Projects S.E.G.A. Olds build
Discussion in 'Traditional Hot Rods' started by Saturn V, Oct 11, 2021.
  1. Is Australia too far? Quain, there's some folk here in Adelaide that dig SEGA. 191116SthnFlyerJPG-copy.jpg
    winr, Outback, OahuEli and 5 others like this.
  2. COCONUTS
    COCONUTS
    This thing started heavy, are you replacing the metal with 20 gage or going with something thinner. I once had a buddy replace the rusted floor metal with alum. from a folding card table.
    bobss396 and Saturn V like this.
  3. Saturn V
    Saturn V
    from Killen AL
    The inner rockers we made out of 16 ga. Firewall and toe boards out of 18ga. The floor pan was for a 56 Chevy. It's a cheap aftermarket piece. About 22ga.
    If I knew then what I know now about what's legal. I would have taken a different approach to the build. I'm too far into it to start over.
  4. Saturn V
    Saturn V
    from Killen AL
    Been having phone/ camera issues. Older photos won't download.
    winr, brEad, TFoch and 10 others like this.
  5. Ericnova72
    Ericnova72
    from Michigan
    You are correct, the "DX" block is super thick, and can be stroked out to 445" or so IIRC. I have seen a 442" version incidentally, (serendipitous number for an Olds guy LOL), along with a 380" which was more common.
    Seems like they stroked a 330" crank to do it??
    The Chevy guys used to modify the 6" SBOlds connecting rod for use in a SBChevy, back in the days before budget friendly 6" aftermarket rods were available, back when your choices were reworked stock rods, $$$ Carrillo race rods, or $$$ and short lived aluminum rods.
    OahuEli, mad mikey, Just Gary and 5 others like this.
  6. DDDenny
    Or these.
    winr, Outback, Spoggie and 1 other person like this.
  7. Brand Apart
    Brand Apart
    from Roswell GA
    Looking forward to this. Not sure about your Trans plan fitting the SEGA rules though. Did Quain miss that. Or am I wrong ? Anyway keep at it simple enough to change that if necessary.
    Saturn V, loudbang and Dick Stevens like this.
  8. Saturn V
    Saturn V
    from Killen AL
    I talked with Quain on the use of the 5 speed trans. We're allowed to use the trans, just not the 5th gear. He gave me options on what I could do with shifter options and modifying the trans too.
    Plus I've planned the crossmember fab to allow for future mods. I'll get pics of it and post them later in the week.
  9. WanatahHustler
    WanatahHustler
  10. Saturn V
    Saturn V
    from Killen AL
  11. Saturn V
    Saturn V
    from Killen AL
    Seeing how I feel the need to run a Olds. Just about everything has to be made! Motor plate and mid plate. IMG_20211107_154505481.jpg IMG_20211107_154342357.jpg
    winr, brEad, Outback and 12 others like this.
  12. We used to use the DN as a 4 speed in Super Stock. 5th had to be blanlk, but nobody ever looked. You would need a completely different shifter to use 5th anyway. You have the option to under drive 4th, which might be the hot ticket with the Olds ;-)
    Joe Travers, AHotRod and Saturn V like this.
  13. Make sure your Doug Nash is good to go. I bought one that had been professionially built but they tend to pop out of 2 or 3 with not noticable wear. Sold it to a Bonneville guy in the middle of Speedweek and it turned out to be junk for him. Long story
    Saturn V and loudbang like this.
  14. Saturn V
    Saturn V
    from Killen AL
    Thanks for the advice. Every part on the car will be gone through. If it's a used part. I will at least tear it down and inspect it.
  15. Saturn V
    Saturn V
    from Killen AL
    Steering box mount. Always nice to have a mill handy IMG_20211107_154457411.jpg IMG_20211107_154444253.jpg
  16. seb fontana
    seb fontana
    from ct
    I am surprised that the frame is not boxed from the factory.
  17. Saturn V
    Saturn V
    from Killen AL
    The frame had a x-brace originally. It would have been easier on me if it had been boxed.
    seb fontana and loudbang like this.
