Technical advice on bad machine work
Discussion in 'The Hokey Ass Message Board' started by buick bill, Nov 15, 2021.
  1. alanp561
    alanp561
    Diesel works just as well and doesn't burn as easy.
    Boneyard51 and buick bill like this.
  2. 48fordnut
    48fordnut
    I like the idea of taking the head to the shop, having a lot of expensive work done and not picking it up. 5B006E08-5961-4EA4-8F77-3AE8FB04CBA8.jpeg
  3. Budget36
    Budget36
    That’s what the grind on the valve looked like to me.
    Boneyard51 likes this.
  4. buick bill
    buick bill
    from yreka;ca
    the only problem with that plan is it doesnt get my $600.oo . but i guess im going to eat thar ! i like the plan where i just run the orig. head that had no defects and settle for 8.0 compression instead if 8.2 ., oh i guess hind sight is real good . as to the valve . it bent when it stuck open and contacted the piston .before that everything was working . i dont see how a bent velve could be ground . it would be obvious as it spun . the only thing that makes since is a alignment problem with the guide and/or the seat . either way i think i will be re-installing the orig. head today . i will dis ***y. it and check the guides , maybe a light hand lap . and if all is good do a FINAL install .
    alanp561 and Boneyard51 like this.
  5. 48fordnut
    48fordnut
    When the problem occurred is when the ketchup should have appeared. Your money is gone. 90% of shops won't claim their bad doing. Just have it as a learning lesson. Leave well enough alone.
    alanp561 likes this.
  6. 57JoeFoMoPar
    57JoeFoMoPar
    Totally agree. Bunch of ****ing s***bags.
    In all seriousness, this is not a situation where it would be worthwhile to bring suit in small claims court since you would need to present some sort of expert testimony as to why the work that they did was shoddy as opposed to you simply installing it wrong or some other reason. Remember, this is a civil action and the burden of proof is on you, not the defendant, to prove every element of your cause of action. Experts are expensive in any field, and it's a poor business model to spend thousands to get back $600. Cut your losses and move on.
    Elcohaulic and Boneyard51 like this.
  7. you know, more and more it is hard to get good help anymore. I think some of the reason for this is that too many people just deal with it/ eat the loss and go on, paying someone else to do it over or just live with the flaws. If the customer would come back and complain, maybe, just maybe the vendor would think about it before doing shoddy work. I'm not saying go in there with guns a-blazin' but go let them know they screwed up and what it would take to make you happy. If they tell you to pound sand, so be it at least you let them know what they are. Otherwise they just keep getting away with it. They may even think they did a good job, and if the boss never knows he thinks his employees are performing quality work.
    Just my thoughts ....
  8. buick bill
    buick bill
    from yreka;ca
    well brought it back . dyed the seat . perfect .ran a hone down the guide to remove the burr pulled the valve from the next cylinder . perfect seal . seats not to deep . we agreed that hard seats were not called for in this application. so no one can figure out what caused the problem . he is going to open up the guides to the next size .replace the valve and we will see . the ONLY idea i can come up with is a slightly off / bent valve .? it was new and not ground or anything so factory fkup ? talk about no luck . im still on the fence about re-installing the orig. head . ill make someone a good deal on a cmplt rbld 848 235 head !!!
    Hnstray and carpok like this.
  9. KenC
    KenC
    [QUOTE . the ONLY idea i can come up with is a slightly off / bent valve .? it was new and not ground or anything so factory fkup ? talk about no luck . im still on the fence about re-installing the orig. head . ill make someone a good deal on a cmplt rbld 848 235 head !!![/QUOTE]
    If it was a new valve it may well have been defective. I don't know of anyone that installs a new valve without chucking it up and ***uring the grind is right. Since almost not commercial shop laps valves anymore, the refacing machine is a must to ***ure a true seat, even (especially?) on a new valve.
    Algoma56 likes this.
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    Do unto others.....
    5window, 6inarow and Hnstray like this.
  11. badshifter
    badshifter
    Beanscoot, joel, uncle buck and 2 others like this.
  12. buick bill
    buick bill
    from yreka;ca
    not the gas . its been started at least every wk . my experience with varnish is it works fine till it cools then on start up your stuck up . i have way more varnish experience than i ever wanted !! anyway if the valve was bad . which is the only explanation im left with . the shop seems like they would have caught it . they say they vacuum check all valves and some how it was good .anyway they are accepting responsibility for what thats worth . so im just out the trouble .and 3 sets of gasket and several 100 mi. loops . if there is no damage to the mtr /piston and related i guess its all good . or it is what it is ! i tore the orig. head appart . condition was as expected . intakes were fine . exhaust is in need of guides there was a quite a bit of damage on cylinder #6 .apears to have ate a valve in its past. but it had been repaired so was just old and ugly . it did have 3 intake seats replaced . which seemed strange to me. so my replacement of the head wasnt such a bad idea . if i ever get it right .
    wandi harry and 5window like this.
