Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. LAROKE
    LAROKE
  2. David Gersic
    David Gersic
    from DeKalb, IL
  3. winduptoy
    winduptoy
    Back on the ground, reverse eye spring under the front end. It will have to do.
    Hitting and straightening fenders with NO dual side mount spares
  4. OL 55
    OL 55
    Timing cover (balancer) seal.
    lothiandon1940 likes this.
  5. RICH B
    RICH B
  6. junkyardjeff
    junkyardjeff
    Got the trans installation finished in the sunliner and have other things to do to it while its on the stands,its always had a exhaust leak that I think is a cracked exhaust manifold and now is the time to fix.
    bchctybob, Joe Blow, RICH B and 2 others like this.
  7. lake_harley
    lake_harley
    Not really a big visual change from just a few days ago, but I'm pleased to report this is the latest picture of my Model A after having driven it the first time....about 2 miles. Seems like it's been a long time coming but it was worth the wait and the work. It actually drove pretty nicely!
    Lynn
  8. Papas32
    Papas32
    from No.Ia.
    nice coupe!
    Lil32, 61Cruiser and lake_harley like this.
  9. leon bee
    leon bee
    My 46 pickup, I don't have much of a bed to put on her. My friend Bob found me this wrecker boom. Here it is pulling my brother's heavy *** F150 up our hill to rewind the cable. Remember, it's all just for fun............or maybe compulsion:
    reagen, stanlow69, bchctybob and 10 others like this.
  10. Marty Strode
    Marty Strode
    I spent the morning transporting painted parts for my '40 PU, and the afternoon getting the ch***is out of storage, for completion this Winter. IMG_7942.JPG IMG_7945.JPG IMG_7946.JPG
  11. Blues4U
    Blues4U
    from So Cal
    Spent a little time dialing in the new dual quad carbs, it was loading up at idle, causing the engine to stumble, and blowin' some black exhaust when clearing it out. I leaned out the idle air/fuel screws a little and smoothed out the idle, I'll probably have to mess with it more but it's running better now. Then I took her out for a full tank of gas, 9 gallons worth, at the cheapest station in town, $4.09 per gal. (be careful who you elect to your state government....) That's up over a dime since the last time I filled it. Anyway, brought her home and wiped her down, ready for the poker run tomorrow. I'm hoping she runs good when were out there a****st all the other hot rods.
    I also brushed off the 47 coupe and wiped her down good. She'll have to wait till Sunday to get to stretch her legs.
  12. RICH B
    RICH B
    Made a little box thing to go behind the speaker grille and let air out. Forgot to bring the torch; so had to use the wire feed on this thin stuff. Makes for the whatever they are called bumps on the inside. Started to cut down the depth of the glove box and learned the vendors patterns are off; never had a problem with other year repop boxes, maybe it's a '41 thing.
  13. fastcar1953
    fastcar1953
    Tried to get the boys in some fall photos. 253394902_4840082976015950_3850555868604382611_n.jpg 253968512_4840081766016071_4878672789015320573_n.jpg
    john W., Stock Racer, reagen and 22 others like this.
  14. Jkmar73
    Jkmar73
    from Tulare, CA
    Got the seat brackets installed and the brake pedal linkage finished.
    Lil32 likes this.
  15. chessterd5
    chessterd5
    from u.s.a.
    NOT A DAMN THING!
    I wonder if it will ever get done.
    210superair, lake_harley and Lil32 like this.
  16. Blues4U
    Blues4U
    from So Cal
    fastcar1953 and j hansen like this.
  17. I have been trying to free the rear brakes on my OT project hauler. its not a hot rod but it is mine.
    There is some pieces of a hot rod in my garage and I did give them a good look. Does that make me a hot rod ******? LOL
    Joe Blow and Blues4U like this.
  18. Blues4U
    Blues4U
    from So Cal
    Oh yes! Took the pickup on a poker run this morning, first outing with the new carbs, Damn, it runs good! Really stoked with the way these worked out. Not perfect, but really close, and damn it sure runs better than the dual 2 barrels I had on there before. Really responsive, very smooth, no hesitation; well, maybe a little here and there, but much better than before, pulls cleanly in top gear from down low, and really strong. I'm feeling good.
    I'll post more photos later, maybe a separate thread, here's the lineup when I got there.
  19. David Gersic
    David Gersic
    from DeKalb, IL
    Washed off the bugs and dirt from last weekend’s trip. Rolled in to the garage, parked for the winter. I’ll change the oil and winterize it, probably next weekend along with changing the garage over to “winter” configuration.
    I don’t mind winter weather, but it does kinda **** to be off the road for the next few months.
  20. Lloyd's paint & glass
    That looks so damn good!
    bchctybob and Blues4U like this.
  21. alanp561
    alanp561
    10 MPG!!! Loaded or empty:(
  22. buzz4041
    buzz4041
    from Texas
  23. TA DAD
    TA DAD
    from NC
    I am still moving forward. I finished the radiator support and got the radiator and the trans. cooler mounted. I need a upper hose and some plug wires, a battery ( they have went through the roof ) and a few other odds and ends I am still undecided about a fan I am leaning towards a clutch set up if it will fit. studebaker build 006.JPG studebaker build 007.JPG studebaker build 008.JPG And I have to make a driveshaft loop. Then it will be on to putting some brake fluid in and see about getting some stopping power!
    leon bee, Lil32, Jalopy Joker and 3 others like this.
  24. Blues4U
    Blues4U
    from So Cal
    Thank's man!
    Lloyd's paint & glass likes this.
  25. Jalopy Joker
    Jalopy Joker
    - whatever fan you decide on be sure to install a full fan shroud - that large trans cooler location may block/disrupt direct air going through radiator
    uncleandy 65 likes this.
  26. TA DAD
    TA DAD
    from NC
    Yes , a fan shroud is on the list.
  27. RICH B
    RICH B
    Convinced the glove box liner to fit and made the final cut off the depth. Made a hammer form out of some s**** wood and beat on some aluminum for a new back wall. Even a special double hole pattern in the aluminum cause **** happens. Need to glue some black vinyl on and rivet it in place to finish.
  28. buddyamigo
    buddyamigo
    from HoustonTX
    The clock in my car has never worked. Discovered that an option for my car when new was a stem-wind clock made by Westclox. After a several year hunt, finally found one in good working order. So, I’m now the only kid on the block with a wind-up dash clock! 80DD4E27-B5B9-407B-9686-C03B3E85E5ED.jpeg 7A34B6C3-617D-4FC5-8FD6-697DB6D36C34.jpeg
  29. junkyardjeff
    junkyardjeff
    Got the trans installation finished and road tested.
  30. Taboo56Chevy
    Taboo56Chevy
    put new air cleaners on my 33
