Technical 3x2 or 2 4bbls
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Oct 31, 2021.
  1. Ron Brown
    Ron Brown
    Im actually moving toward the triple holleys
    Deuces and Boneyard51 like this.
  2. bchctybob
    bchctybob
    I just sold this setup a month or so ago. I got it in the deal with my ‘28 coupe, brand new. It just didn’t fit the build style of any of my cars. I thought about using the carbs on the 375 hp 396 bbc I have under the workbench until I saw what the bbc Chevy tri-power manifolds go for these days, yikes!!
  3. nosford
    nosford
  4. Blues4U
    Blues4U
    from So Cal
    That is purty!
  5. MeanGene427
    MeanGene427
    from Napa
    In the case of the FE setups, the 3x2s were stronger than the factory 1x4s of the day- but if you've ever seen those old 1x4s, they are very flat and not too efficient. The low riser 2x4 was a pretty good step up, but still pretty "low"- but can run quite well on a street car. The good one for street (and brackets) use is the "regular" medium riser 2x4, which is what is on my Galaxie- they run very well. Then you move up into stuff like the Tunnel Wedge, and start giving up low end for top end boogey. Hard to beat the looks of any of them. There are folks who can make the 3x2 run pretty well, but it takes a huge amount of work, different carbs etc. On that note, my next-door schoolmate, Larry Kirkum, has been doing pretty well in FAST racing with his '68 427-435 3x2 Corvette (not an L88), running 9.50's on Wide Ovals
    https://www.hemmings.com/stories/20...turn-9-second-p***es-all-day-long-in-michigan
    loudbang, bchctybob and Boneyard51 like this.
  6. Tickety Boo
    Tickety Boo
    from Wisconsin
    Wow I read the story thats impressive on wide ovals, had to be somewhere around a 1.500 60 ft time :cool:
  7. 4tford
    4tford
    I'm running two 4's with progressive linkage in my 40 Ford runs great with that setup.
    Jessie J., olscrounger and bchctybob like this.
  8. MeanGene427
    MeanGene427
    from Napa
    Yeah, he took machine shop in high school and has done very well. FAST cl*** is interesting, has to LOOK stock, but inside, lotsa goodies
    bchctybob likes this.
  9. rladams65
    rladams65
    3x2 looks very cool.
    2x4 gives more power and is easier to maintain.
    Aesthetically speaking - I think 3x2 is Hot Rod esque, while 2x4 feels like a racer. They both are pretty fancy setups really.
    The engineer in me struggles to get behind dividing 6 barrels into 8 cylinders, but that is simply my own neurosis bubbling up
    Deuces and olscrounger like this.
  10. bchctybob
    bchctybob
    So come on Ron, don’t keep us in the dark. How about some before, during and after photos?
    Deuces likes this.
  11. Ron Brown
    Ron Brown
    I will do that....
    bchctybob and Deuces like this.
  12. GlassThamesDoug
    GlassThamesDoug
    I like 2x 2bbl holleys....on a 2x 4bbl intake. Typically without a blower. I like the early offy dual 4, or TR1X Tunnel ram. 20211107_093728.jpg
    bchctybob, Tickety Boo and Deuces like this.
