Projects Haven Hills AV8 Roadster Build
Discussion in 'Traditional Hot Rods' started by Haven Hills Auto Club, Jun 20, 2020.
  1. I want to officially start my AV8 Roadster build. My starting point is a ***led 1931 Ford Roadster frame. 36' front axle & wishbone w/ a Millworks reversed eye main leaf. Currently a 36' rear axle & tube w/ a Millworks AV8 reversed eye spring, but I plan on using a 48' Columbia axle. Wide five hubs and rims. 42'-48' juice brakes front & rear. 32' style grille shell. 40's or 50's aircraft fuel tank. 46' flatty 0.60" w/ a Merc 4" crank. Hotton & Sullivan heads and Hexagon intake w/ matching air cleaner. 39 trans w/ Zephyr gears. 36' Ford headlights. 38'-39' Zephyr taillights. Stewart Warner Police speedo, 4500 rpm tach, and N.O.S. gauges. There are many more small bits and pieces as well. I'm trying to keep the build within the 49'-53' era, but I know I already broke that rule with the SW instruments. I'm mainly using Ford parts, with a good mix of period aftermarket. No Chevy parts here. Trying to stay away from California built speed equipment, as this is a Michigan built hot rod. I've made mention of some of the specs in other posts, but this will be the official build thread for the Haven Hills Roadster. 20200619_174635.jpg
  4. Brookville firewall modified with a 32'-34' truck engine dimple. 20200526_122010.jpg
  5. The body is coming from Brookville Roadster. I will be picking it up at the NSRA North car show as long as it is still happening in early September. Till then, I hope to do some engine and ch***is work. I will post updates as they come. I also want to thank the H.A.M.B. community for the vast information and support. This project would not be possible without information in the H.A.M.B.
    kidcampbell71 and ct1932ford like this.
  6. whitewallwilly
    whitewallwilly
    Great start to your project
    kidcampbell71 likes this.
  7. brady1929
    brady1929
  8. Model A Gomez
    Model A Gomez
    Wish I'd have seen that firewall a couple of years ago, I repaired and notched a stocker and cut the slot to use the s**** throttle. No reason the reinvent the wheel, spent a lot of time and effort on a rough firewall. !cid__Photo03061434.jpg 26.jpg
  9. Model A Gomez, if you want, I did post a tech thread posted " AV8 Firewall Modification". I posted the pics of the old and new firewalls. I was going to use the whole 32'-34' firewall, but it was getting to tricky for me. So, I used just the engine dimple. It was so close. I swear Ford used the 30'-31' firewall as a base to design the 32'-34' truck firewall. Very similar lines. It looks like yours turned out good. I don't know yet if I gained any clearance, but the s**** pedal should mount up like it was supposed to be there.
  10. I finally got ahold of a 32' K member. I found them for sale, but everyone I found was butchered, rusted out, or was local pickup only in Cali. Thankfully I was able to get one shipped from Colorado. I was going to use a 46' truck crossmember, but alot of guys said it would mount the trans to high in the ch***is. So, now that I have the 32' K member, I need to find the rear bearing cap to mount the trans in the K member and convert my open drive back to a closed drive. The trans is a 39' with 18/26 Zepher gears. Just counted the teeth today. Parts are ordered to convert everything back to closed drive. 20200801_152620.jpg 20200801_152738.jpg
  11. ct1932ford
    ct1932ford
    Good luck with the build. Looks like you have lots of the right stuff!:cool:
  12. x77matt
    x77matt
    Nice! Good choice of parts so far!
  13. Well NSRA North was cancelled, so we decided to pick the body up at Brookville Roadster. Everyone at Brookville was great. That shop is awesome. Alot of skill and knowledge goes into each body. I am very happy with the end result. The hot rod is right at home with the other projects. Thank you Brookville Roadster. 20200919_134618.jpg
    itsmee, brEad, A Boner and 6 others like this.
  14. Well not much has happened, but I have found some more parts. It's funny how the concept evolves and spirals out of control. Found a 40'-41' Zephyr steering wheel, Parker Products turn signal switch, 49' Merc gauge pods, 100 mph police speedo, N.O.S. Mallory DSM coil, 38'-39' Zephyr taillight ***emblies, early FoMoCo seat belt buckles, Shell Oil license plate topper, and a 32' wishbone. Needless to say I have some other parts I need to sell now.. Or build a second car. Only time will tell. 20201205_121110.jpg 20201205_121118.jpg 20201205_121505.jpg
    hfh and brEad like this.
