Technical Saving 70s paint vs rust
Discussion in 'Traditional Hot Rods' started by panhead_pete, Nov 16, 2021.
  1. panhead_pete
    panhead_pete
    After nearly 6 months of waiting my coupe turned up today and its a little rougher than I hoped but that's typical when buying cars unseen and them spending 6 momths in storage and shipping. Anyway Im looking for some suggestions on how I can approach this. I've not really done body work before and Im not really interested in stripping the whole car and starting again, more so tidying it up and preserving what's there.
    Initial thoughts was sanding the majority of the rust out and applying Gibbs or similar??????
    248170112_611553229993449_7830077828416529084_n.jpg 257273851_1261215797712020_6209679782646750338_n.jpg 257733500_1821125338078447_2363283751181586188_n.jpg 257766149_412539887207486_5426334092094100663_n.jpg 257852741_4782211768477216_7281673983657970607_n.jpg 257927937_1019130655595994_8720878189052006030_n.jpg 257952633_1050116765554626_5971877145647617113_n.jpg 258456984_1102725527135924_3652732009635650602_n.jpg 258750207_1299418843838688_1835239100826270510_n.jpg
  2. alchemy
    alchemy
    That's a lot. I'd consider that an all or nothing car.
    On my car, which is almost the same, I did nothing. I don't store my car out in the weather, so it doesn't get worse. But the patina is an acquired taste. I just happen to have the taste.
    sko_ford, rod1, redoxide and 4 others like this.
  3. panhead_pete
    panhead_pete
    I have that taste too but this will need to go through an inspection here in Japan and will need to look tidier than it does :)
  4. squirrel
    If you can keep it dry, you're probably better off doing nothing, until you can fix it right.
    What is the inspection for? Is it for appearance? or structural integrity?
    Cosmo49, panhead_pete and VANDENPLAS like this.
  5. evintho
    evintho
    That's a little beyond 'tidying up'! The paint needs to be stripped, the rust addressed and completely redone. On a positive note....the chrome and chop look good!
    sko_ford, HunterYJ, RodStRace and 5 others like this.
  6. williebill
    williebill
    IMHO, the paint that's still there isn't bonded to the metal anymore, and is just waiting for gravity to finish removing it. That car deserves better. You can strip some of it with your fingernails. There isn't anything to save. Time to roll up your sleeves.
  7. rusty valley
    rusty valley
    Lots of thick bondo, cracking like old lacquer maybe. I think it may be a "primer" paint job for a while until its done right
  8. trevorsworth
    trevorsworth
    That paint is toast, looks like it never had good adhesion to the metal and now it's just flaking away as rust forms beneath it. You're not gonna be able to get a nice patina out of that.
  9. swifty
    swifty
    Buy yourself a buffer- mine was A$70 at Supercheap, and a pile of 3M stripper discs- about A$25 each and get rid of all the paint and bog then spray a good 4 coats of 2K epoxy primer on it which is waterproof. You'll have a nice grey coupe then. Round here we use Lesanol brand which is $180 for 4 litres, comes from Indonesia I think. Can't remember the number but I've got a can in the shed. Don't pull it apart, just do some hand sanding in the delicate areas, like that beautiful grille, mask it and spray it. That should hold it until you're ready to go further.
  10. SR100
    SR100
    I agree with the others, that paint is toast. The question is, will primer p*** inspection or will you need to go all the way?
  11. oldolds
    oldolds
    Another vote for new paint
  12. Baumi
    Baumi
    I´d strip off the loose stuff and hit the bare areas with OWATROL, that´s a Linseed based rust inhibitor.Looks great too!
    panhead_pete likes this.
  13. Car needs to be stripped.. Its FUGLY !
    Patina is one thing and that car does not have it..
