Technical Lowering the rear not the front?
Discussion in 'Traditional Customs' started by john W., Nov 26, 2021.
  1. john W.
    john W.
    My new all-stock 47 Caddy has lowering blocks in the rear. Looks like 2 inches.
    Was this done by the former owner just for looks?
    This would affect the handling, right? As a former racer I would say yes.
    Why wouldn't he have lowered the front to match? Oil pan clearance?
    Thanks
    My car is on the left. On the right is another car at the factory ride height.
    Screen Shot 2021-11-26 at 1.53.26 PM.png Screen Shot 2021-11-26 at 1.53.50 PM.png
    Greenblade and dana barlow like this.
  2. jimmy six
    jimmy six
    Ever heard of a tail dragger? Because he didn’t want too. In the early 50’s rear lowered cars were every where I lived; mid 50 and late 50’s lowered the front…..then all hell broke loose.
    jnaki, samurai mike, CadMad and 8 others like this.
  3. i.rant
    i.rant
    If your car at one time looked like the photo on the right lowering the rear was probably done in an attempt to level the ride height.
    I’ve had a few cars with blocks on the rear and never noticed any change in the handling .
    Your Caddy looks good now.
    Greenblade, Packrat, Tim and 3 others like this.
  4. seb fontana
    seb fontana
    from ct
    Personal taste.
    427 sleeper and 210superair like this.
  5. X38
    X38
    It' not about handling, it's about the look. Cool factor.
  6. stanlow69
    stanlow69
    The one on the right just looks too high in my own opinion. Lowering the rear transfers the weight of the car to the rear making it easier to steer. It also handles better going around corners as well. Less body roll. Plus, it looks good. No need to lower the front.
    Packrat, i.rant, williebill and 2 others like this.
  7. john W.
    john W.
    Ill test it soon.
    No race car in our history that I know of gained a handling advantage by being lowered only in the rear. Id like to hear more opinions.
    I agree it does look cool...
    Thanks
  8. Casey Riley
    Casey Riley
    from Minnesota
    Is yours the outdoor picture? Or the the one in front of the garage door?
  9. GordonC
    GordonC
    I 'd say yours has the best looking ride height. As far as handling I don't think you'll be running any gymkhanas with that car and for riding around town it will probably be just fine.
    427 sleeper likes this.
  10. john W.
    john W.
    I drive all my cars pretty fast despite them being luxury led sleds. I lose hubcaps with alarming frequency, so Im moving to wire wheels.
    My car is the one near the garage door.
    BY "race car" I meant non-drag cars.
    Greenblade likes this.
  11. 19Fordy
    19Fordy
    Lowering the rear makes the look sleeker, longer and period correct.
    It's part of the "cool" factor back in the day.
  12. john W.
    john W.
    Okay,
    Ill lower it to the ground in the rear then...
  13. X38
    X38
    I don't know why you even ask questions.
  14. oldsman41
    oldsman41
    Taildragger needs a 3 inch in rear to my eye. If you don’t drag the oil pan 2 inch drop in front
  15. chop&drop
    chop&drop
    It looks perfect to me just as it is.
  16. el Scotto
    el Scotto
    from Tracy, CA
    Me too!
  17. Yeah, what he said.
  18. big bird
    big bird
    Like both, but I like the Left side more!
  19. guthriesmith
    guthriesmith
    Exactly :cool:
  20. 427 sleeper
    427 sleeper
    In theory, you're 100% correct. In reality, it's a Bad *** lookin' 47 Caddy, not a canyon carver. Drive it and enjoy it the way it was meant to be... JMHO ;)
  21. Anderson
    Anderson
    I’m confused, you have a handling concern because the rear end is lowered…but you want to switch to wire wheels which will not handle as well as solid steel wheels?
    So long as the front end was properly aligned after the rear was dropped, it should not effect handling.
    hotrodjack33, X38 and 427 sleeper like this.
  22. Because of cool. That’s why.
    Surfcityrocker and 427 sleeper like this.
  23. And jacked up in the back on a big full size car looks goofy
  24. I dislike tail draggers but yours doesn't look like one, it just looks right.
  25. And handling isn’t important for cruising
    hotrodjack33 and 427 sleeper like this.
  26. john W.
    john W.
    I will keep it as is.
    Thanks for the tips on tail draggers.
  27. jimmy six
    jimmy six
    With all that said….I’d lower the front 3-4 and take out the rear blocks……I always got better mileage going down hill.
    hotrodjack33 and 1stGrumpy like this.
  28. Mimilan
    Mimilan
    Don't drive it in North Carolina. They are banning the "Carolina Squat":D
