Hot Rods So. Mart's old T-Bird, then. Will it start, or what? Plus Old Rusty Rad investigation.
Discussion in 'The Hokey Ass Message Board' started by Mart, Nov 12, 2021.
  1. Mart
    Mart
    I was reorganising the garage and needed to move the T-Bird. It hadn't ran for ages so I decided to see if it would start and run around the block. Perfect video fodder! I then pick up the problem of water ejection on Old Rusty. I found the problem and eliminated it. I tack on a little bit of tinkering on the 32 sedan to round out this weeks offering from Mart's Garage video productions PLC.
    Thanks for checking in on me, you take care and I'll catch you on the next one.
    Mart.
    Thor1, dana barlow, SPEC and 7 others like this.
  2. stillrunners
    stillrunners
    from dallas
    Nice.....glad she fired up !
  3. deathrowdave
    deathrowdave
    from NKy
    Fun stuff, thanks for sharing
  4. Mart
    Mart
    Thanks fellas. Bumping it here for the Saturday crew.
  5. A Boner
    A Boner
    Thanks, Mart!
    Thor1, Mart, winduptoy and 1 other person like this.
  6. SPEC
    SPEC
    Thanks for sharing.
  7. hotrodA
    hotrodA
    I love that ‘Bird!
    You have some GREAT cars.
  8. Mart
    Mart
    Thanks fellas.
    How about a bump for Sunday!
  9. JWL115C
    JWL115C
    Mart, enjoyed the video on YouTube. Regarding the radiator problem. Don't see how your coolant recovery system would work with that radiator. It seems to me all it will do is collect and store coolant that has overflowed from the radiator. Good point about the shallow and deep radiator caps. The cap must match the depth of the radiator fill neck. Keep them coming.
    Thor1 likes this.
  10. Mart
    Mart
    Yeah, JWL That setup was for a previous rad. Hopefully the current rad will work ok after "finding it's own level" without any recovery system in place. I have bought a new cap with a rubber seal just in case. I can reinstate some sort of recovery system if it is needed.
    Thanks for watching the videos, glad you enjoy them.
    Mart.
    Thor1 likes this.
  11. Fortunateson
    Fortunateson
    Another great video as always...
  12. JWL115C
    JWL115C
    Mart, still confused about your coolant recovery system. The overflow tube is in the neck above the lower seal of the traditional style pressure cap. How does coolant get past the lower seal on the cap to transfer overflow coolant back into the radiator?
    I had an overflow tank on my 32 three window. An attractive chrome one. All it did was collect overflow from the radiator, but could not transfer it back due to the location of the overflow tube. I removed it and just use an overflow tube that dumps coolant on the ground instead of the tank. I believe later model cars do use a coolant recovery system, but with a different style cap and plumbing.
    Looking forward to Friday's posting.
