Hot Rods Double hump heads?
Discussion in 'The Hokey Ass Message Board' started by Thepartsbinguy1, Nov 7, 2021.
  1. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    Going to pick up a 327 mounted to a Jeep t90 and they guy said it was a solid engine he built when he owned a gas station way back when. He told me the 327 crank broke so they put a 283 crank in it? Then they put it in a Jeep truck for his daughter but she just couldn’t drive it. Now after ohh 25 years I’m getting what’s left of the Jeep. These just don’t look exactly like the double hump heads I have. Any ideas? Maybe it’s just all the dirt making things look off? I can’t get there right away to look at numbers. 6FDF5CC4-9DEE-48D7-856A-3AA6B10BF294.jpeg
    Deuces likes this.
  2. Lost in the Fifties
    Lost in the Fifties
    They look like mine.
    Deuces likes this.
  3. 1934coupe
    1934coupe
    It looks like it to me, if they put a 283 crank in it did they change the pistons? The pin location is different between 283 and 327.
    Pat
    Deuces, Blues4U and indyjps like this.
  4. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    My 462’s are straight down and on the edge of the Jeep heads it slants? Did they make different versions of the double humps? E036884B-A3FD-4F83-BDF9-F6924BA06A46.jpeg
    Deuces likes this.
  5. indyjps
    indyjps
    See what you have. I'd buy a full gasket kit and do a quick teardown, inspect, clean. Depending on how the jeep was used coulda been full of mud and dust :eek:
    If the heads are in good shape run them, if they're 2.02 you're lucky. There's a few version of the humps.
    Check the piston height as @1934coupe suggested.
    I might as well start asking what cam it has, all small block chevy threads eventually go there. :D
  6. oldiron 440
    oldiron 440
    Hell I don't know what I'd do with a double hump at my age...
    NashRodMan, belair, partsdawg and 3 others like this.
  7. swade41
    swade41
    from Buffalo,NY
    Some are different than others, that right side is probably a casting flaw, these have angled sides
    Deuces likes this.
  8. X-cpe
    X-cpe
    If they didn't change the pistons, wouldn't they be .125"+ down in the hole with who knows what un-compression ratio.
    MBog and rbrewer like this.
  9. joel
    joel
    What you have is a "pig in a poke" . It's worth a gasket set to look inside. You have double hump heads; if you remove the valve covers and check the casting numbers, you can maybe get some info on valve sizes and combustion chamber volume.
  10. Speed Gems
    Speed Gems
    Also if they put a 283 crank in it you now have a 301/302 unless it's over bored
    MBog and 427 sleeper like this.
  11. 427 sleeper
    427 sleeper
    Is there a provision for a temp. sender on the exhaust side of the head? It might have the later 291 double hump's.
  12. Mr48chev
    big duece likes this.
  13. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    I have been trying for weeks to get this engine back to my place. the guy I’m buying it off of has patience let me tell you. After failing to find a trailer to get the whole Jeep he cut the whole Jeep up for me with a sawzall.. set all the parts I need laying off to the side. I couldn’t find a ride to even get the parts so he texted me just now and was like I’m gonna load everything up and just bring it to you. Guys a legend. I’ll let everyone know what the heads are when he brings everything out.
    1952henry and Speed Gems like this.
  14. lippy
    lippy
    from Ks
  15. swade41
    swade41
    from Buffalo,NY
    You could run a boroscope in through the sparkplug and possibly see a number on the top of the piston, then cross-reference the number to see what the piston specs are.
    X-cpe and Max Gearhead like this.
  16. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    Got a picture of the full engine.. I think it’s worse then the 75$ 283 :eek: witch is still going strong by the way. 4DD4A91F-F783-441A-97A3-4ABD16EB11EC.jpeg
    dearjose likes this.
  17. wheeldog57
    wheeldog57
    We can supply alot of info if you gather a few numbers from your motor. If you pull off a valve cover you'll see the casting number between rockers. Behind the distributor and down where the transmission attaches there is a large casting numbers for the block. Also, in front of the right head on the flat surface will have stamped numbers. Those (if still there) can tell alot. Let us know what you find.
  18. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    He’s bringing it out around Tuesday and I’ll be able to look it over and get numbers. I’ll post them up.
