Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Tim
    Tim
    from KCMO
    Maybe I’ll paint a 6 ball on the bench to remind me it’s not a shelf ;)
    Thor1, drdave, loudbang and 2 others like this.
  2. dumprat
    dumprat
    from b.c.
    Shelves above the roll up doors are great for totes of hot rod parts and random junk. I always find shelf space to be at a premium..
    Very nice garage though!
    kidcampbell71, Thor1, Stogy and 4 others like this.
  3. Tim
    Tim
    from KCMO
    That’s a good spot for a shelf! Thanks for the idea. I’m definitely putting effort towards things going up and getting off the floor
    Thor1, Stogy and loudbang like this.
  4. Six Ball
    Six Ball
    from Nevada
    Also a good time to go through it all again and make sure it is really worth putting in a tote on a shelf. Once you get behind and have boxes of mixed stuff piled on top of each other it is a ***** to sort it. When you are looking at taking more time to sort your treasures than to build your project you are in deep doo. :mad:
    Thor1, Stogy, drdave and 3 others like this.
  5. Tim
    Tim
    from KCMO
    Not much going on. Feels like I haven’t worked on the car in a decade. Took the 46 around the neighborhood to mix up a little antifreeze concentrate I snuck in now that it’s getting cold and the new garage isn’t heated. A2F8F02B-2C6A-4295-B101-0ADF59ACC89B.jpeg hopefully get some miles in tomorrow and get on the work bench soon. Got the space more or less cleared this week.
    brEad, kidcampbell71, -Brent- and 6 others like this.
  6. justabeater37
    justabeater37
    I took over a year off shop work in the moving process. It is like learning to weld, cut, and shape all over again. I keep losing motivation as my skills have slipped so bad without using them. That is why I figured I should not only tackle one of the hardest cars to chop and get right, but start with an absolute piece of twisted ****. It has been a frustrating return I have inflicted upon myself.
  7. Tim
    Tim
    from KCMO
  8. As a storage idea... I see you've got fairly high ceiling(s)... Mine are about 12' so I've got high shelves along each side that hold a lot of stuff and are braced to the wall and ceiling. Not real convenient for everyday access, but we've all got (too much) **** we can get off the floor and out of the way. Of course, in the normal fashion of things, it just clears up floor space to put newly collected **** in, so I don't know how much of a 'win' it is. Build a space, grow into it, overflow it.... it never ends.
    brEad, Thor1, Six Ball and 1 other person like this.
  9. Tim
    Tim
    from KCMO
    Yeah I’m trying my best to get stuff up and off the floor. Looks like tire racks went from $44 and everywhere to $150 and out of stock :S need to figure that one out.
    also need to find some good idea for storing metal and wood pieces. Probably time for some digging on garagejournal.com
    kidcampbell71, Thor1, drdave and 2 others like this.
  10. Tim
    Tim
    from KCMO
    kidcampbell71, Thor1, drdave and 3 others like this.
  11. Stogy
    Stogy
    Six Ball and loudbang like this.
  12. Tim
    Tim
    from KCMO
    Yeah I think it is. Found a thread with quite a few variations but I think I like this the best. Seems similar to what You find at ace hardware and tractor supply stores holding metal
    loudbang, Six Ball and Stogy like this.
  13. Tim
    Tim
    from KCMO
    Another idea, poorly cropped screen shot. Best I could get with out registering for Pinterest or something. 69FF5F92-D8DA-4591-970B-008EA3B155E0.jpeg
    brEad, kidcampbell71, Thor1 and 4 others like this.
  14. Stogy
    Stogy
    :rolleyes:...I really need one of those...
    loudbang, Six Ball and Tim like this.
  15. Six Ball
    Six Ball
    from Nevada
    Before I can use wheels I have to find the floor. :eek:
    brEad, kidcampbell71, Thor1 and 3 others like this.
  16. Tim
    Tim
    from KCMO
    Just lay a sheet of plywood over it all and start over lmao
  17. Six Ball
    Six Ball
    from Nevada
    Got to squeeze the plywood in between the junk and the ceiling.:(
  18. Tim
    Tim
    from KCMO
    Scissor jack?
    Stogy, Six Ball and loudbang like this.
  19. Six Ball
    Six Ball
    from Nevada
  20. Tim
    Tim
    from KCMO
    Needed some garage time so I started filling up a wall. A706588B-F6AD-4685-921C-0F8CA9369F12.jpeg A ways to go yet but neat to see something I drew out months ago on some s**** paper starting To take shape
  21. razoo lew
    razoo lew
    from Calgary
    Very cool. I think that you should show us a pic of both of the drawings though.
    Thor1, loudbang and Six Ball like this.
  22. Tim
    Tim
    from KCMO
    I was referencing the drawing of how I wanted to lay out the garage, I’ll snap a shot of it later today if you like.
    it’s changed and will continue to change but the idea is still the same :)
    Six Ball, Tman and loudbang like this.
  23. Tim
    Tim
    from KCMO
    brEad, Ragged Edge, patmanta and 5 others like this.
  24. Tim
    Tim
    from KCMO
    Work bench Lumber acquired! I’ll start marking and cutting the next few evenings and hopefully screw it together this weekend
  25. Tim
    Tim
    from KCMO
    Wall is almost full. 041BB7C1-D9E3-40E0-8029-2E2376C97E75.jpeg Smells like Lumber in here. I kinda like it.
    brEad, Thor1, drdave and 5 others like this.
  26. Six Ball
    Six Ball
    from Nevada
    In 1966 I worked in the molding plant at a saw mill. We cut at lot of yellow fir called "piss fir" because of how it smelled. Not the nice piney smell you think of. Tough to take with a hang over. :eek:
    Thor1, loudbang, WalkerMD and 2 others like this.
  27. Tim
    Tim
    from KCMO
    Oh buddy I bet lmao
  28. Tim
    Tim
    from KCMO
    While you wait for me to do anything worth while go check this out
    https://www.jalopyjournal.com/?p=49646
    joeys got some phenomenal photos in that journal entry. You’d be missing out if you didn’t go look
    Thor1, Stogy, Six Ball and 1 other person like this.
  29. Tim
    Tim
    from KCMO
    Needs a few more screws holding the top on but a coat of paint and the bench is ready to shove up to the wall and get put into use! F05387F5-D8C4-41B7-BAAD-9B6D00AA413E.jpeg 18EA4392-B2AB-43D3-B37B-1225894077E4.jpeg the top overhangs a little so I can put a power strip in the front and have it tucked under out of the way, and the back will get a few notches for cords for the drill press etc.
    very sturdy so far!
    Excited at the prospect of seeing the floor again!
    Thor1, drdave, justabeater37 and 3 others like this.
  30. Six Ball
    Six Ball
    from Nevada
    A row of drawers under the top and a bottom shelf?
