Projects 1933 dodge coupe "Baleful"
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Nov 8, 2021.
  1. oliver westlund
    oliver westlund
    Im gonna take bets..... who thinks i can fix this? 20211112_171147.jpg 20211112_171151.jpg
    rusty valley, dwollam and loudbang like this.
  2. trevorsworth
    trevorsworth
    Looks completely fixable to me. Just take your sawzall and cut away all that rusty metal and you should have a usable chair again! :D
    Jrs50, treb11, ottoman and 10 others like this.
  3. oliver westlund
    oliver westlund
    Hahahah
    kidcampbell71 and loudbang like this.
  4. scotts52
    scotts52
    I say if you think you can then I'm placing my bet on you.
    Jrs50, loudbang and oliver westlund like this.
  5. oliver westlund
    oliver westlund
    Thanks! We shall see if tgeres enough to weld to
  6. HemiDave
    HemiDave
    from Austin, TX
    Dang, I've got a 33 that looks almost exactly the same....I gotta go check the garage!!!
    Dave
  7. oliver westlund
    oliver westlund
    Very cool!
  8. vtwhead
    vtwhead
    E254 should be May 25 0f '54. In '54 the axle spline might be 29. later pieces went to 31 like you might find in '64. I would pull an axle and count the splines.
  9. oliver westlund
    oliver westlund
    Thank you! Ill do that. Very very cool!
  10. oliver westlund
    oliver westlund
    The mill...1950 olds according to paul, i scared up a 52 olds intake and carb though 20211112_172427.jpg
    treb11, Lil'Alb, brEad and 6 others like this.
  11. vtwhead
    vtwhead
    What is the plan for that engine? ******?
  12. AHotRod
    AHotRod
    YOU my friend have allot of repair and fabrication ahead of you, it's completely doable, been there.
    Get it blasted and get it in metal prep protection, then get a couple of sheets of cold rolled 18 gauge, stock up on consumables and welding materials and enjoy the journey.
    Congratulations on your new born !
  13. oliver westlund
    oliver westlund
    Engine turns over so itll probably get run as is for now. Trans idk...lasalle would be ideal. Wasn't worth it before but may be worth it on this one, definitely want to run a standard. I have a 37 ford 3 speed and adapter for the olds but that just doesn't fit this build
    dwollam, loudbang and Stogy like this.
  14. oliver westlund
    oliver westlund
    Thank you! I have a line on a cowl that should solve a ton of issues up front, (thanks dave) also have an offer from scott to fix my rumble seat lid and do some trading on a drivers door. Beyond that i have floors, rockers, some trunk, roof fill, roof above the p*** door and pretty much the entire bottom 3 inches of the car to fix. It will definitely be a journey! Loads of solid steel there though!
    Stogy and AHotRod like this.
  15. Rocky
    Rocky
    Classified Editor
    If push comes to shove maybe a grille shell from a different make would work. My buddy, Sonny's old 32 plymouth with repro 32 ford parts up front sonnys32plymouth.jpg
  16. oliver westlund
    oliver westlund
    Absolutely, thats plan b....swap meet hunt for something thatll look good...i think dave has a cpl other grills from different rigs im gonna check out too
    dwollam and Stogy like this.
  17. goldmountain
    goldmountain
    Check out the proshaper threads by Wray on Youtube where he makes flexible shape patterns on the "good" side so that you can replicate it on the really bad side. Then remake the "good " side also.
    loudbang, Stogy and oliver westlund like this.
  18. oliver westlund
    oliver westlund
    Cool! Will do! Thanks for the tip!
  19. Hollywood-East
    Hollywood-East
    If You made a tube/rod inner grill structure or parameter per say, the sheet metal outer might not be as intimidating.
    oliver westlund likes this.
  20. oliver westlund
    oliver westlund
    I was thinking about that...or making a wood buck with the basic lip and curve profile to form patches
    Hollywood-East likes this.
  21. oliver westlund
    oliver westlund
    Well...with a 1950 olds rocket and a 1954 olds rear diff. I think im gonna need an olds steering wheel. My fave is the 53/4 we sold an 60k original mile 53 olds a cpl yrs ago and i always loved that wheel. If anyone has one they want to sell gjve me a holler! Screenshot_20211114-112134_eBay.jpg
    Lil'Alb, Stogy and kidcampbell71 like this.
  22. oliver westlund
    oliver westlund
    Theres the 53 we had in the background Screenshot_20211114-112820_Gallery.jpg
    loudbang and kidcampbell71 like this.
  23. oliver westlund
    oliver westlund
    Well....made an effort to purdy up the rubber and wheels on this thing buuuut 3 of em are stuck haha so ill sit and look at my 1 and smile while the pb soaks 20211114_140116.jpg
    Stogy, scotts52 and kidcampbell71 like this.
  24. stanlow69
    stanlow69
  25. oliver westlund
    oliver westlund
    Cool! Yeah i dig it with the whitewalls im painting it the factory maroon and black color i think... Screenshot_20211110-120643_Google.jpg
    Stogy, scotts52 and stanlow69 like this.
  26. Rocky
    Rocky
    Classified Editor
    For a while we had a 34 Dodge with the long wheelbase around the Omaha area. Black and silver. It was outrageous when seen in person. I wish I'd taken a photo of it. Had Western Bullets on it and it looked very cool.
    oliver westlund and Stogy like this.
  27. vtwhead
    vtwhead
    Oliver here is the box we are using presently. circa 81-85 Jeep CJ Saginaw box, FWIW
  28. oliver westlund
    oliver westlund
    Cool! I think dave has a factory box and column im gonna go with. Fits my build a little better, always good to have a backup plan!
  29. oliver westlund
    oliver westlund
    Cool! I love these rigs
  30. oliver westlund
    oliver westlund
    Anyone have any awesome tips on getting crusty wheels off? Ive tried heat, hammers, prybars, pb blaster soaks... im runnin outta ideas
