I have a rolling frame from a 1964 buick 225 electra. Does the brakes are the good ones for the ford conversion?
@Patrice yes, that would be them……45 fin is more sought after than later 90 fin versions. However, their desirability and value depends on how badly worn the iron liners are. The inside diameter of the drum is key. Ray
They are the ones. I also have a set of them I am going to adapt to my 40 Buick. As Ray said, measure the ID of the liners. They can be re-lined, but expensive.
Tanks for your fast replies. I will measure the ID next week, I have the correct tool at my work. All is complete and turn with a little resistance. Do you know the correct size and the maximum autorised diameter? And please excuse my bad american.... Patrice.
The GM service manual for those vehicles states a maximum diameter of 12.080 inches which would be 306.832mm.
Check for corrosion between the liner and the aluminum. It would be a hard white line. I have had one drum that was 3/16 out of round
If you are putting the entire brake ***embly on early Ford spindles, those have the wrong backing plates. However, all the other bits and pieces work. The '58 to '60 backing plates are the ones to use.
I will check the condition and the drum ovalization with a dial gauge with the backing plate removed for clearance.
I just took a look at my car. While those are the correct brakes, you need the earlier '58 to '60 backing plates to work with early Ford spindles and even there, you need to make spacer plates.
I don't think they are right send them to me and I will dispose of them properly...... Hopefully the sarcasm translates to French? Just kidding hopefully you can use these and show us the whole project. I love to see traditional American hot rodding get respect in other countries.
And please excuse my bad american.... Patrice.[/QUOTE] I guess France must really be pissed off at England due to the fishing dispute! Never heard of the American language...LOL
Ha ha, I will check them first, and if they are worn, they are yours, you just have to pick them ;-) As for the project, my 32 has mechanical brakes, may be in the future, but still with traditional way.
I guess France must really be pissed off at England due to the fishing dispute! Never heard of the American language...LOL[/QUOTE] No, but prononciation, yes ;-) Seriously, I read the forum since many years, and I am always impressive by the high level of cars, tech and interesting discussions. I want to make sure that I have a good english (american) syntax, that is the minimum I have to do.
No, but prononciation, yes ;-) Seriously, I read the forum since many years, and I am always impressive by the high level of cars, tech and interesting discussions. I want to make sure that I have a good english (american) syntax, that is the minimum I have to do.[/QUOTE] I’m always impressed with the level of English spoken/written by our non N. American members from France, Finland, Sweden, Germany, etc. My deep memory can sometimes give me a little Francais but my wife is extremely good. Thank God these messages are written because accents can really ****** up communication....
I am Cajun an my son is taking French in school an I can't help him at all because my French is an old French that has been messed up with English an Spanish. Makes me feel a bit foolish at times
I grew up in Port Arthur Tx. I love the sound of Cajun speaking. It is music to my ears. I miss not hearing it in Kerrville. I worked on the docks and my Cajun friends could not understand French seamen.
I guess France must really be pissed off at England due to the fishing dispute! Never heard of the American language...LOL[/QUOTE] England and the United States….”two Countries divided by a common language” Ray
Thoses drums are amazing in hand. Great parts and proud to have saved this frame from the s****yard. I discover that the left wheel nuts are inverse, I cannot unscrew them until I tried on the reverse rotation ....Every day I learn. General shape seems ok. Max ID is 306,3 mm, I have to remove more surface rust. As son as I can, I will measure the ovalisation.
I dis***embly the backing plate from the spindle to attach the dial gauge. Good news, the out of round is no more than 0.08mm (0,003 inches).
