Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. EVERY run spins the tires at some point! As Stan noted, flat spin
    loudbang and Stogy like this.
  2. AmishMike
    AmishMike
    If u get super low, beware loading trailer or keep set big tires for moving around
  3. john mullen
    john mullen
    10.4 will do thanks
  4. Daddy_O
    Daddy_O
    Flat spins.....bad. You have to go back through tech again and p*** before you can make more runs.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks Daddy_O
  6. john mullen
    john mullen
    That's a good thing, need to make sure nothing is broken or out of place.
    Safety first...
    Stogy and loudbang like this.
  7. But on the plus side you get your Spin Pin and join the infamous club
  8. jimmy six
    jimmy six
    The last thing I want anyone to know..
    Tman and loudbang like this.
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Does anybody have a pic of a SpinPin? I googled it.
    NADA.
    Is it real or just a fic***ious thing?
  10. Stan Back
    Stan Back
    Spin-Out Club
    El Mirage Ladies Auxiliary (Yours for a Donation -– Check Your Toe-In)
    Jet96, Lepus, Just Gary and 7 others like this.
  11. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks Stan Back. I ***ume you can also earn one at other LSR venues then. And that the toe-in suggestion does not have a thing to do with camel toe. Had me wondering.
  12. Stan Back
    Stan Back
    As far as I know, it's only an SCTA thing.
    In our case, dragging the front end sideways at 200 MPH can, sometimes, stretch one piece or another out of specs.
  13. 51504bat
    51504bat
    Not to mention what it does to your shorts.:cool:
  14. loudbang
    Just the pin :)
    Stogy likes this.
  15. john mullen
    john mullen
    Stogy, Just Gary, loudbang and 4 others like this.
  16. john mullen
    john mullen
    Finished up the engine mounts and installed the bump stops for the axel.
    Set at 1/2 inch off the pan.
    D-Russ, Stogy, saltflats and 2 others like this.
  17. fegsta
    fegsta
    How is cj, and Steve coming along. Hope all is well. Grate fabrication work John. I liked the stance as was, but if this makes all the difference then so be it. All the best Tim
  18. john mullen
    john mullen
    Thanks Tim,
    Steve Is out of intensive care and is in rehab doing much better, CJ is doing well also.
  19. john mullen
    john mullen
    Happy Thanksgiving to all my H.A.M.B. friends and family near and far.
    May you enjoy great food, family and friends making new memory's together.
    It's been a tough year but I am hopeful for the year to come to be better
    Stogy, saltflats, Just Gary and 4 others like this.
  20. john mullen
    john mullen
    Just in.. Steve Strupp is out of rehab and headed home.
    Still needs rest but is on his way back to good health
  21. fegsta
    fegsta
    That's grate news, I feel like I no these people although we have not met yet. Happy thanks giving to one and all. (we don't do this over here in England.) all the very best Tim
  22. john mullen
    john mullen
    Finished mounting the axel and shocks today 20211127_140343.jpg 20211127_135951.jpg 20211127_135939.jpg
  23. john mullen
    john mullen
    Stogy, D-Russ, loudbang and 2 others like this.
  24. loudbang
    XXL__, fegsta, Stogy and 1 other person like this.
  25. john mullen
    john mullen
    Not to be cut out these are upper shock towers
  26. loudbang
    Ok understand it now. :) I thought it might be for axle clearance.
    Stogy likes this.
  27. john mullen
    john mullen
    The og Notch is enough with 1/2 to spare.
    Stogy, D-Russ and loudbang like this.
  28. john mullen
    john mullen
    I started fabricating the panhard / centering device for the front axel today. I'll post more photos as it comes together 20211130_125838.jpg 20211130_155516.jpg 20211130_155552.jpg 20211130_155920.jpg 20211130_155519.jpg p
    loudbang, Stogy, D-Russ and 1 other person like this.
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    With all that frame structure available on each side I'd be tempted to use a Watts linkage.
    tomkelly88 and kevinrevin like this.
  30. john mullen
    john mullen
    I would but the dry sump pump is in the way ergo this system is the next best thing
