Projects 1934 3W in Japan
Discussion in 'Traditional Hot Rods' started by panhead_pete, Nov 20, 2021.
  1. deathrowdave
    deathrowdave
    from NKy
    Don’t take them off , if you choose to remove them , box them up send them to me !
    Spooky likes this.
  2. panhead_pete
    panhead_pete
    I'll try and respond to some of the quiries etc :)
    I sure hope so otherwise its going to be an expensive garage toy. :) In all seriousness I think I should be able to as have seen some severe chopped and channeled cars here, just not 100% sure what it will need but will be going down to check on that in the near future (Test centre is 90mins away)
    Cheers Bob, definetly going to start labelling wires as I find out what each does. Im sure my patience will be tested but it will be a fun project over the winter.
    Cheers its going up on a hoist this week when I get the temporary registration for it. Its been on the road quite a few years after being found and well maintained after that but always worth checking. Im also keen to see how the ch***is was constructed.
    I reckon this is correct so thanks! Im toying with the idea of sanding down the remaining bondo and painting the roof in a matt POR15 or similar but would prefer to keep it as is.
    Will let you know when we know. Hopefully not toooo much :)
    Thanks to @squirrel and yourself re that toner, had not thought of that and will get one on its way! Very salient point re the cowl vent gasket. I freed up the door yesterday as it was a little sticky and the gasket is toast. Im with you on the cowl lights, just going to check I dont need parking lights prior to doing that.
    Is anyone aware of an off the shelf rubber plug or similar that would fit the cowl lights hole as I'd rather not weld on the car if possible.
    @trevorsworth As I understand its running a 350SBC with single 4 barrel and a Muncie with early 70s vette rear.
    Hope that covers it and once again thanks for the interest and help fellas!!
    chryslerfan55 and catdad49 like this.
  3. panhead_pete
    panhead_pete
    Hahaha if they come off they wont be going anywhere :)
    Okie Pete and Desoto291Hemi like this.
  4. rusty valley
    rusty valley
    Cowl light holes are a good spot for mirrors
    panhead_pete likes this.
  5. SS327
    SS327
    Leave the cowl lights on it. That car looks elegant with them on it. One of the few in my opinion. Have you talked to MoonEyes in Japan? They may be able to talk you through the process. Or at least a list of do’s and don’ts. Their home base is now in Japan.
    panhead_pete and trevorsworth like this.
  6. redo32
    redo32
    The knock off lug covers would look good bead blasted and shot with "Ceracote" graphite or matching color with the wheels. Then keep your eyes out for Halibrand style KO.
  7. tom brown
    tom brown
    Most electric problems come from poor ground connections--usually from setting- Clean- Clean-Clean! Great ride.
  8. squirrel
    I've found that most electric problems on a car that's been sitting, come from dirty switch contacts, but poor grounds at light bulbs are a close second.
    rod1, Stogy, Snicklefritz65 and 2 others like this.
  9. continentaljohn
    continentaljohn
    Awesome car Pete and congratulations on getting. We used Brady I’d wire markers for the machines we built. They are just simple stickers with numbers . It’s great because you can identify with a simple ledger . image.jpg
  10. alfin32
    alfin32
    from Essex, Ma.
    Awesome find!
    Is this the car out of Maryland with the Corvette IRS?
  11. panhead_pete
    panhead_pete
    It is indeed. :)
    Cheers mate, I have a toner on its way and as I work my way through the car with it will be cleaning as many contacts and earths as I can.
    Thanks! I didnt know those existed so will order some up and get them on the way.
    I have been chipping away at a few things and removed the sill plates as was a tad worried what I might find under them but it appears to be all super solid.
    Whilst I was there I thought I'd tidy it up a little and sprayed the sill plates black which works better for my eyes.
    A cool find whilst I was looking at the wiring under dash was a lot of small metal plaques on the firewall. Will be interesting to see how many more there are but some are dated from the 70s.
    So a good couple of small wins for the day. Im thinking the body is really solild under the paint but wont know for sure unless it all comes off which Im still wanting to avoid although the car definetly has dandruff. My plan is to keep chipping away at it as I can although need to focus on getting the A coupe running and hopefully sold. I had planned to keep that too but our business is being severely impacted by C19. :(
  12. Snicklefritz65
    Snicklefritz65
    from Mass.
    man that's a wicked car. and the plaques sure are neat too.
    congrats on a nice purchase!
    kidcampbell71 and panhead_pete like this.
