Projects '53 Mild Custom - Dads Hot Rod
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Jan 29, 2019.
  1. 54vicky
    54vicky
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Take another picture showing more of what is to the left of it. This is the same area in a '53 with a 302 using Butch's mounts. I would guess it's a piece cobbled in to use the y-block they had a part called a "steady rest" https://www.fordbarn.com/forum/showthread.php?p=1767306 Since 1953 fords still had the flat head. Butch's '53 swap.jpg
  3. 54vicky
    54vicky
    the steady rest fit on front bolted to block at front behind crank pulley
    oliver westlund and loudbang like this.
  4. Hdonlybob
    Hdonlybob
    That is a nice find... I like.. A lot !!
    Good for you..
  5. oliver westlund
    oliver westlund
    that is a bent, hurst style mount that used to be mounted to a crooked piece of angle iron!
  6. oliver westlund
    oliver westlund
    is there a hole for a pilot bearing already? i have a 292 mated to the 3 speed manual and could swap cranks if its easier or drill out a hole for a pilot bearing if a hole doesnt exist already?
  7. oliver westlund
    oliver westlund
    i am making my own mounts that will allow the use of the factory y block mounts, i am also going to use a single central mount that came on the new (to me) y block, it comes off the front. the thing ran idk how well, extremely hob knobbled together in the past, i tried to relieve some tension on the clutch pivot and lower the engine slightly. now that my mounts are in and the factory y block mounts fit in them. i am going to remove the engine and finish weld as well as better brace my mounts
  8. 54vicky
    54vicky
    why the hell would you want to go to extreme just go to napa and get a pilot bushing.
    50chevytx and oliver westlund like this.
  9. oliver westlund
    oliver westlund
    lol thats why i asked if theres already a hole! obviously there is so ill just go to napa and get a pilot bushing
    SS327, chryslerfan55 and loudbang like this.
  10. ST63
    ST63
    Stock rear gearing?
    oliver westlund likes this.
  11. oliver westlund
    oliver westlund
    got out and worked on her today, yanked the old engine and trans, gonna finish up my mounts, patch up the butchered crossmember and clean clean clean, maybe a bit of rattle can black. then mate the tri power 292 to the manual and slap her back in, the throwout bearings toast, i tried monkeying with the pilot bushing to pull it out of the old engine but i may just buy a new one, pressure plate and clutch look good, anyone recognize this trans? whats it out of potentially for the oreilly boys? 20200919_171003.jpg 20200919_175155.jpg 20200919_175211.jpg
  12. That's a Ford three speed, not one of the B/W trans. The lightest-duty of the manual trans Ford used in that era. Not one you want to beat on....
    chryslerfan55, loudbang and JeffB2 like this.
  13. oliver westlund
    oliver westlund
    it wont get beat on, could that be stock for 1953? just wondering what vehicle info to enter when looking for parts
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    You should save this link a lot of good info on 1953 and earlier Fords. http://www.vanpeltsales.com/index.htm
  15. oliver westlund
    oliver westlund
    little motor mount progress today, still have to reinforce the crossmember, i just dont trust it how it was left 20200929_102718.jpg 20200929_100501.jpg
    brEad and loudbang like this.
  16. oliver westlund
    oliver westlund
    Well...progress. took me long enough. I welded some 1/4" plate in to reinforce the crossmember, finished up my mounts and installed the tri power y block!
  17. oliver westlund
    oliver westlund
  18. oliver westlund
    oliver westlund
  19. oliver westlund
    oliver westlund
    Also finished welding the p*** side headlight french, stripped 3/4 of the fender to bare metal and primered. Now filler, seal skin!
  20. oliver westlund
    oliver westlund
  21. 41rodderz
    41rodderz
    from Oregon
    Progress is good .:)
  22. oliver westlund
    oliver westlund
    Figured id go back and pull the back gl*** with my bud 20211105_165911.jpg 20211105_173211.jpg
    loudbang and Stogy like this.
  23. That arm-burner exhaust has got to go.... LOLOL...
  24. oliver westlund
    oliver westlund
    The crossover pipe? Itll likely get headers at some point idk. At this point i am trying to get the floors,roof and rockers patched, painted, interior in, start run and drive and im handing the keys over to my pops. Was supposed to be an 80th birthday gift but i will be lucky to have it ready for his 81st christmas next month! It will still be a project when he gets it, just an easier one
    loudbang and TrailerTrashToo like this.
  25. JeffB2
    JeffB2
    from Phoenix,AZ
    https://www.spotlitekustomaccessories.com/store/p8/Ford_Y_Block_Headers.html Company owner drives a '54 with a Y block. ;)
  26. JeffB2
    JeffB2
    from Phoenix,AZ
    From the Ford Shop Manual "the back gl*** has to be removed when installing a new headliner" so it's a good time to do that too.
    loudbang and oliver westlund like this.
  27. oliver westlund
    oliver westlund
    Ive been toying with the idea of doing one of those tuck n roll headliners. Just havnt figured out how to make it all work yet, appreciate the advice!
  28. oliver westlund
    oliver westlund
    Mine had the steady rest. I pulled it off. It hit the core support
  29. oliver westlund
    oliver westlund
  30. oliver westlund
    oliver westlund
    Well....another member in the pit crew! Sadie! Born at 2:10 am on nov 7th! 20211107_033558.jpg
    Jimmy, dave plmley, brEad and 5 others like this.
