Projects 1932 Ford "Freedom Roadster" Build
Discussion in 'Traditional Hot Rods' started by Lancer, Oct 31, 2021.
  1. Lancer
    Lancer
    After owning this car for two years now I'm finally able to get some work done on it. I'll be posting images from the last two years to get caught up to current on the build. These photos are from the day I picked it up, with help from my Brother. Check out the stripping on the firewall circa 70s? Would love to know more about the artist. I'll post more on that soon.
    thumbnail_IMG_1560.jpg thumbnail_IMG_1559.jpg thumbnail_IMG_1558.jpg thumbnail_IMG_1533.jpg thumbnail_IMG_1528.jpg
  2. brady1929
    brady1929
    Very cool.
    Stogy, loudbang and Lancer like this.
  3. SPEC
    SPEC
    Excellent project.
    Stogy and loudbang like this.
  4. Lancer
    Lancer
    Where the name came from. Lucky Burton made this for me and it will work perfect.
  5. Stogy
    Stogy
    Bring it on, and thanks for bringing it on...to the Hamb...:D
    positive of the Striping timeline @Lancer?... This is all new to me so a belated Ya LuckyGuy!!
    brady1929, loudbang and Lancer like this.
  6. Lancer
    Lancer
    @Stogy Not sure of the timeline for the pinstripping. Here is a close up of the signature. I was told he was known by the Kustom Kemps and did a lot of stuff in the mid west. IMG_2736.jpg Thats where the timeline guess came from.
    elgringo71, Outback, 303racer and 7 others like this.
  7. Stogy
    Stogy
    brady1929 and loudbang like this.
  8. Anderson
    Anderson
    That’s the one Flip was putting together a while ago. Good start!
    Outback, loudbang and Stogy like this.
  9. Lancer
    Lancer
    Very cool, looks like my guess about the timeline was pretty close. Didn't realize he was that well known. I did some searches on the name two years ago when I got the car but didn't find anything. I think I even posted on here about it. To bad the links don't work on that 12 year old thread, but its great to have that info now. Thanks @Stogy
  10. Lancer
    Lancer
    @Anderson sure is the same one. Got it from Flip two years ago.
  11. Stogy
    Stogy
    There are quite a few mentions in the Hamb archives...certainly an active artist a****st the Striping circle and like all of them he has his own style...
    :rolleyes:...I was looking at that striping on the cowl and being a visual artist I many times see things others may not...
    Perhaps it was intentional maybe not but there is a bizarre/kooky face/head if you look at it closely with pie shaped gl***es... wild hair, a stash and that larger hole in cowl near the bottom just off to the right of center looks a bit of a kooky mouth...the bottom center of the cowl could also serve as a more life sized mouth but either way I am chuckling looking at it...
    The bluish areas off to the sides of the cowl below center look like bluish clouded sky...
    I am working on an little something to bring that out and will share it in a bit..
    Again it could be a mere coincidence but I saw it nearly immediately...
    So what's the plan. @Lancer?
    Flatty, Hemi, Smallblock?
  12. Lancer
    Lancer
    @Stogy I see exactly what you are talking about. Once the engine is in place you wont be able to see it though. Plans are for a 292 Ford Y-Block, World Cl*** T-5 and a Ford 9" with Posi. I have all of the drivetrain now, just getting it sorted out. Main focus right now is getting the Banjo out and the brackets welded to the 9". Going with ladder bars. Lots more photos to come.
    34 5W Paul, loudbang and Stogy like this.
  13. Roger Loupias
    Roger Loupias
    Cool car, have a great build and guard that firewall.
    Outback, Lancer and Stogy like this.
  14. Dan Hay
    Dan Hay
    There's some MK John work on my dad's 38 Chevy, done at Des Moines in 83-84. I'll post up a pic later.
    brEad, loudbang, Lancer and 1 other person like this.
  15. Lancer
    Lancer
    Awesome Dan!!!
