Hot Rods Hurst Airheart Rebuild Parts???
Discussion in 'The Hokey Ass Message Board' started by Joe DeBattista, Nov 24, 2021.
  1. Joe DeBattista
    Joe DeBattista
    What is everyone doing for their Hurst Airheart overhaul parts. Tolomatic discontinued a bunch of the calipers, and hence discontinued the rebuild parts as well. Had I known we would have stocked up, but curious if anyone else has found any solutions other than just tracking down old kits out there.
  2. dreracecar
    dreracecar
    from so-cal
    Depends on what is needed , O-rings (3 sizes) are a pretty standard deal
    Joe DeBattista likes this.
  3. deucemac
    deucemac
    You might try The BRAKE Man (TMB) in Simi Valley. It was started by Warren Gilliland, who was Bill Airheart's protégé. Warren retired but drops in ocean in a while nowadays. He was the only person to be able to help me with my lobsters when I needed parts. He really knows what to do and how to get parts for H/A brakes. It's worth a shot .
  4. Joe DeBattista
    Joe DeBattista
    The O rings yes are pretty standard that little wave washer is proprietary and used to come with the kits. I just found some NOS kits, just was curious about what people are doing as I know a lot of guys run these.
  5. Joe DeBattista
    Joe DeBattista
    Totally thanks for the tip I’ll look into it. Thanks.
  6. dreracecar
    dreracecar
    from so-cal
    The Piston "drag" washer that came with the kit. I have found that they were a pain to deal with and wound up reusing the old ones that were sized to fit the original piston shaft anyway. The only parts to the kit that I have a hard time sourcing are the 4 little dust sleeves that go over the shafts
  7. Fordors
    Fordors
    By chance I had some silicone tubing laying around that was close on the inner diameter and the wall thickness is about .060. I slipped it on a wooden dowel rod and cut pieces to length with a razor knife. Silicone tube is used for aquariums, food service equipment, etc.
    If not silicone a thin wall rubber or vinyl tubing might work just as well.
    My calipers are 175-06 series, which ones use the wave (or drag) washers you guys are referring to?
    stillrunners likes this.
  8. dreracecar
    dreracecar
    from so-cal
    Vinyl tubing is too stiff and will not collapse as the black rubber that comes with the kit, The proper material is out there, but my needs fall short over buying a 25ft roll of it when I only need 4 inches
  9. JimSibley
    JimSibley
    Doesnt speedway carry parts for these?