  13. panhead_pete
    panhead_pete
    Thanks for all the kind words. I just see myself as a caretaker of the car. Jay the previous owner was the one that saved it.
    Another little win today. Looks like a corvette gave up quite a few parts back when the car was built. The hand brake release ****on spring was not working and fortuneatly Jay had included a whole ***embly in the trunk.. With a bit of cleaning and knocking out a couple pins I was able to replace the lever from the spare one. All that **** on the sheet came out of the inner handle...
    Works a treat although getting the large pin back in place proved difficult so have replaced it with a bolt for now.
    Does anyone recognise these seats? Im guessing more corvette parts but that's only a guess.
  14. 8ntsane
    8ntsane
    Congrats on the new ride, looking good. You must be a happy man. :cool:
  15. SS327
    SS327
    Late 60s early 70s Corvette.
    Snicklefritz65 and panhead_pete like this.
  16. Stogy
    Stogy
    Nice Hotrod @panhead_pete...can't wait to see you get it back to speed...hard to beat the Make and Model...careful p***ing them Ole Billboards...;)
  17. RodStRace
    RodStRace
    Checked pics for seats in 60-70s 'vettes, camaros, novas and el caminos. No match to the slim back, s***ching pattern and back 'lump' at the top.
    The latch ****on to hold seatback locked in the center along with lack of added headrest is going to narrow the year. I'd guess mid sixties to early 70s (if the headrest was removed and covered over). IIRC, 1970 was headrest required.
    Closest I found was 68 Chevelle. 69 had the ****on high up on the back. They had trim along the side edges, though.
    If someone here doesn't nail it, I'd email pics to one of the resto upholstery places.
  18. panhead_pete
    panhead_pete
    Thanks all, asked around on some corvette FB groups and apparently not vette. Hopefully we'll work it out soon.
  19. belair
    belair
    WOW. That thing has "The Look." Congrats,
  20. redo32
    redo32
    seats look like '70 Barracuda.
    chryslerfan55 and panhead_pete like this.
  21. Those seats are not Mopar E body,,,,,I know that for sure .
    Tommy
    Just Gary, SS327 and panhead_pete like this.
  22. S****e, sand, POR15 the whole car and drive it.
  23. RodStRace
    RodStRace
    RE: Barracuda
    s***ching sideways, not front to back (could be redone) Challenger was different, but also not a match.
    high backrest/headrest
    no 'lump' on back of seat (more of a GM thing)
    latch on side, not middle bottom
    much thicker back cushion
    side and back plastic trim
    =no
    68 GTO shown, but wrong latch, and added headrest (option?) and side trim, as mentioned
    Notice the 'lump' at the top back of the back cushion? Closer, but not it.
  24. RodStRace
    RodStRace
  25. panhead_pete
    panhead_pete
    Thanks to all that have tried to help.
    @RodStRace they are the closest looking seats, particularly the brackets, thanks.
    RodStRace likes this.
  26. fleetside66
    fleetside66
    I'm digging' the nerf bar, Pete. Subtle & elegant. Good luck with it & keep us updated.
  27. panhead_pete
    panhead_pete
    Thanks but it ****s kicking it when walking past. After doing that 3x I hope my muscle memory is there for that. :)
  28. mrquickwhip
    mrquickwhip
    Hi again Pete. You can buy blind grommets to fill the hole if you remove the cowl lights. Simply measure the hole and order them online. Easy peasy. My mate had an off topic car years ago and it had a rust hole at the cowl. He didn't want to repair and paint it, I asked him to make a cup of tea and I would sort it, he went indoors and by the time he came out with tea I had rummaged around his garage, found a blind grommet, filed the hole and fitted the grommet.
  29. Mark Grabo
    Mark Grabo
    from Upstate NY
    The seats are ford . 71-74 ford Mustang , Pinto or Maverick from the latch I Think Maverick
  30. Dan Hay
    Dan Hay
    Man that car is super cool! I'm a 70's kid so I have a soft spot for that era of hot rod!
