Projects A Farm Truck Comes to the City—’29 Pickup Build
Discussion in 'Traditional Hot Rods' started by ClarkH, Mar 20, 2021.
  1. Hitchhiker
    Hitchhiker
    Those wheels are technically my fault as well...
    I'm pretty good at spending your money, aren't I?(in this case technically trade stock)
    Stogy, 41 GMC K-18, Thor1 and 2 others like this.
  2. loudbang
    Ah the authorities not believe you on the frame number but sometimes if you have access and the area is clean lay a strip of masking take over the number then hold a lead pencil horizontally make a rubbing of the numbers by rubbing the lead over the numbers lightly and the numbers should stand out as white (or color of the tape) and the rest is lead color. Then if the numbers show nicely carefully remove the tape and apply it to a piece of paper and store it away someplace you will remember.
    That is how they do numbers here on an old vehicle the needs to be inspected and they put the rubbing right in the reg booklet.
    Or even a good clear photo.
    Moondog13, Stogy, 41 GMC K-18 and 2 others like this.
  3. ClarkH
    ClarkH
    ♫ "Back in the saddle again..."
    The farm truck and I took a break over summer. But now that the local weather has ****ped out, it’s time to get this thread moving again.
    I’ll start with the p***enger door. To refresh everyone’s memory, I had to remove the portion of the door jamb covering the hinges and fix some of the mount holes, leaving me with a bunch of this:
    Pretty straightforward repairs. Started by tracing a template of the middle hinge area:
    Cut and tacked insert
    Drilled holes for mounts
    Inserted hinge as a backer and used a steel dowel with rounded end to countersink
    Repeated at the bottom hinge and ground the ugly MIG welds flush
    On to the A-pillar...
  4. ClarkH
    ClarkH
    The p*** side A pillar was a cut-up mess. Especially the top hinge area, which started out looking like this:
    I cleaned up the hole with a Dremel and made an insert. There was just enough left of the inboard mount hole to serve as a guide for the other holes:
    Welded another insert in front of the hinge and then cleaned everything up. Ended up with this:
    Middle and bottom were easier. Middle before:
    Middle after:
    Bottom before:
    Bottom after:
    What I’m not showing here is the repe***ive test fitting of the door that went on throughout this process, to make sure I got everything in the right place. There's still some cleanup to do, obviously, but I went ahead and mounted the door so I could appreciate the progress.
    Actually, if you look close you'll see those pictures were taken during a test fit while I was still working on the forward part of the pillar. Everything is pulled apart now so these pics are the best I can offer. The important thing is, I now have two functioning doors. That is something to be thankful for.
    Happy Thanksgiving, all!
  5. -Brent-
    -Brent-
    Nice tutorial! This is going to be a neat pickup.
    Stogy, 41 GMC K-18, ClarkH and 2 others like this.
  6. ClarkH
    ClarkH
    Thanks @-Brent-. I often wonder if some close-ups of my work aren't a little cringe-worthy, so positive responses are encouraging. A thin skim coat at the end can hide many sins. As I said from the outset, any insights on my threads are more for Average Joes than Seasoned Pros.
    Closing the doors saga (at least for now), I also repaired some of the damage to the door skins that had resulted from aggressive welding during past hinge repairs.
    Uppers were easy, just a little insert to clean the edge adjacent hinge. To remind everyone, the right door started with the wrong side of the hinge welded to it (yikes!):
    I cut that mess off and welded an insert:
    The damage to the beltline area on the p***enger door was trickier. I spent an inordinate amount of time trying and failing to make a perfect little patch. I wound up going the two-piece repair route, which ended up being so much easier.
    Started with this:
    Proceeded like this:
    That's all on doors for a while. On to other topics...
  7. Wanderlust
    Wanderlust
    Looks good! Wonderful old truck
    Stogy, 41 GMC K-18, loudbang and 2 others like this.
  8. connielu
    connielu
  9. Jet96
    Jet96
    from WY
    .Thanks for showing your repairs, that's a lot to fix. I'm thanking my lucky stars my doors didn't look like that!
    winduptoy, Stogy, Thor1 and 3 others like this.
