Projects Ford TwinT straight 8 build
Discussion in 'Traditional Hot Rods' started by Blackbob, Mar 10, 2020.
  1. spit6
    spit6
    I am watching this is way cool engineering!
  2. banjorear
    banjorear
    Me too. Love it! Best of luck
  3. Can’t wait to hear it run.
  4. shivasdad
    shivasdad
    from Texas
    Anymore happening? Just found this. I'm subscribed.
  5. Ebbsspeed
    Ebbsspeed
    @Blackbob We'd love an update of this project.
    Blackbob and Blues4U like this.
  6. drtrcrV-8
    drtrcrV-8
  7. Blackbob
    Blackbob
    finally got some barn time and cleared a bench for the TwinT project, loosely set up to see where I got to and an old pic of the T ch***is with space for two motors IMG_3534.jpeg IMG_3531.jpeg 254518762_4940887022622556_5338701135788294378_n.jpg 247992651_4940887005955891_3161137978363767318_n.jpg
  8. Hollywood-East
    Hollywood-East
    I believe I have a picture of the one I saw when I was working with a character in Phoenix... I will look for it when I get to the shop...
    Blackbob likes this.
  9. oj
    oj
    Have you ever seen a Durant Speedster? 1924ish ? He used a pair of Continentals (I think) 4cyl with a common crank, very similar to what you're building.
    winduptoy, Jet96 and Blackbob like this.
  10. Blackbob
    Blackbob
    No, I haven't I'll do a bit of google searching.. I know of a a Bugatti 8 that was done that way on an ally crank case
  11. Blackbob
    Blackbob
    Im back on it, slowly but progress will be made :)
  12. Hollywood-East
    Hollywood-East
    KIMG9696.JPG actually.... It's Six, never mind...
  13. Dave G in Gansevoort
    from Upstate NY
    There's an antique automotive museum in/near Kennebunkport Maine. Its got a Pre-T Ford with a 6 cylinder flathead that looks like a T 4 banger. I'll get my nephew ratrodder to chime in, as he spends time up there, and might have a picture or 5 of it.
  14. Kevin Pharis
    Kevin Pharis
    from Califunny
    There were a few pre T race cars along with the production Model K that were 6 cylinder engines, all jug type that I know of. Ford also made a few experimental T 6 cylinder engines that were used in Edsel Fords speedster and possibly other test cars as well. These would have had very similar T design characteristics.
    The T 6 cylinder picture above was a relatively well known modification of stock components similar to this dual engine 8. There was even a T dealer back in the day that produced a V8 made up from modified T engine parts!
    Stogy, winduptoy, Jet96 and 2 others like this.
  15. Fortunateson
    Fortunateson
    I’m looking forward to a pic of the oil pan gasket...
  16. oj
    oj
    I was just looking at it, the Durant, a little while ago, they ran it in a number of 'Great Races'. For sure, 2 engines. Neat car.
    Stogy, winduptoy and Blackbob like this.
  17. Blackbob
    Blackbob
    Won't be that exciting, it will be two standard ones cut n shut together, getting it to sit in place might be a fiddle ;)
    winduptoy likes this.
  18. XXL__
    XXL__
  19. FlatJan
    FlatJan
    great project.. will follow and wish you all the best!
  20. birdman1
    birdman1
    the use of the sprockets and roller chain is actually a well proven coupler. Oliver tractors used them on many of there tractors, up to over 100HP.
  21. ratrodrodder
    ratrodrodder
    from Boston
    I'll have to do some more searching to figure out which museum you're talking about - there's Owl's Head, but that's nowhere near K'port... Motorland, but I don't recall anything like that there (but I've been known to be wrong in the past). :rolleyes:
    (Ir)regardless, cool project! Hope you are able to continue to make progress over the winter! :)
    Blackbob and loudbang like this.
  22. RodStRace
    RodStRace
    Just a suggestion, borrowed from old front engine top fuel builders.
    They would use a machined bar fitting the mains and pinion input to align the drivetrain.
    Seems like the 2x oil pan would not be a solid stressed member to align the 2 blocks.
    Best bet is to mount both blocks solid, but you want them as aligned as possible.
    If you can find a bar that can span both blocks and be tightened with the mains to 'jig' them straight, then fabricate the engine mounts, it would keep them aligned.
    Jet96, Blues4U, 282doorUK and 5 others like this.
  23. Blackbob
    Blackbob
    I have a length of tube of the correct diameter for lining up the blocks that I will use once I have got the exact distance between the crank ends fixed. I plan to use one of Les Schuberts flexible trans shafts to try and help keep the balance issues to a minimum
  24. alchemy
    alchemy
    I'm in Marshalltown, Iowa. I'll have to see if I can find out anything about Mr. Hollingsworth and his twin T.
    Very cool project you've got there.
  25. i like cars & stuff
    i like cars & stuff
    from Aotearoa
    Are those shafts easy to obtain? I have had only tiny success making one myself.
  26. Blackbob
    Blackbob
    I haven't tried to buy one yet, the seller is active on the MTFCA, that being said, I have a mill and a lathe and two spare trans shafts ;)
    282doorUK and loudbang like this.
  27. i like cars & stuff
    i like cars & stuff
    from Aotearoa
    You'll only need one shaft. And a 12mm steel plate i believe. Could be 10mm. Been a while since i fitted it to the engine.
  28. Blackbob
    Blackbob
    Yeah, from memory Les reduced the flange on the shaft by 0.005" and made the outer plate in 660 bronze to the original depth.
  29. Stogy
    Stogy
    Hard to pick which Thread of yours to bring back to the top...this is it...hows thing evolving @Blackbob and I hope your day is full of Cake, Spirit and GowJob...Happy Birthday...;)
    Blackbob, Outback and Carter like this.
  30. Outback
    Outback
    from NE Vic, Oz
    @Blackbob I know you haven't been here for a bit, hoping you might return to fill us in?? Anyone know him?
    RodStRace and 41 GMC K-18 like this.
