Technical 289 intake weirdness
Discussion in 'The Hokey Ass Message Board' started by sparky232, Nov 7, 2021.
  1. sparky232
    sparky232
    Anyone ever encounter this? Putting together a 289 for a buddy who has had the parts stashed since the late 70s/ early 80s. Not really sure what the deal is and haven’t found any info online. Am I having a brain fart senior moment way too soon? AAC3B669-27F1-4951-8860-A147101B553E.jpeg
    tommyd and dana barlow like this.
  2. Yep, that's the way some heads were cast. For the guys that don't believe in torque wrenches, the leading cause of breaking off that corner of the intake...
  3. Fords love 'em or hate 'em they were Fords. :D
    lothiandon1940 and sparky232 like this.
  4. tommyd
    tommyd
    from South Indy
    Normal sbf Ford stuff. Good to go.
    sparky232 likes this.
  5. Oilguy
    Oilguy
    I did a Google and found several others like that. As Crazy said, use the correct torque specs. Looks like you could easily snap it off. But I don't know squat about Fords.
  6. Budget36
    Budget36
    You’d think a wedged spacer would be made for that.
  7. Truck64
    Truck64
    from Ioway
    That would cost another $ 0.04, are you nuts?!
  8. Moedog07
    Moedog07
    Cast iron intakes from the factory don't tend to break there. Even if the factory had made a spacer some gearhead would toss it during an intake change.
  9. Budget36
    Budget36
    I get ya. But was thinking Mr Gasket, etc would have seen a way to make a buck.
  10. It would be way to easy to make your own I wouldn't do it.:confused::eek:o_O:rolleyes:
  11. sparky232
    sparky232
    I was considering making a wedge spacer out of some tubing but didn’t want it to look hokey. I just won’t get he man on the intake bolts and check torque specs.
    Little backstory, he dis***embled his 65 comet in 1977 and it never went back together. All new now semi vintage speed parts going back together finally now that we are putting it back together. We meaning me, he’s in a home and can’t turn wrenches anymore.
    tommyd, lothiandon1940 and Oilguy like this.
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    Curious as to what casting number your heads are ? My 302 has 289 Hi-Po C5OE-B heads and no gap there maybe check here about casting numbers http://www.mre-books.com/interchange/interchange5.html
  13. With a aluminum intake, you do want to lower the factory torque number and make sure you use the factory pattern. I'll sneak up on it, starting at 10 ft-lbs, going up in 2 lb increments until you hit 18 ft-lbs, repeat this twice then stop.
    Using the cast-iron number and tightening in one operation is how you break these...
  14. I'll bet I know what happened, you got the heads on backward. :rolleyes::D:D:D:D
  15. sparky232
    sparky232
    Thought I had a pic of the casting, but nope. I’ll check next time I’m over there.
  16. sparky232
    sparky232
    Ha! Of course!