  10. 31Apickup
    31Apickup
  11. 41 GMC K-18
    41 GMC K-18
    "All things are possible through speed and diligence and perseverance "
    "Everything old is new again"
    "Perfection cannot be rushed"
    I am looking forward to seeing further progress on this worthy project!
    Has there been any new progress on the vintage " Traffic actuated switch panel box "?
    Stogy, ClarkH, loudbang and 1 other person like this.
  12. Duke of Haphazard
    Duke of Haphazard
    from PNW
    This is cool! Did something happen? It seems there've been no new posts for quite awhile. Hoping all is well with the project.
  13. ClarkH
    ClarkH
    Well, this thread has been in hibernation for a while. But the recent prodding from @Duke of Haphazard and @Stogy is timely, because it’s ready to wake up. And I mean that both figuratively and literally.
    By way of an explanation for my silence: Engine issues with my speedster have been consuming most of my build-attention. Over the past two years, two older babbet bangers failed me, and now I’m committed to a serious rebuild. But that’s for another thread.
    As for the farm truck, my original plan was a hopped-up banger. But with all my banger-enthusiasm locked up in the speedster, I was lured by the evil Siren-song of a flathead V8. Specifically, a rebuilt 8RT that’s been sitting under a bench in my brother’s shop for the better part of a decade. This is an engine my brother acquired to go into a now long-gone A coupe. He’s totally fixated on Hudsons these days; eager to clear some space, asked me if I wanted it.
    Well YES, I exclaimed, while earnestly shaking my head NO. Why the conflict? Because as cool as that flathead is, I knew in that instant I was transforming what was intended to be a simple project into something very complicated.
    A key complication is that my little 2-car garage is completely overwhelmed. Between the speedster and several dismantled bangers and the truck cab, not to mention work benches, tools, equipment, spare parts and such, I have virtually no room to work.
    God love him, @Hitchhiker alleviated the problem somewhat by offering me a corner of his shop where I could set up the truck’s ch***is. I guess you help a guy move countless tons of car parts up and down the I-5 corridor a couple-three, four times, he figures he owes you a favor or two.
    So here’s the engine, sitting on a stand at Seattle Speed shop awaiting her close-up.
    We popped the heads off for a quick inspection and the rumored rebuild appears to be true.
    Doing this was not a big deal because I won’t be using the 8RT heads, and the whole thing needs to come apart anyway because I don't have much faith in the effectiveness of 10-year-old ***embly lube.
    So now the thread has been reawakened. Plenty more to come. Fitting this engine into a ’29 engine bay without going all Lizzy Borden involves much creative reconfiguration. More to come.
  14. 31Apickup
    31Apickup
    Good to see this moving forward again.
  15. 41 GMC K-18
    41 GMC K-18
    So cool that Matt @Hitchhiker, has made a little space for this noble project to come to life !
    Looking forward to future updates on this cool project !
    Thor1, Squablow, tb33anda3rd and 5 others like this.
  16. The37Kid
    The37Kid
    Nice to see you starting with a nice clean rebuilt motor!
    Stogy and ClarkH like this.
  17. winduptoy
    winduptoy
  18. Stogy
    Stogy
    John boy would be pumped...getcha back to the farm quicker...:D
    @ClarkH this seems a plausible period correct choice to me...a trip to the wreckers back in the day could easily have provided a low mileage engine from a wreck for such a project...I've complete confidence you will present a well rounded runabout. Timeliness is never a problem with me as I understand the way life has a way of being an incredibly diverse affair...
    Then there's Hitchhiker along with your bro, the missus and us Hoodlums how could you go wrong...;)
    I always enjoy chiming in here...thanks for your detailed journey back to the Yesteryear...
  19. Hitchhiker
    Hitchhiker
    I believe the word you were looking for to describe me was ENABLER....Perhaps DEALER :eek::rolleyes:;)
    Thor1, ClarkH, Squablow and 3 others like this.
