Projects 1917/1928/1938 American Lafrance Plymouth V12 Speedster
Discussion in 'The Hokey Ass Message Board' started by animal8324, Nov 17, 2020.
  1. warhorseracing
    warhorseracing
    from cameron wv
    Thank you Sir. I was just curious.
    Stogy and loudbang like this.
  2. animal8324
    animal8324
    from nj
    Piston and valves came in earlier this week. Im hoping to get it together by the end of august 20210710_082319.jpg
  3. animal8324
    animal8324
    from nj
  4. noboD
    noboD
    That is going to make a LOT of noise. I love it!!
    VANDENPLAS, loudbang and Thor1 like this.
  5. animal8324
    animal8324
    from nj
    Alittle update on my American Lafrance V12 Speedster.
    I located and installed a good piston tonight to replace the cracked one. I also finally got the sprockets in and have the bullgear mocked up.
    Still waiting on the head and gasket kit other than that everything to complete it is here.
  6. Garpo
    Garpo
    I think I would like a fairly substantial chain guard on the things to make list. Just a convenient hand swing from the seat.
    Might help prevent another Parry Thomas incident.
    LWEL9226, 41 coupe, 51504bat and 6 others like this.
  7. warhorseracing
    warhorseracing
    from cameron wv
    Probably not a bad idea from a safety standpoint. Also in the unlikely event of a chain breaking and thrashing around wildly.
  8. RodStRace
    RodStRace
    Not to mention a convenient place to hang a playing card to interact with the teeth! :p
    chryslerfan55, Stogy, cactus1 and 6 others like this.
  9. animal8324
    animal8324
    from nj
    The rear drumsand engine are coming together! 20211030_121927.jpg 20211030_141259.jpg 20211030_161233.jpg 20211030_162953.jpg
  10. This thing is neato!
  11. 1low52
    1low52
    I love this beast!
  12. animal8324
    animal8324
    from nj
    Got the heads on and 2 of the subheads. 4 of the subhead bolts stripped out in the head. I have helicoils on order. Hopefully this week i can get the other 4 subeheads on. 20211113_124837.jpg
  13. animal8324
    animal8324
    from nj
    Got the engine back together and fired tonight!
    Now it's time to plumb everything and get the sprockets finished up!
    I'll be showing it at Retro Rewind and Fins and Films next year
  14. RodStRace
    RodStRace
  15. 41 GMC K-18
    41 GMC K-18
    "Perfection cannot be rushed"
    "Everything old, is new again"
    Congratulations on getting the engine running! You might want to look up Henry Seagraves land speed racer " The Sunbeam slug, AKA mystery"
    March 29th, 1927, 207 MPH, this was a 1000 HP machine that featured " chain drive "
    Looking forward to seeing the ongoing progress of this cool speedster you are building!
    chryslerfan55, Stogy, Thor1 and 2 others like this.
  16. animal8324
    animal8324
    from nj
    I stared figuring out plumbing for fuel and brakes. The plymouth brakes have these weird *** banjos to the hose instead of the lines going directly to the wheel cylinders.
    Also got the headlights mounted.
    20211128_181454.jpg 20211128_181814.jpg Screenshot_20211127-144816_Chrome.jpg
  17. animal8324
    animal8324
    from nj
    Productive day. I got the motor sitting on rubber bushings, the clutch pedal is now connected to the clutch, the gas pedal is mocked back up, the Fuel tank cap is attached to the fuel tank as well fuel line being ran, and i've began on the brake plumbing.
  18. animal8324
    animal8324
    from nj
  19. animal8324
    animal8324
    from nj
  20. j hansen
    j hansen
    That`s what I call a brake drum!!
  21. animal8324
    animal8324
    from nj
    20211224_114906.jpg 20211224_114906.jpg 20211224_114906.jpg 20211224_114906.jpg
  22. animal8324
    animal8324
    from nj
    Wheels are back on and I had to roll it out for a few pics!
    Brakes and right side chain drive is all that's left for final mockup then it's time for shows for the summer followed by a piece by piece teardown for paint/plating next winder
  23. noboD
    noboD
    With those chains you shouldn't need a horn. They will hear you coming. I like it!!
  24. warhorseracing
    warhorseracing
    from cameron wv
    Looks like some one has been doing burn outs in the driveway.:D
  25. Stogy
    Stogy
    Black paint on a tire perhaps...or the tire that just wouldn't roll and the winch won...?
  26. animal8324
    animal8324
    from nj
    We hold Burnouts for my show Fins and Films at my shop I built this at.
  27. Stogy
    Stogy
  28. warhorseracing
    warhorseracing
    from cameron wv
    A lot of time in my youth spent at the drag strip.:cool:
  29. animal8324
    animal8324
    from nj
    Got her to run on her own tank and idle tonight!
    Now it's on to cooling and brakes!