    Dan Hay and loudbang like this.
  16. Lancer
    Lancer
    Couple more photos, getting it ready to pull the body off.
  17. Stogy
    Stogy
    Sniffing Flathead...Hello 292...
    Coming Up!!!
    Have fun with it @Lancer...It has that look happening...
    Credit to All That Inspired This
  18. Lancer
    Lancer
    Pretty cool man, pretty cool.
  19. Lancer
    Lancer
    Body is off the frame now. Found an old cart locally that makes a perfect dolly for the body.
  20. Lancer
    Lancer
    So, my plan has been to run a Y-Block 292 that I had picked up and a 5 speed. But, this weekend I had a 1956 Y-Block with 55K original miles with matching 3 speed with overdrive fall into my lap. Now I am rethinking and considering running the 3 speed/od instead. I just need to find a floor shifter for it. Anyone have a line on a floor shifter for a top loader 3 speed? Yblock 2.jpg Yblock 3.jpg Yblock-1.jpg
  21. Lancer
    Lancer
    Outback likes this.
  22. Lancer
    Lancer
    It's now in lot of pieces. Block sanding is taking place, which is interesting. Never sanded on a gel coat before. Needs work to fit the doors properly. They will take some time, and cutting. I keep going back and forth on whether to punch louvers in the deck lid. What do you think? These photos are a month or so old, more work has been done, I need to get some more photos taken. Photos are mostly in order. 279189525_10151525818774946_5790523861157913418_n.jpg 279199485_10151525818789946_3347038449188501506_n.jpg 279164887_10151525818784946_9035431784964399794_n.jpg 279254530_10151525818769946_4008797730445359547_n.jpg 279158766_10151525818764946_51096133066230658_n.jpg 279126975_10151525818779946_3051250245394346936_n.jpg 279192358_10151526172989946_3698509021915039375_n.jpg 279167592_10151526172984946_2137185778722082292_n.jpg
    Outback, Stogy, guthriesmith and 2 others like this.
  23. Dan Hay
    Dan Hay
    I know that body has inner structure of some sort, but I wouldn't mess with door gaps until it's back bolted on the frame.
    Looking good!
    Also, I saw my post in this thread from last year promising a pic of MK John work on my car. Here ya go, better late than never! IMG_3448.jpg
  24. Lancer
    Lancer
    Funny, and yes, 100% on adjusting back on the car.
    Stogy and Dan Hay like this.
  25. Lancer
    Lancer
    I was able to get my deck lid in primer over the weekend. 284374512_10151537604784946_4414860629679622895_n-1.jpg
    oliver westlund, Stogy and lucky ink like this.
  26. Lancer
    Lancer
    Was able to get more parts pulled off and more blocking done. The doors are going to be the most work. They need work in every area. The firewall is cherry though, pretty stoked on that part. Its the only part I don't have to touch.
    279524201_10151528516224946_5643892679171599439_n.jpg 279433553_10151528516204946_6729448948065033667_n.jpg 279261882_10151528516229946_3162893205452009009_n.jpg 279508955_10151528516219946_4926707843442551740_n.jpg 279426061_10151528516214946_3796157088396697380_n.jpg
    Stogy, Just Gary, Outback and 3 others like this.
  27. Atwater Mike
    Atwater Mike
    Nice project. Is that roadster mfr. a 'Rodbod'?
    Stogy and Lancer like this.
  28. Lancer
    Lancer
    I've not been able to find any markings with a manufacturer's name.
    Stogy likes this.
  29. Lancer
    Lancer
    Deck lid primed and guide coated.
    284374512_10151537604784946_4414860629679622895_n.jpg 287312508_10151541354214946_928785133318653707_n.jpg
    Stogy, Just Gary and Outback like this.
  30. Outback
    Outback
    from NE Vic, Oz
    I like your plans, cool striping, thanks for posting!
    Stogy likes this.