  20. 41 GMC K-18
    41 GMC K-18
    I actually had to look up that term "Scope Creep"
    So glad it wasn't in reference to the loose fitting of a telescopic sight on a firearm!
    At 70 years old, it's still possible to learn something new, by participating on the HAMB, daily!
    Thor1, ClarkH, Toms Dogs and 3 others like this.
  21. Hitchhiker
    Hitchhiker
    This thread needs an update @ClarkH...a very lengthy one
    Outback, Thor1, osage orange and 5 others like this.
  22. ClarkH
    ClarkH
    Uh, yeah. Gosh, where were we…
    So the plan is to squeeze this flathead into the tiny ’29 bay without moving the radiator or severely cutting the firewall. That meant more-or less reconfiguring the 8BA into a 59AB. i.e older water pumps, new cam, front-mount distributor, center-mount gen and fan, etc. When we opened up the engine we found a few minor issues, so the block went off to the machine shop. More on that later.
    Meanwhile, we proceeded in fitment with a dummy block and trans.
    We opted for a Tardell K-member (sourced via Instagram), which necessitated a ’32 wishbone (from Hitchhiker) and a dropped ’32 heavy axel (Hamb cl***ifieds). We wanted the cab in place to verify fitment before welding the K member, so I hauled it and the box up to @Hitchhiker’s shop.
    Put the cab in place and installed the front suspension. Note the reverse-eye spring and 4-inch drop. (This might be too much...)
    Went to install the dummy engine, and I’ll be darned if it didn’t fit. I mean, it’s tight. Really tight. But you can slide a piece of paper between the block and firewall. So technically, it clears. (We did remove a short section of the lip that supports the floor. It won’t be visible with the floor installed.)
    (Added a little bling there for inspiration.)
    While the block cleared, we could see there will be interference with the 59AB style rear-mounted fuel pump/oil filler. Hitchhiker’s buddy solved this for me used a slick little air hammer to form a bump-out into the firewall that exactly corresponds to the pump tower. My job was to sit in the cab holding a shot bag over the affected area while he worked; each man according to his talents, I guess. After finishing with hammer and dolly, it looks darn-near factory. We will have to be creative with oil fill, however. Still working on that.
    Committed now, we welded in the K-member.
    At this point, it was begging for a full mockup. So we set the box on it, and rolled it out for a picture.
    Well, I'm not lying, we all just smiled and stared at it for a while. I mean, it looks great to me. It’s a bit more rake than I was expecting, which is fine. But I intend to run fenders, so there may be some height fiddling yet. And the tie-rod is going to be a challenge for sure.
    If you look through the doors, you’ll see Hitchhiker’s ’32 ressurection project in the background. Kind of a cool juxtaposition.
    Next up: The engine.
  23. Pass The Torch
    Pass The Torch
    I gotta get busy on mine... I knew I shouldn't have opened up the thread! Thanks for the kick in the pants.
  24. alchemy
    alchemy
    A rear spring from a T would set it about perfect.
  25. Hitchhiker
    Hitchhiker
    Do you know what T spring fits? I've tried several original T rear springs on model A rear ends. And they're not anywhere close to fitting.
  26. Outback
    Outback
    from NE Vic, Oz
    Oh how I would love to go down this road, but not for me at the moment. I am enjoying watching this lil truck come together :cool:
    osage orange, ClarkH and 41 GMC K-18 like this.
  27. alchemy
    alchemy
    No sorry I don’t know specifically. I have a pile for future use but haven’t bolted any in yet. We all know that the T’s are a little narrower in leaf width, but I thought the overall length was compatible. What problem are you encountering?
  28. Hitchhiker
    Hitchhiker
    The main leaf wont stretch enough to get to the shackles. Its easily 6 inches short.
    41 GMC K-18 likes this.
  29. patsurf
    patsurf
    i thought that was the old trick to put a qc under a deuce?did they do lots of mods?
    Outback likes this.
  30. Martinbuilt
    Martinbuilt
    There's those lovely springs from OYS
    ClarkH likes this.
