Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. pennafxu
    pennafxu
    from Kentucky
    Plug caps came in… It seems I will need to pull the rubber part off… BFC92B1C-CED8-40EC-A330-7878E5EB8E36.jpeg 57055686-ED47-4DB9-8458-7BFAD5E7609C.jpeg 04233E97-1BBA-4EDD-B7CB-6C7B589B55FD.jpeg 84605B8F-19A8-4CE5-9221-B339387C04C0.jpeg
  2. alchemy
    alchemy
    pennafxu likes this.
  3. pennafxu
    pennafxu
    from Kentucky
  4. alchemy
    alchemy
    My flathead has real wire in its plug wires.
    WiredSpider likes this.
  5. pennafxu
    pennafxu
    from Kentucky
    does it have an electronic ignition?
  6. alchemy
    alchemy
    Of course not.
    rusty valley likes this.
  7. pennafxu
    pennafxu
    from Kentucky
    Why not?
  8. alchemy
    alchemy
    Because I like old style hot rods. And I don’t trust things I can’t see.
  9. pennafxu
    pennafxu
    from Kentucky
    Lol
  10. pennafxu
    pennafxu
    from Kentucky
    44D23C4A-7FDF-4327-8FF3-98568E0E9B94.jpeg B9B2F8DB-90EC-4E81-A3A9-A311FFE02912.jpeg 68576880-E54C-4DF1-8E7D-CE4654A0E693.jpeg Separating mount from coil… Will blast off the rust…
  11. pennafxu
    pennafxu
    from Kentucky
    On to the plug wires… 40BA0204-5791-47AA-A537-837EF034C4AF.jpeg 5391E7B6-19F6-4955-AA3E-92ECB2C7B904.jpeg
    Got 25’ of 7mm suppression core. Just how @alchemy likes it…
    brEad and loudbang like this.
  12. pennafxu
    pennafxu
    from Kentucky
    Trying to recycle as many old wires as possible… BBDE0887-7D5E-45D1-B02B-B303CC59E028.jpeg grabbed a test end. BBDE0887-7D5E-45D1-B02B-B303CC59E028.jpeg 2A44C646-676C-4BFE-B34F-5D9907F2DB58.jpeg 8017CB78-A5F0-4E0D-B8B6-2DC5D1266BBF.jpeg 5D3478D9-92C4-488C-9997-6834D6BF5B8E.jpeg
    bent 90 deg wings whilst holding in the dedicated crimper
  13. pennafxu
    pennafxu
    from Kentucky
    7FD39B38-6BF9-42E4-A013-75ACF5CB7AF3.jpeg D3D497AF-BE38-4190-B711-B0D293C32A36.jpeg
    From my reading, they recommended a little gap like this… 270B0E4D-5CBF-406D-868F-D3A84431CFB3.jpeg 58261D00-0291-4237-8F65-23F0F05C0CB4.jpeg FD4A11BD-4C80-4E65-98EE-7D560C2CE94A.jpeg
  14. pennafxu
    pennafxu
    from Kentucky
    One down and 7 to go! I need to review the firing order again to make the correct lengths. Will also wait after the alternator and belts are fitted. I will also check for continuity
    LAROKE and loudbang like this.
  15. Flatrod17
    Flatrod17
    I see you have 216 autolite plugs. I think they may be wrong for your heads. They are 1/2 reach, if I remember right the Offy's take a 3/4 reach plug. Running the 216's is like trying to run a cartridge fire plug. It's way up in the head.
  16. pennafxu
    pennafxu
    from Kentucky
    Ok… so what are the right ones… [mention]Flatrod17 [/mention]
  17. pennafxu
    pennafxu
    from Kentucky
    739B8FEC-A291-442D-B696-A5CB827DE921.jpeg AABA7D55-BA92-40AE-8CC3-DBD0A42B45C9.jpeg 739B8FEC-A291-442D-B696-A5CB827DE921.jpeg AABA7D55-BA92-40AE-8CC3-DBD0A42B45C9.jpeg
    These are the right ones...
  18. Flatrod17
    Flatrod17
    LAROKE, loudbang and pennafxu like this.
  19. pennafxu
    pennafxu
    from Kentucky
    So I've decided to build an engine break-in stand and run my flatty in, and prep for the other 2 flatties. I'm going to cannibalize one of my engine stands... More to follow on that. I will need y'alls help on the final engine set up. I have a decent idea of what I need to get this running but I certainly need input. I need to feel like I'm doing something. I'm getting so depressed here not being able to do ****. It's driving me mental. I have a mini build list and hope for your help.... @alchemy and @patmanta
    LAROKE, brEad, loudbang and 1 other person like this.
