Technical Small Project: Harrison Heater Rebuild
Discussion in 'The Hokey Ass Message Board' started by Rehpotsirhcj, Nov 7, 2021.
Tags:
  1. Rehpotsirhcj
    Rehpotsirhcj
    The weather is getting colder here and so it's time to address the leaking heater core and rattling fan in my 53 Chev 3100. I thought I'd post a few photos of the process in case it might help someone down the road.
    Note that there is excellent do***entation on the web for this that goes into much more detail, so this is just an overview.
    This is the Harrison heater as it came out of the truck:
    It was pretty rusted up on the vent side, and so once I dis***embled everything I soaked it in Evapo-Rust overnight. Stuff is pretty amazing, works better then my electrolysis tub.
    A few shots of dis***embly. It turned out that the fan cage is peened to the mounting hub, and these were loose and rattling. Quick fix with a hammer against the vice and good to go.
    I sanded everything out and then used Rustoleum Dark Bronze Hammer finish over a primer coat.
    I chose to order a new core because I wanted to get this finished, and we don’t have a radiator shop here. The inlet/outlet was a bit different and so I modified the case a bit, but kept what I cut out in case I ever want to fix and install the original core again.
    I used pipe insulation around the core on re***embly to minimize any chance of vibration and rattling. I hate noisy heaters.
    Couple of stickers to make it look legit, and it’s ready to install:
    It runs nice and quiet now, and will heat me right out of the truck. Plus, it’s stock and sill looks the part. On to the next project.
    squirrel, catdad49, AVater and 7 others like this.
  2. Black Panther
    Black Panther
    from SoCal
    Looks great! I just picked up a '54 F100 that has a similar heater with Ford script...so I'll be doing this soon too...
    Rehpotsirhcj likes this.
  3. rusty valley
    rusty valley
    Nice job! Heat and defrost is a good thing for us northerners.