  14. Jeff34
    Jeff34
    I guess I may be in the other camp here. I say clean it up as best you can to p*** inspection, then you can decide what to do with it later. Best to get it “approved” and then figure it out. Just my $0.02
  15. da34guy
    da34guy
    Hit it with compressed air (120 lbs or more) Betcha alot more comes off
  16. That’s a neglected car, not patina .
    samd it best you can and hit it with flat black for a quick and dirty clean up.
    might want to “ create “ patina,” a somewhat clean “ ratty” car would look better then what you have and could be done in a week end
  17. Blues4U
    Blues4U
    from So Cal
    I'm thinking putty knife and wire brush to remove as much of the loose stuff as you can, the some Rustoleum flat black from a rattle can.
  18. Squablow
    Squablow
    My newly found '41 Cadillac convertible has a big patch of paint missing with rust like that, but luckily it's only one big spot on one front fender and the rest of the paint is much more intact. I plan to tape off the whole surrounding area and sandblast the rusty spot, then prime and paint over that area, blending in the edges as best I can. I don't mind if it looks "touched up", I just want to keep the paint.
    Your car is going to be a lot tougher though, since there's way more than 1 spot and the rust looks pretty heavy there. You could attempt some of the rust dissolving chemicals like stuff that Eastwood Company sells, although I don't know if that will discolor or ruin the surrounding paint or not, and I'm not sure how good of a job it will do on deeper rust like that. Worth a shot, can't possibly hurt it any.
    Some of those spots are big enough you could do the masking and sandblasting thing, but it looks like some of the surrounding paint is ready to fail as well, and you're going to have some very large areas of filled in paint.
    I know all too well the allure of saving very old paint, and if I were you I wouldn't be afraid to try since if you end up having to strip it anyway, nothing you try is going to hurt it any. But you've got an uphill battle with this one.
  19. ClarkH
    ClarkH
    Dang, dude! First a Model A and now this?!?! How many cars did you get in that shipment? I'm jealous. :D
  20. Dooley
    Dooley
    from Buffalo NY
    What's the difference between patina and neglect?
    Some spots look OK from a rust standpoint but others are getting bad.. but you can always add new metal and let that rust as well
  21. Bandit Billy
    Bandit Billy
    Car, like fence, need paint
  22. jimmy six
    jimmy six
    You should do what you want as everyone here has an opinion on what they would do. Patina is on old br*** lamps. I’d take it apart and remove all rust and filler then repaint to your desire. Clear coated rust and paint cracking is just that and personally not for me. I p*** by them a gatherings unless it has something else interesting. Good luck with your project and delema.
  23. dana barlow
    dana barlow
    from Miami Fla.
    New shiny paint all the way..*****...........................The're zero ways to make "patina" be anything other then gone bad an is rotting!
    Even the word "patina" is a fake way of saying"Needs fixing"so pretend to like how it looks:(,,and pretend they are not just to lazy too fix.
    If you can't do it your self,maybe make a trade to some-one who can,for something you can do for them.
  24. 57Fury440
    57Fury440
    That's a nice car. Strip all that old paint off and do it right.
  25. Baumi
    Baumi
    Now that I have looked at your pics on a computer screen instead of my phone I ´d change my opinion from " hit it with Owatrol" to hit it with a die grinder... looks like most of the paint is cracked and already lifting and I bet there´s quite some rust under the lifting paint almost everywhere... If it was my car, I´d grab a few cold ones, spend a night or two in the garage and see what a great idea I come up with after finishing the last one. That´s what usually works for me:D That is still a beautiful car after all, it just needs that paint removed. I even think it could look great in bare metal...
  26. alchemy
    alchemy
    Didn’t I see that car in Rodders Journal? Coverage of the big show on the east coast.
    VANDENPLAS likes this.
  27. Pics of the whole car please?
  28. Rckt98
    Rckt98
    Please do justice to that car with a nice paint job. Back in the day, you wouldn't be seen driving a hot rod around that looked like that.
    BamaMav and joel like this.
  29. gene-koning
    gene-koning
    That is not patina, its rusty metal with terrible paint and filler.
    Strip it to bare metal, the treat it with a rust converter and prime it until you get ready for the inspection. Will a good coat of uniform primer p*** inspection?
    redoxide likes this.
  30. Tickety Boo
    Tickety Boo
    from Wisconsin
    The salt in the air at your location has got no mercy on the bare metal, get some protection on it A.S.A.P.