  15. I hope to be building the engine soon. Still need to order some more parts, but I have enough to measure deck height, so I can finish the machine work on the block. It's winter and I have no heat in the shop, so progress is slow. 255 Merc crank, reconditioned rods, Egge pistons, Hasting rings, and Clevite bearings. Shold make a good foundation.
    KiWinUS, hfh and 51box like this.
  16. Other than getting junk drunk and tinkering with the flatty, I really need to get a coat of red oxide primer on the new Brookville body. A cold shop will not treat the body well this winter. I have some feelers out there, but none of the local body shops do custom work. Hopefully soon I can get it some where. With the body in primer and the flatty short blocked, progress is sure to speed up.
    Stogy likes this.
  17. Update. Body shops don't paint cars anymore. Who would of thunk. Been searching for a year with no luck. I'm tinkering with the "Yard Art Roadster" because its actually fun to work on. NO PAINT! I'm not a painter and I do not have the time to do the job right, so this AV8 is permenatly put on hold until the body gets primed in red oxide primer. The flathead is also on hold, mainly because I won't dump thousands into an engine for a car that will never get painted. I'm extremely disappointed in the body shop industry. All they want is that easy insurance money. At least around me.
  18. manyolcars
    manyolcars
    You can learn enough to spray it yourself.
  19. Skill isn't the problem. The space, the tools, and the time is the problem. I don't have too many weekends I can dedicate to painting. I just need it done so the car can get mothballed until the engine is finished. It could be years.
    Stogy likes this.
  20. neds29
    neds29
    Have you given up already?
  21. Sometimes its hard to see the light at the end of the tunnel when you get this deep into a project, and it seems the parts and services to support the project are hard to come by. I talked to another shop today. I got a maybe. Better than the 50 "we only do insurance work" s I got. We will see....
    Stogy likes this.
  22. 2935ford
    2935ford
    Great start.........
    Makes me want to start another build........ah, nevermind!
    Said no more and I have to really mean it this time! :)
    Stogy and Haven Hills Auto Club like this.
  23. hfh
    hfh
    from Western MA
    You have such a great start and you have collected so many special parts that will be so much fun to use in getting your roadster together. Find a restoration shop (not just a body shop) that you can trust to get your body painted. That will likely renew your interest in getting it completed. Then you will have a reason to get your engine together. It is so rewarding to finally, after years of work, to hear your engine run, to actually get your project to move under its own power. Don’t miss out on those rewards. It’s really worth the struggle.
  24. Thanks for the encouragement. This is a bucket list car that I have very high expectations for. Hope to make it to Autorama with a really unique AV8. I will get there. Just stalled and frustrated. This year is basically blown. Hope to be back heavy on this car next spring.
    Stogy and hfh like this.
  25. UPDATE!!! Mike at Gas Axe Garage has the body. He is fitting the 39 Zephyr lights to the rear panel and will relay the body to get primed in black sealer. Makes me want to mount up some white walls. My budget is blown for the year, but finally some real progress! Unfortunately, the flathead is stalled. The crank is **** and will require major and expensive surgery. This will push the engine into next summer if I'm lucky. I will update with photos once I get her back from paint.
    Stogy, Nobey and Budget36 like this.
  26. Big thanks to JH Customs for prepping and painting the body in epoxy sealer.
    brEad, Shadow Creek, A Boner and 4 others like this.
  27. Progress is slow, but finally most of the roadster is in primer.
    brEad, KiWinUS, Shadow Creek and 3 others like this.
  28. Stogy
    Stogy
    Keep up with it your getting it done and just love the vintage direction @Haven Hills Auto Club...
    Just imagine how much effort has been spared with the choice of body...
  29. I searched 4 years for a real roadster body. The good ones were out west and the ones near me were basically the same price as the Brookville, but missing the bottom half or major components. I know the Brookville isn,t Henry, but at least she is steel. I just say I bought a patch panel for the gas tank. Ha!
    brEad, woodiemike and Stogy like this.
