Looking to Get Started...
Discussion in 'The Hokey Ass Message Board' started by Tribalmonkey, Dec 14, 2020.
  1. Tribalmonkey
    Tribalmonkey
    I’m still looking for a roadster. I found a nice 28 down in NC but it is 7 hours away. I may pull the trigger on that if I don’t find anything closer soon.
    lothiandon1940 likes this.
  2. vtwhead
    vtwhead
    I have a friend that moves snow bird cars to Fl each fall. He has an enclosed trailer and surely p***es by your area. If that is anything that could help you out let me know and I can get you in touch with Dan.
  3. Tribalmonkey
    Tribalmonkey
    Thanks!
  4. Tribalmonkey
    Tribalmonkey
  5. lothiandon1940
    lothiandon1940
    It's a beauty, Mark. Almost too nice to hot rod........NOT!:D
    loudbang and Tribalmonkey like this.
  6. Dick Stevens
    Dick Stevens
  7. Tribalmonkey
    Tribalmonkey
    Don - Actually I agree with you. Once I saw it in person, thought about it more on the long ride home, and then consulted two of my buddies, I decided I can’t hot rod it. It is too nice - that and I can barely get in and out of it. It’s too small for me. I need to find an appropriate condition 30/31. TM.
  8. tb33anda3rd
    tb33anda3rd
    nothing is too nice to hot rod. millions of model As around .....start cutting.
  9. Tribalmonkey
    Tribalmonkey
    This roadster has a BW R10 overdrive that is grafted into the torque tube. Looks to be an early 40s 50s traditional mod. My plan is to swap the rear drive train out to cherry pick the overdrive for future use before I tidy up the car and sell it.
    Dustyp489 and lothiandon1940 like this.
  10. Tribalmonkey
    Tribalmonkey
  11. Tribalmonkey
    Tribalmonkey
    I’m looking for a two bolt timing cover for my 59AB.
  12. lothiandon1940
    lothiandon1940
  13. Tribalmonkey
    Tribalmonkey
    So I ordered a new stromberg efire distributor for my 48 flathead build. I now realize they are only 2 bolt and I have a 3 bolt timing cover. What is my best course of action? Buy the adapter? Switch timing covers? Obviously, I am a bit new to this.
  14. vtwhead
    vtwhead
    TM, just my 2 cents here which is often only worth a penny but there seems to be an awful lot of negative issues with that efire system and it's failures from the initial install to down the road.
    Another E-Failure - The Ford Barn
    You feel confident that yours is going to be a good one? Would you be better off starting that flatty with a tried and true points distributor to work out the bugs and then investing in a more non traditional system?
  15. Tribalmonkey
    Tribalmonkey
    Thanks for the feedback. I’m trying to test fire this flathead soon. I’d like to go with the crab style. Can I use an original crab style with my 3 bolt cover? You guys know I like to work pretty fast and I find I’m taking lots of two steps forward and one step back with my flathead. I have a lot to learn. I think I have most all of the popular flathead books and have read most of what I have. Thanks again! Your experience and opinions are extremely valuable. TM
  16. vtwhead
    vtwhead
    IIRC and I usually don't crab style was only two bolt so no would appear to be the answer. Also other things may have to be change if you switch covers.I have not messed with flatheads for a very long time so I have to step aside for the others that have greater knowledge.
    Surely someone near you should have a stock distributor that they could lend you to test fire that flatty.
  17. Dustyp489
    Dustyp489
  18. Dustyp489
    Dustyp489
    Would the one from the 21 stud work for start up?
  19. Dustyp489
    Dustyp489
    Sorry I just checked 36 flathead dist. Was one year only.
  20. Tribalmonkey
    Tribalmonkey
    EB5212C1-DECB-4E7E-827A-EFE70F2E5806.jpeg 23BCE2A3-1593-4C56-92B4-164C2DCE2ACB.jpeg
    Maybe. However, I discovered that I have what looks like an early cam because it sticks out further so I’m swapping out my Stromberg e-fire two bolt with the three bolt version. I spoke to Clive at Stromberg and he stepped me through what I needed.
    On a different but related note I just finished doing a bit of a cleaning and rebuild of a old Holley 94 carb. I still need to learn how to best clean the carb bodies to make them look new. I use an ultrasonic cleaner with simple green to clean my parts. It cleans but doesn’t brighten anything up.
    I should be ready to test fire the 59AB once I get my new distributor in a few days. I’ll post a video and some pics. :)
    loudbang and lothiandon1940 like this.
  21. Tribalmonkey
    Tribalmonkey
  22. Tribalmonkey
    Tribalmonkey
    I’ve also been messing with the 28 roadster. It had several small things that needed attention. Carb leaked really bad, also leaked coolant from the drain valve, doors were hard to close (latches wouldn’t catch), mech brake adjustment (of course), fluids, some cleaning and painting of parts…. 63DE9957-9A8C-42EF-8338-EC28F315C554.jpeg 789932CC-8C08-46AC-98DE-32A942FF1C51.jpeg
  23. Tribalmonkey
    Tribalmonkey
  24. vtwhead
    vtwhead
    TM, if you are rebuilding that 94 with a kit be aware that most all the kits have the wrong power valve. They appear right but won't seat correctly and leak. Vintage Speed in FL has the correct power valves.
  25. Tribalmonkey
    Tribalmonkey
    Thanks! I noticed that. I installed the original to see if it works. If not I’ll order one from Vintage Speed.
    Stogy, lothiandon1940 and loudbang like this.
  26. Tribalmonkey
    Tribalmonkey
  27. Tribalmonkey
    Tribalmonkey
  28. Tribalmonkey
    Tribalmonkey
  29. Tribalmonkey
    Tribalmonkey
    I really didn’t expect it to start right up. And then I was expecting something catastrophic to happen. I had my finger on the kill switch ready to shut her down. I also had a fire extinguisher sitting right behind me on the floor. I had already ran the starter to check compression and see if I could pump fuel to the carb. Then I connected the distributor, plug wires, and coil. So I guess it was ready to go.
  30. lothiandon1940
    lothiandon1940
    A Flathead making happy noise, a smoke filled garage/ shop, a smile on your face. It doesn't get any better than this. Happy Holidays to you, the wife and the boys...........Don.