  13. wicarnut
    wicarnut
    Sorry to read about your learning experience, automotive machine shops are like every other service a person buys through ones lifetime, 10% great, 30% acceptable, 10% barely acceptable, last 50% unacceptable, **** work, just plain bad. I started building engines at 14, 1962 , I had machine shop in school so I learned how to measure with proper tools to check various dimensions, such as crank diameters after a regrind or polish, rod and mains ID with bearings torqued, bores, head work rebuilds, guides, seats, lap valves to check seat, ***embled heads myself after checking everything, etc. I dealt with several shops in Milwaukee area through the years back in the day and could write a book on **** work received 1 time, never gave anyone a second chance till I found a competent shop, only a few IMO. Also I learned to discretely mark my parts as you might not even get your own parts back. As a young man I worked for SESCO racing engines, learned some skills there that served me well all my life. In my later years with my hobby cars I did not rebuild engines, just bought crate engines as through time the 2 shops I dealt with the owners retired and I have Been There, Done That. So........ My free advice, Caution ! Free advice is sometimes worth price paid. Talk to people to get a reference on any service hired, check with local BBB, never pinch the nickel hard, you tend to end up with a handful of buffalo ****, as a general rule of thumb, you tend to get what you paid for. Good Luck, maybe someone on here can point you in the right direction.
  14. 6inarow
    6inarow
    Well sometimes the ultra high compression 848 heads arent worth it. You were right on in post 64. these old 235s shouldnt be that complicated, but maybe they have no experience with them. Might be worth talking to a few inliners in the area for a good recommendation
  15. TrailerTrashToo
    TrailerTrashToo
    Quote of the day!
    wicarnut and Boneyard51 like this.
  16. Bob Lowry
    Bob Lowry
    Hey Bill, when I did a 671 blower on my '46 Chevy, it was a bear to lift it off and on by myself. I made a "sling"
    that attached to the ends of the blower and used my cherry picker to easily pick it up. Maybe something similar
    would work for your head. I do feel your back pain....Bob
    X-cpe, Desoto291Hemi and Boneyard51 like this.
  17. I vote for putting the original head back on.
    6inarow and 48fordnut like this.
  18. Dan Timberlake
    Dan Timberlake
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
  20. buick bill
    buick bill
    from yreka;ca
    wonder no more .the spot , if you can make it out , on the left is where the stem seized in the guide ! DSCF5615.JPG
  21. buick bill
    buick bill
    from yreka;ca
    does anyone think my attempt at resurfacing the rockers could have been a contributing factor ? DSCF5618.JPG DSCF5620.JPG DSCF5621.JPG
  22. 55blacktie
    55blacktie
    I wonder how many marriages the H.A.M.B. has saved by allowing us to vent our frustrations here, rather than beating our wives.
    427 sleeper and Boneyard51 like this.
  23. Bob Lowry
    Bob Lowry
    All of them....
    427 sleeper, Boneyard51 and Baumi like this.
  24. buick bill
    buick bill
    from yreka;ca
    sometimes im trying to post and mine wont shut up !! but i have got good at blocking her out when need be !!
  25. Here is the rub, there are sloppy machinists everywhere and there always have been.
    I have tried several solutions to your problem over the years, often they involved violence. I cannot recommend them to you. The feel good from the solution seldom outlives the repercussions.
    Someone recommended cutting your losses. I am not sure that this will make you feel good but I do think that it is good advice.
    Machine shops thrive on repeat business and word of mouth. They may not ever care if you do not return and may not know why their business is not as good as it could be if your friends never shadow their door but it may save someone you know some headaches. Not recommending them to others is a good way yo recoup what you have lost with them.
    48fordnut, Boneyard51, kjmmm and 3 others like this.
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    Sorry ,but that's retaliation , not only is it petty but unless you have no conscience , isn't very satisfying in the long term ! IMO
  27. egads
    egads
    Sound's like the machine shop is trying to take care of it. Good on them. ( No one is always perfect!! )
    Desoto291Hemi likes this.
  28. buick bill
    buick bill
    from yreka;ca
    yes they say that it will be right . this time . it wouldve been nice if it was right the first time . the second time......... oh well .but i sure hope the third time will be the charm . i guess im heading 150 mi each way to get the rockers resurfaced . i doubt that my attempt was or could have contributed . but all i can do is to rule anything i can out .i guess if my facing wasnt square it could load one side of the stem .dosnt seem to likely . but im wrong more than i care to recall
    Boneyard51 and egads like this.
  29. Flathead Dave
    Flathead Dave
    from So. Cal.
    Had the exact same problem with a shop in Riverside. Took my 8BA heads in for a cleaning, decking and crack check.
    Went to pick them up and was told that everything was good to go. The crack was so visible that the martians could see it from Mars. When I mentioned the crack, I was told that it isn't a crack. HAHAHAHA...
    I had a cola in my hand and proceeded to poor some of it on the valve relief side and watched it sieve through the head and drip on to the counter top.
    I got my good head and didn't have to pay the bill.
    I will never go back to that place.
    Algoma56 and Boneyard51 like this.
  30. Truck64
    Truck64
    from Ioway
    Yep, mistakes are gonna happen, it's how they are handled that matters.
