Hot Rods Help id old 4 speed
Discussion in 'The Hokey Ass Message Board' started by el marage, Nov 17, 2021.
  1. el marage
    el marage
    Found today. Who made it. 3 or 4 speed?
    Thanks 20211117_134110.jpg 20211117_134345.jpg 20211117_134253.jpg 20211117_134439.jpg 20211117_134521.jpg
    Deuces likes this.
  2. 1956victoria
    1956victoria
    loudbang and Deuces like this.
  3. greybeard360
    greybeard360
    AMC used a real long input shaft like that.
    Deuces likes this.
  4. squirrel
  5. Truckedup
    Truckedup
    Yes 833.. are the shift levers positioned one up and one down? If so it's an overdrive 4th gear
    Deuces likes this.
  6. That’s a very old Mopar A833 4 speed,,,,,for an A body .
    It’s at least late 60 ,s model,,,,it takes a slip yoke drive shaft and not the old trunion mount shaft .
    It also is wearing an old Inland shifter,,,,funnn .
    Looks like it has been in the weather for some time,,,,,even for Southern California .
    Tommy
    loudbang, Deuces, 427 sleeper and 2 others like this.
  7. 1934coupe
    1934coupe
    I thought it was Mopar.
    Pat
    Deuces likes this.
  8. lippy
    lippy
    from Ks
    Yep A-body. B-body shifter would have been at the front of tailshaft housing. And if it was an overdrive 833, the throw out bearing collar would be larger at the bolt flange at the case. Takes a different bellhousing unless you open the hole up on the bellhousing. I think a lot of pickups used the overdrive 833. Lippy
  9. el marage
    el marage
    Deuces likes this.
  10. el marage
    el marage
    Thanks for the comments.
    Deuces likes this.
  11. mgtstumpy
    mgtstumpy
    23 spline input shaft similar to FE powered 1962 Galaxie T10s?
    Deuces likes this.
  12. jimmy six
    jimmy six
    It’s rusty and heavy
    Deuces likes this.
  13. SS327
    SS327
    And tough as nails.
    lemondana, Deuces and Desoto291Hemi like this.
  14. deathrowdave
    deathrowdave
    from NKy
    Mopar is the winner
  15. lippy
    lippy
    from Ks
    Yes other than the hemi box, it's a real tough box. The three speed is a very tough box also. If the old 3 speeds would handle max-wedges, they were tough. Lippy
    Deuces, SS327 and Desoto291Hemi like this.