  18. Saturn V
    Saturn V
    from Killen AL
    Today's project was the rear shock and mounting. IMG_20211120_141728250.jpg IMG_20211120_141708121.jpg
  19. Saturn V
    Saturn V
    from Killen AL
    Black Friday deals,,,,still working on the rear suspension. IMG_20211126_151454570.jpg
  20. Saturn V
    Saturn V
    from Killen AL
    Almost done with the rear suspension. Found out this era correct is harder than it sounds!!! IMG_20211129_183131845.jpg IMG_20211129_183131845.jpg IMG_20211129_183051947.jpg
    winr, Outback, pitman and 8 others like this.
  21. bobss396
    bobss396
    We had a circle track racer with a car that was legal for one track, went to another and was able to run, but told him to bring it back next week with more body on it. This guy and his brother were always wicked FAST. So he comes back, he used corrugated tin from a garbage-picked swimming pool, complete with the wood grain. With just the car # on the door. I'll say it was neatly done.
    OahuEli and loudbang like this.
  22. Saturn V
    Saturn V
    from Killen AL
    Been having some health issues, so things have slowed down some on the project. Last few weekends we have been trying to finish up the suspension.
    Some blasting and paint, the body will be going back on. IMG_20211211_120824949.jpg IMG_20211211_121001756.jpg IMG_20211211_121024962.jpg
    winr, TFoch, kadillackid and 9 others like this.
  23. Tutashen
    Tutashen
    did you use slugs or any extra sleeving where you joined at the kickup , reason i ask is have never done much car frame stuff an while i don't mind picking up small stuf that breaks off to old to pick up a front end :(
    Saturn V likes this.
  24. Saturn V
    Saturn V
    from Killen AL
    We have plated the frame graft, along with several Rosetta welds along as cutting a hole in both frame rails for the crossmember. IMG_20211107_154403724.jpg
    pitman, bobss396, Just Gary and 3 others like this.
  25. mario711
    mario711
    wishin' you good health .. really love this thread , things going fast ; )
    loudbang and Saturn V like this.
  26. Saturn V
    Saturn V
    from Killen AL
    Hopefully the Drs will get me back to full speed. They're starting treatments for A.S. after new yrs. If they can calm down the joint pain and the fatigue it will help get this project back on schedule.
    I am thankful I have 2 guys that have been there to help get it where it's at now!
    pitman, bobss396, loudbang and 4 others like this.
  27. Tutashen
    Tutashen
    Thx i have done alot of bike frame stuf an used slugs at points that are prone to break , don't have the reflexs to run my bikes anymore , i do have a body, rearend, motor an welding skills , an four wheels you pretty much just driving without the wife :) i bought the body at auction in 1974 an my brother an i have argued bout the build ever since an he just died so i'm going to lay lines for a frame do it his way , i will for sure post the build , you people are all that's keeping me grounded enough to function an thx for that , here in on. canada they are really picky about frames i don't know you could run yours on the street , used 4130 for a plane so i probably stick with that an bend over any hoops they have to certify it , it's light an strong easy to weld an comes from a local airplane builder supply that tracks where an when it was made ect. so streeting should be ok , wish i lived where there were all kinds of tracks to race at with in a few hundred miles now with virus going to grocery store is a big deal let alone crossing the border with a race car , i would love to race a sega car :)
    winr, bobss396 and Saturn V like this.
  28. Saturn V
    Saturn V
    from Killen AL
    Giving y'all a peek at some of the weight savings! IMG_20211216_175142614.jpg IMG_20211216_175119146_HDR.jpg
    winr, Outback, kidcampbell71 and 7 others like this.
  29. UNCLECHET
    UNCLECHET
    I love watching the SEGA races! It's neat to see a SEGA car being built. Subscribed!
    loudbang, Just Gary and Saturn V like this.
  30. Saturn V
    Saturn V
    from Killen AL
    Stripped everything off the frame. Scheduled with the blaster Monday after Christmas. Getting closer to final ***embly for the frame! IMG_20211218_132955907_HDR.jpg IMG_20211218_132937784.jpg IMG_20211218_132912923_HDR.jpg
    brEad, AHotRod, kidcampbell71 and 9 others like this.