  20. pennafxu
    pennafxu
    from Kentucky
  21. patmanta
    patmanta
    from Woburn, MA
    Sure, whatever I can do! I'm not sure how much help I can offer other than encouragement and to say that your 2 to 1 intake is probably going to want to run straight linkage and not progressive. I usually see progressive come in on triples and that is a dual to one adapter so it might get wonky but I am no expert. I do have one of those in my bin earmarked for the 59ab I have in pieces somewhere for later though so I am going to be very curious how this works for you.
    My 8BA is still at the machine shop.
  22. pennafxu
    pennafxu
    from Kentucky
    That is a stock pic… mine is a sharp intake.
    patmanta and loudbang like this.
  23. alchemy
    alchemy
    I don't like electronic distributors (points are more traditional, and that's what we are here for, right?). I don't like the diecast potmetal fuel blocks (find a nicer cast aluminum one). I don't like aluminum fuel line (I always use the same steel tube you buy for brake line). I don't like Speedway fake Strombergs (buy real Strombergs). I think there is a Holley regulator in the 0 to 4 pound range that would work better with Strombergs. Not sure on the Powergen fit with your fan - remind us what fan you want to use.
  24. pennafxu
    pennafxu
    from Kentucky
    Ok I will get the original one’s. It is the original 4 hole fan. I was getting the electronic distributor for the engine break in stand?? Reasoning behind the steel line please? Do you have part number for Holley regulator? Will get the cast aluminum block then.
    Thank you @alchemy
  25. alchemy
    alchemy
    https://www.speedwaymotors.com/Holley-12-804-Adjustable-Fuel-Pressure-Regulator-1-4-PSI,383.html
    Tons of original fans out there, about every other year in the flathead era got a different version. Show a pic please.
    I just don't trust copper or aluminum lines on a car - I've read about cracking. Might be fine on your stand, but why risk it. Steel lines are cheap at the store and have flared ends so you can screw them into your pump and regulator.
    https://www.speedwaymotors.com/Edelbrock-1280-Fuel-Block,108900.html
    I guess the cast aluminum blocks are rather expensive. The diecast would be fine for the stand, but I'd pony up for the aluminum on the car.
  26. pennafxu
    pennafxu
    from Kentucky
    I picked up my carbs…. @alchemy :) what thread pitch is on the intake studs??
    6F5FA43B-72E1-4936-B5D8-176A00AA3EEE.jpeg 50A9B2B8-8C88-40D6-9699-8F9E2218F554.jpeg 57B31DB8-1566-41E8-A0E6-E031D55614A2.jpeg FFECFA80-2320-4AD9-BA33-194958091691.jpeg E142EEA8-AF5C-4C28-8A2A-F9191CF83554.jpeg 0EE78CF3-A485-4F46-ADDF-D173522D8317.jpeg 6926FC02-B124-4C57-87FD-DC7098618E65.jpeg 9DA89E11-B029-441F-8EEA-7DA94C215C5E.jpeg
    patmanta, LAROKE and loudbang like this.
  27. alchemy
    alchemy
    Most aluminum intakes use 5/16" co**** threads. You can find studs with co**** on both ends, or fine on the top.
  28. pennafxu
    pennafxu
    from Kentucky
    Got some parts...
    tempImageF6qcHf.png tempImageXLnEDQ.png tempImageSLNpe0.png tempImage1rBCJ7.png tempImagenHNkLx.png tempImagelNGYsr.png tempImageF6qcHf.png tempImageXLnEDQ.png tempImageSLNpe0.png tempImage1rBCJ7.png tempImagenHNkLx.png tempImagelNGYsr.png
    brEad, patmanta and LAROKE like this.
  29. pennafxu
    pennafxu
    from Kentucky
    Cowl is from a model A air compressor... I will put a cylindrical gas tank where the semicircles are.
    Will polish up the nickel plate and drill holes for my gauges. This is a very heavy duty trolley. I will weld the back end of the flathead engine stand on one end.
    Outback likes this.
  30. pennafxu
    pennafxu
    from Kentucky
    I will fabricate and elevate this front frame with flathead engine mounts
    Lil'Alb, patmanta and Outback like this.
