
    someone else may know of a source for these specs.
    Jasoncamaro likes this.
  3. Hnstray
    Hnstray
    from Quincy, IL
    @Jasoncamaro
    This is a 392 drawing. The bore is 4”. knowing that, it is possible to extrapolate the width and height from this drawing.
    I have a book at home that has diagrams/dimensions, but I am currently a 1000 + miles from home. I will try to remember to look that up and post here after I return home in a few days.
    Ray
  4. Ricco39ford
    Ricco39ford
    Here are some dimensions I found. Could take some off my block, let me know what you want. Total length and width, height? 19E60C83-36F1-4620-B827-6288E642D82F.jpeg
    mgtstumpy likes this.
  5. Guy Patterson
    Guy Patterson
    A possible source could be Hot Heads I believe on their website they have some images an dimensions
  6. foolthrottle
    foolthrottle
    plastic moc up long block
      28.4 KB
  7. Jasoncamaro
    Jasoncamaro
    Thanks for the help everyone this is helping a lot
  8. Jasoncamaro
    Jasoncamaro
    I will get some pictures and mark the dimensions I need if you don’t mind . Do you have a bare block ?
  9. Ned Ludd
    Ned Ludd
    mgtstumpy, Jasoncamaro and XXL__ like this.
  10. Ricco39ford
    Ricco39ford
    Yes have bare 392 block
  11. Ned Ludd
    Ned Ludd
    I downloaded the abovementioned SketchUp model, and ran a render without editing anything:
    The shapes have been simplified a lot, doubtless to keep the filesize down, but it's convincing enough on my monitor at ten paces. The fan seems to be a mirror image of what it should be.
  12. 4tford
    4tford
  13. Jasoncamaro
    Jasoncamaro
    I’ll sort what I need tonight
